Flat speaker wire
apphd
I am looking at trying out some flat speaker wire (tape type). I see most use one type of a terminal block or another. Does anyone know of other ways to terminate these? Can they be soldered? Can the conductor be rolled/folded and used in common banana plugs and/or binding posts?
Thanks for any comments.
Post edited by apphd on
You can use a hole puncher and slide the wire under the binding post nut or you can spend $$$ and buy Goertz style termination."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks Face, never thought of the hole punch, and while the Goertz are not an arm and a leg I'll have to think about that for a while.
I have used flat speaker wire before. I used standard bananas on these and simply rolled the wire into a rounded "pig-tail" shape before inserting into the banana plug like you suggested. The only difficult thing about the flat wire was stripping the wire. I used a razer to cut the insulater and hand-pulled it away to expose the bare copper. It worked, but it was a pain. My wire strippers are for round wire (as are most). -
Is this the type of wire you have??
Jimmy -
Jimmy
Not sure if you missed your reference link or pic what ever you were questioning, but this is what I am looking at:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=099-058
Now I am questioning: has anyone removed this after a year or so, does it cause much damage when removed? -
I have thought about using flat cables also - what sort of experiences have others had with these? Are they as good as thick cables I have now?
Thanks,
