Pioneer Elite Watts/Channel
mufsoman
Am I understanding correctly the watts/channel specs for my Pioneer VSX-94TXH that it provides 140w no matter what the set up, 2.1, 5.1 or 7.1? What am I missing? If this is not true, then what are the specs? Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Denon 3800
Parasound HCA-2205A
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Post edited by mufsoman on
Its called Google.
"Power output was generous in 2- and 1-channel tests, and the 94TXH was happy enough driving 4-ohm loads. With 5 and 7 channels driven, and its clamping circuitry in full effect, it fell well short of 100 watts per channel"
http://www.soundandvisionmag.com/receivers/2635/pioneer-elite-vsx-94txh-av-receiver-specifications-and-conclusions-page2.htmlLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Google??? Never heard of it.....Yes, I found the same report, just missed that statement about the watts. Thanks anyway.Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables -
They never output what they say per channel. So now, I use my Pio '94 as a pre amp and I am using Carver 1.5t's amps on all my speakers. I was supprised when the tone on the '94 got warmer with the carver's.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
bsoko2 - Thanks for the feedback. I'm hoping to upgrade to some amps in the future when the funds are available. And by the way, great set up. I looked at your System Showcase. I'll be posting mine soon too. Thanks againSony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
