Component Video Cables?
POLKHT
POLKHT Posts: 138
edited September 2009 in Basic Hookup/Wiring Questions
Is there still a need for component video cables? With HDMI and lossless audio being more common, why should one keep them or use them?
Post edited by POLKHT on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    I personally don't use them. For video I stick strictly to HDMI, for me the audio is a + imo because I don't even use it being that my receiver doesn't have hdmi inputs. But it serves its purpose sending audio to the tv as well from my cable box in case I dont want to use my surround sound. Oh wait I do use component, for my Wii and thats just because I HAVE to.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2009
    Component is still a very viable cable choice. I use Component in most of my setups, and, to me, HDMI is not the greatest thing since sliced bread.
    If you need 1080p, or if you want the convenience of a single-cable solution, then HDMI is the way to go. Otherwise you can't go wrong with Component. It is a proven and reliable method.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • kawizx9r
    edited August 2009
    tcrossma wrote: »
    +1
    Didn't mean to bash component,I simply hate clutter so I buy into it for convenience.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • POLKHT
    POLKHT Posts: 138
    edited August 2009
    How would you get lossless audio, without HDMI?
  • kawizx9r
    edited August 2009
    POLKHT wrote: »
    Optical/coaxial digital connections, that is if the source in itself is pure coming from a cd/sacd/dvd-a or so.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Solumnus
    Solumnus Posts: 48
    edited August 2009
    Sometimes you have to use component cables with older HDMI devices or some devices with DVI out because they do not register as HDCP compliant.
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
  • xj4094dg
    xj4094dg Posts: 1,158
    edited August 2009
    How does the picture quality differ between the two?:confused:
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • POLKHT
    POLKHT Posts: 138
    edited August 2009
    So you can get Master Audio or TrueHD over digital coaxial or optical?
  • Conradicles
    Conradicles Posts: 6,340
    edited August 2009
    POLKHT wrote: »
    No, I think he mislead on that one by mistake...
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2009
    DVD players can upconvert 480p to 720p. It's still the same amount of source data so it's not as nice as a HD source. Component will be around for as long as the content providers will allow it. The industry does not like component since it is an analog cable that provides for easy copying of content.
  • tcrossma
    edited August 2009
    Component can do 720p and 1080i. In fact, the Component specification and cables can handle 1080p, but there are few (if any) source components that do 1080p over component due to DRM.
  • thsmith
    thsmith Posts: 6,082
    edited August 2009
    xj4094dg wrote: »
    Not much if any but if you have a LCD TV hdmi will look better otherwise no difference.
  • speedster2333
    speedster2333 Posts: 37
    If I understand correctly, hdmi is good in the short runs but not in the long and component is the samefor both short and long runs without loss of information?
