RTi10 vs RTiA7
dei08dei
Hey,
Could someone help me out with a simple question(s). I noticed the price difference between the RTi10's and the RTiA7's. They look virtually the same. Other can cabinet differences (height and width) what are the differences between these two. I currently have RTiA3's for my front channel and a CSi5 center channel.
Thanks for your help.:
Post edited by dei08dei on
A lot of people have posted saying they think the newer A series sounds a bit better than the older series.
Keep in mind you will need a good amount of power to make either of those sing. The two big woofers plus the decent size midrange can put a hurtin' on smaller receivers. -
no reason to double post this dei...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
The differance is the price!!!! I just sold my RTI10's for $350.00 and picked up a pair of RTI12's for $500. So being a older model you can get great deals on the RTI series(used) and save money. I know it has been said that the RTIA series sounds better and Polk redid the cabinet but I heard both and there was little differance. Though let me say this was on 2 differant systems and enviroments. But this was my opinion.I do like the sleeker look of the RTIA series but I saved a bunch of cash staying with the RTI series and finding them used.Good power and cables will definately help.:)HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
As Dekuda mentioned go for a pair of RTi12s.Shoot the jumper.....................BALLIN.............!!!!!
RTi12's ... hope you have 200watts or so.
What will you be using the drive them? -
I have done side by side listening with both models and the new RTia models are more refined sounding. Cleaner and clearer. More musical if you will. I was very impressed with the 7's. I say for for them over the older models.
DanDan
i have the RTi A7's, i absolutely adore themsetup
Panasonic 46pz85
Polk RTi A9's
Polk CSi A6
FXi A6's
Energy s12.3 sub
Denon 3808ci
Pioneer elite dv-79
Monster 1850
Denon dp500m w/ grado green
PS3,XBOX 360, NES -
Dang, $350 for the Rti10s is very nice. $500 for the Rti12s is very nice as well...Onkyo 805, RtiA5s, Csi5, Rti6s
