Component Video Cables?
POLKHT
Is there still a need for component video cables? With HDMI and lossless audio being more common, why should one keep them or use them?
Post edited by POLKHT on
I personally don't use them. For video I stick strictly to HDMI, for me the audio is a + imo because I don't even use it being that my receiver doesn't have hdmi inputs. But it serves its purpose sending audio to the tv as well from my cable box in case I dont want to use my surround sound. Oh wait I do use component, for my Wii and thats just because I HAVE to.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Component is still a very viable cable choice. I use Component in most of my setups, and, to me, HDMI is not the greatest thing since sliced bread.
If you need 1080p, or if you want the convenience of a single-cable solution, then HDMI is the way to go. Otherwise you can't go wrong with Component. It is a proven and reliable method.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
+1
Didn't mean to bash component,I simply hate clutter so I buy into it for convenience.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
How would you get lossless audio, without HDMI?
Optical/coaxial digital connections, that is if the source in itself is pure coming from a cd/sacd/dvd-a or so.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Sometimes you have to use component cables with older HDMI devices or some devices with DVI out because they do not register as HDCP compliant.
Toshiba 62HMX85
Panasonic DMP-BD60
Xbox 360 with HD-DVD
Pioneer VSX-9130-TXH-K
Polk Audio CSiA6
Polk Audio RTi10's
Polk Audio RTi4's
Polk Audio RTi6's
Polk Audio PSW505 -
How does the picture quality differ between the two?
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
So you can get Master Audio or TrueHD over digital coaxial or optical?
No, I think he mislead on that one by mistake... -
DVD players can upconvert 480p to 720p. It's still the same amount of source data so it's not as nice as a HD source. Component will be around for as long as the content providers will allow it. The industry does not like component since it is an analog cable that provides for easy copying of content.
Component can do 720p and 1080i. In fact, the Component specification and cables can handle 1080p, but there are few (if any) source components that do 1080p over component due to DRM.Speakers: Polk LSi15
Not much if any but if you have a LCD TV hdmi will look better otherwise no difference.Speakers: SDA-1C (most all the goodies)
If I understand correctly, hdmi is good in the short runs but not in the long and component is the samefor both short and long runs without loss of information?
