SR124 DVC Question
magnum21
magnum21 Posts: 3
edited December 2009 in Car Subwoofer Talk
Hi guys i have a question I will be getting 2 SR124 DVC now my question is how should i power them? I want to run as close to the RMS rating of them as possible. I was recommended a kenwood KAC X1R by crutchfield but I have heard they dont run stable at 2 ohm is this true?
Thank you very much
Post edited by magnum21 on
  • MacLeod
    MacLeod Posts: 14,358
    edited November 2008
  • killerb
    killerb Posts: 390
    kenwood excelon kdc-x991 h.u.
    Rockford Fosgate 360.3 DSP
    Rockford Fosgate POWER1000 running entire system
    Image Dynamics IDQ12 Sub
    Morel Elate 6 front stage
  • magnum21
    magnum21 Posts: 3
    thanks for the ideas quick question about both
    for the PA1200.1 isnt that gonna be a little underpowered to run both subs?
    and for the massive audio where is the best place to buy it from? I see on the site its listed as out of stock
    Thanks alot
  • MacLeod
    edited December 2008
    My bad. I thought you were running only 1 sub.
    Still, that would be 600 watts per sub which aint too shabby. The 1500 would be more but consider that although it would be 150 watts more, it only adds up to a .75 db increase in volume.
  • magnum21
    magnum21 Posts: 3
    ok cool this is my first time using either one of those amps I just wanted to be sure which would be best. if I did go with the PA1200.1 how far past the rms can it go while still being stable?
  • pushkanak
    pushkanak Posts: 45
    edited August 2009
    Hello, I just purchased two SR124-DVC subs and am now going to purchase the proper amp for them, so this thread got my attention.
    While I want the PA1200.1, I don't like its lack of power to take each sub to 700 rms. So I'm considering the RF T1500. What do you guys think about that amp? What I want is enough power and a good SQ combination, since SQ is my major concern.
    Thanks.
  • pushkanak
    pushkanak Posts: 45
    edited August 2009
    Actually, I've found these amp alternatives, besides the RF T1500 and the polk PA 1200.1:
    Boss CW3500D
    MB Quart DSC 1500.1D
    Polk Audio PA1200.1
    Power Acoustic BAMF5500/1D
    Soundstorm CR5000.1
    Autotek AT2000.1
    Quantum QCa4500D Cozmik
    JL Audio - G-MAX
    I need an amp who moves the subs to their max rms potential, while at the same time preserving a good SQ. It's a pity that the polk PA 1200.1 amp can't power the subs to their max.
    Which one do you think is the best brand for what I'm looking? I'm open to other suggestions if better that all those.
  • MacLeod
    edited August 2009
    That RF would be a good choice. Plenty of power.
  • pushkanak
    pushkanak Posts: 45
    edited August 2009
    MacLeod wrote: »
    Yes, but is it also the best amp from within that list for an SQ setup together with the subs?
  • pushkanak
    pushkanak Posts: 45
    edited August 2009
    I've researched in many sites and found out that the MB Quart and RF seem to be good brands for SQ. I'm posting the SQ related specs for each amp (directly from their manuals) and see if someone can infer from them which amp can produce better SQ.
    Mb Quart DSC 2000
    Frequency Response-3db 15hz-250hz
    Signal to Noise ratio > 95 db
    THD & N 0.1%
    Damping Factor >200
    RF T1500
    Frequency Response 20Hz to 250Hz ±0.5dB
    “A” Weighted Signal to Noise Ratio
    Referenced to 1 Watt into 4 ohms ≥80 dB
    Referenced to rated output into 4 ohms ≥100 dB
    THD+N (Total Harmonic Distortion + Noise) (T500-1bd) < 0.5% @ 1ohm
    THD+N (Total Harmonic Distortion + Noise) (T1500-1bd) < 0.8% @ 1ohm
    Damping Factor >200
  • pushkanak
    pushkanak Posts: 45
    edited August 2009
    Any insights onto this?
  • MacLeod
    edited August 2009
    Amps dont produce sound quality, they produce power. Sound quality depends on what you do with that power.
    For an amp you want great built quality, plenty of clean power and no noise. Both the RF and the MB Quart and the JL Audio and the Polk will give you that. The others are flea market brands.
  • Reggin
    Reggin Posts: 22
    edited August 2009
    How does this compare with the Blaupunkt one?
  • cadenceclipse
    cadenceclipse Posts: 459
    edited August 2009
    it doesn't. cadence ia9-hc. like mac said rf, mb, jl and polk will all work fine but for price, power and other reasons, i'd check out cadence. think u can get that amp w/ 5 yr warranty for like $400..
    Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
  • ButtaMax
    ButtaMax Posts: 1
    Hi, Im new!!
    I just got a sr124 and ill be using a PPI d3000/1.
