Need to vent...
  • kuntasensei
    kuntasensei Posts: 3,263
    edited August 2009
    Here's a pic or two of the damage:
    As you can see, the wood had swollen up almost to the tip of the carpet spikes. I have no clue how I didn't notice it before now.
    I got some repellent spray after work to try to break the dog of marking before my replacement base arrives. Not sure if it works on the dog, but the cat can't freakin' stand it!
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • kcoc321
    kcoc321 Posts: 1,788
    edited August 2009
    looks like Polk CS came thru for yah...BUT I would definitely still clear coat both of them, real good. that way it can never happen again... the MDF on the bottom was 'raw" and that is why it could absorb the moisture...any moisture.
    Good luck.....:o
  • Upstatemax
    Upstatemax Posts: 2,739
    edited August 2009
    It's good to hear you have an easy/cheap fix! :cool:
    How did you not smell that?
  • kuntasensei
    edited August 2009
    Seriously, you can't smell it unless your nose is right up on it... and looking at it closely, it's really not as yellowed as you'd think dog piss would make it. Makes me wonder if it's dog piss or if the lady who occasionally cleans here was running the steam cleaner right up on that speaker (which I hadn't even considered until I looked at the bottom). That would almost make sense, considering the speaker's location. Plus, the carpet around the speaker doesn't really seem to be stained like you'd expect if the dog was marking it regularly. Look at this pic:
    I'm seriously wondering if that white film on it is from the steam cleaner's detergent, and if the slight smell is just mildewing wood from the moisture. Either way, Polk's CS came through... and I'll definitely be giving the new base a quick clear-coating before it goes on.
    Equipment list:
    Emotiva XPA-3 amp
  • gavn8r
    gavn8r Posts: 53
    edited August 2009
    So yeah... the dog has apparently been marking it for some time without me noticing, effectively destroying my speaker.
    I had the same problem. Turns out it was my son. He lives in the cellar now.
  • thsmith
    thsmith Posts: 6,082
    edited August 2009
    Amazing, Polk CS is right on !
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2009
    mmadden28 wrote: »
    A friend of a friend gave me a Piano--didn't realize it until it was home but he had a cat that made that piano its ****. I guess I can't complain much as it was free-but I do have to spray it (lysol/febreze) from time to time---eventually I'll get around to sealing it (to hopefully seal in any odors).
    I used to have cats--and one of them started the marking indoors.--I found this spray at the petstore that the cats really really realy did not like. They curled thier noses up when they got anywhere near it. I forget what its call-not sure if it works for dogs too.
    You can use an enzyme called "Nature's Miracle"...available at PetSmart/etc. for about $ 28/gallon or you can get it online for less than $20/gallon plus shipping. It will DESTROY the odor, but you have to soak it pretty good & let it stay on the area.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited August 2009
    I think you should send an e-mail to Polk Customer service thanking them all for the great work they for Polk customers. You should also share with them the whole story with them. The reason I say this is because they will really appreciate the thanks and get a great kick out of the story. Too many times the people on the front lines like customer service reps are over looked.
  • bklynNupe
    bklynNupe Posts: 728
    edited August 2009
    When I was a kid, my mom had a Chiwawa really pissed up my father’s EPI speakers. Then we had some cats that did the same including using the speaker covers as scratching posts! I love dogs, but don’t own any because I know what they can do to your stuff. Maybe when I have a big enough house one day with a large backyard I can restrict a dog to the yard and part of the house. I think dogs that are in this habit will never stop because your speakers might as well be a tree. I know I would flip- out if a dog “decorated” my a’9!
    As for cats, they are some nasty SOB’s and if they pee once, it’s a wrap!
    Off the subject a bit, but I never understand why folks post stuff for sale on CL and have their cat or dog laying on it. To me it is a clear sign that they pet may have chewed, pissed or scratched the item a bit. Not a good look! :mad:
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • jimmydep
    jimmydep Posts: 1,305
    edited August 2009
    If you think the cleaning lady is getting the bases wet when she cleans the carpet, you might try some higher carpet spikes....something high enough to keep the base off the carpet......Just a thought.
    Kudos to Polk's CS.
    Jimmy
  • kuntasensei
    edited August 2009
    I'm gonna go with the suggestion of clear-coating the bases. That ought to help.
    Equipment list:
    Emotiva XPA-3 amp
  • danger boy
    danger boy Posts: 15,722
    edited August 2009
    NJPOLKER wrote: »
    wow.. that's not very nice :p
    PolkFest 2012, who's going>?
  • NJPOLKER
    edited August 2009
    danger boy wrote: »
    I was just using the short version of his member name. I'll bet that happens a lot.
  • NJPOLKER
    edited August 2009
    I also think the advice I gave him is the right thing to do. Any comment on that :D:rolleyes::cool::):confused::o:p:eek:
