Flat speaker wire
apphd
apphd Posts: 1,514
I am looking at trying out some flat speaker wire (tape type). I see most use one type of a terminal block or another. Does anyone know of other ways to terminate these? Can they be soldered? Can the conductor be rolled/folded and used in common banana plugs and/or binding posts?
Thanks for any comments.
Post edited by apphd on
  • Face
    Face Posts: 14,340
    edited August 2009
    You can use a hole puncher and slide the wire under the binding post nut or you can spend $$$ and buy Goertz style termination.
  • apphd
    apphd Posts: 1,514
    edited August 2009
    Thanks Face, never thought of the hole punch, and while the Goertz are not an arm and a leg I'll have to think about that for a while.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited August 2009
    apphd wrote: »
    I have used flat speaker wire before. I used standard bananas on these and simply rolled the wire into a rounded "pig-tail" shape before inserting into the banana plug like you suggested. The only difficult thing about the flat wire was stripping the wire. I used a razer to cut the insulater and hand-pulled it away to expose the bare copper. It worked, but it was a pain. My wire strippers are for round wire (as are most).
  • jimmydep
    jimmydep Posts: 1,305
    edited August 2009
    Is this the type of wire you have??
    Jimmy
  • apphd
    apphd Posts: 1,514
    edited August 2009
    jimmydep wrote: »
    Jimmy
    Not sure if you missed your reference link or pic what ever you were questioning, but this is what I am looking at:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=099-058
    Now I am questioning: has anyone removed this after a year or so, does it cause much damage when removed?
  • GreggC
    GreggC Posts: 23
    edited August 2009
    I have thought about using flat cables also - what sort of experiences have others had with these? Are they as good as thick cables I have now?
    Thanks,
