Swivel Speaker Mounts for Fxi3
maks71
maks71 Posts: 5
edited December 2009 in Basic Hookup/Wiring Questions
Hello Polkies!
I just bought Fxi3 from Polk's Ebay store. I'm planning to hang them on the wall and wondering about options for mounting brackets. Since my walls are high 10' , I'd like to use mounts that provide swiveling function.
Searched quite a few threads I came to know that these speakers comes with inbuilt key-hole bracket but did not find any definitive answers about swiveling brackets.
Does Fxi3 has one key-hole or two??
Here is my requirements.
1) Swiveling
2) Should not require any drilling on the speakers.
3) Obviously , should be able to bear the weight of the speakers (10-13lbs).
Thanks in advance for your replies. My apologies in advance if this has already been answered and I missed in my search..
Max.
Post edited by maks71 on
  • mmadden28
    mmadden28 Posts: 4,283
    edited August 2009
    Why do you want them to be able to swivel? The FXis are not meant to be directional or 'aimed' at you.
    Your walls are 10' high, but do you have to mount them that high?
    I have my FXi3s mounted about 8-9' (because I did have to mount them that high-over a window/walkway), and they sound fine. Try regular mounting first before doing any workarounds.
    Welcome to Club Polk
    ____________________
    Pool: Atrium 60's/45's
  • maks71
    maks71 Posts: 5
    edited August 2009
    PRe-wired spots are right near ceiling. i.e. around 10'. Will that position be ok to deliver sound to 5-6' below?
    Thank
  • maks71
    maks71 Posts: 5
    edited August 2009
    Does anyone know how many key-holes Fxi3 has? ( I haven't received mine yet)
  • AudioGenics
    AudioGenics Posts: 2,567
    edited August 2009
    would you be interested in a set of POLK Audio speaker mounts.
    WB 3000 Wall Brackets
    and a Welcome to Club Polk.
  • maks71
    maks71 Posts: 5
    edited August 2009
    jvc wrote: »
    Where could I find them? Googling with WB 3000 did not help... Also , do they require drilling hole into speakers?
  • maks71
    maks71 Posts: 5
    edited August 2009
    maks71 wrote: »
    Any one??
  • Knucklehead
    Knucklehead Posts: 3,602
    edited August 2009
    Welcome to CP, I have the FX500i's they have 2 but I believe yours may have 1 from looking at the manual.
    Check this out....http://www.polkaudio.com/downloads/manuals/home/CSi3_5_FXi3_5_MN.pdf
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • mmadden28
    edited August 2009
    maks71 wrote: »
    Thank
    Well since the wires are there already, mount them in that spot, calibrate your AVR (if it has that cabaility), and see how it sounds. They're not supposed to be directional so it may work just fine for you. I think I recall something indicating that they should only be a few feet above the ears, but like I said, mine are up pretty high and it sounds damn good--would it be better if they were lower? Probably, but I have no choice so up high they stay. You may want to try Di-Pole mode.
    Then if you don't like it, worry about angling or swiveling them.
    maks71 wrote: »
    I believe its one keyhole.
  • PSOVLSK
    PSOVLSK Posts: 5,382
    edited August 2009
    This works great for me. I currently use it for LSi 7's, but I've used other speakers including the FXi A4.
    http://www.crutchfield.com/p_121BT77B/B-Tech-BT77-Black.html?search=BTech+BT77&tp=586
  • reubenray
    reubenray Posts: 91
    edited November 2009
    PSOVLSK wrote: »
    The FXiA4's are what I want to setup behind me at a height of about 7' 6" to the bottom. This has to be this high due to doors. They will also be in the corners so they will need to be turned a little. Looking at the link I could not tell if these swivel and tilt enough at the same time. I would like to also confirm that you used these previously with the FXiA4 speakers being these speakers are not square or rectangular shaped. I will also be using these for my FXi3's surrounds.
    Onkyo TX-NR709 A/V Receiver
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
    SVS 20-39PCI Subwoofer
  • JotGloky73
    JotGloky73 Posts: 10
    Looking for DVD with tips on control and focus on entries into submissions
    Suggestions?
