PS3 as media server??
Lowell_M
Lowell_M Posts: 1,660
edited August 2009 in Electronics
I hijacked a thread earlier and thought I should start a new one...
I know and understand that you can swap out the internal HD of the PS3 for bigger. Can you also load MP3's or other song formats on an external HD and connect to the PS3?
Also, will the PS3 rip songs from a CD onto the HD?
Or...I currently have a PC set up as a media PC, but the way I have it setup is somewhat inconvenient. Is there a way that the PS3 can see the PC over my network and play songs of the PC harddrive?
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    You can rip cd's but from my understanding it is defaulted to rip them at 128 or 256 i dont think you have the option. If was you I would invest in an apple tv and use the built in one on there as that is what it was mead for. or do what me and the neighbor did buy a big hard drive for the computer and put all the music on that than alow the apple tv to just use the music in itunes on that hard drive for its music "the reason we did this ws because we did it in lossles and had over 7k songs"
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited August 2008
    Yes you can set up your computer to stream content over your network if you have one. And yes, you can load up an external with mp3s. I would choose the former option though. try googling a walk through. Should be easy enough.
  • mantis
    mantis Posts: 17,381
    edited August 2008
    You can change the recording rate on the ps3. I have mine set to aac 320 and it sounds great.
    Dan
  • Fongolio
    Fongolio Posts: 3,516
    edited August 2008
    I have a 500 gig external connected via usb. Two things doing it this way....the file system on the external must be fat32 and the hard drive must have the same folders as a PS3. Game Music Photo Video. Works great for me and is still portable and usable for on other setups like my computer.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • JDOGG
    JDOGG Posts: 433
    edited August 2008
    You can have your PC stream all the media over your network, to your ps3, for playback over your audio system(which is what I do). Your gonna need a media server like TVersity, or something along those lines.
    http://tversity.com/
    Panasonic VIERA 46" 1080p plasma
    Onkyo TX-SR805
    Klipsch RF-7(bi-amped)
    Klipsch RF-25
    Xbox 360 with HD DVD
    Playstation 3
    Cobalt Cable
  • Lowell_M
    edited August 2008
    Thanks for your help. I got the PS3 streaming from my media PC last night through Media Player 11. I have some serious library maintenance to do, though, because I have a lot of music in Apple Lossless.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited August 2008
    a_mattison wrote: »
    If you use TVersity, it will pass ALC, and PS3 will read it, eliminating the need for WMP. I have found TVersity much more versatile.
  • PhantomOG
    PhantomOG Posts: 2,409
    edited August 2008
    JDOGG wrote: »
    Ok, this tversity things looks interesting... but what exactly does it do? I install it on my network connected PC right? And then what does it help with? I can already find and play shared mp3's/videos/pics on the PC so what additional functionality does this software provide? Is this just for streaming web sources?
  • Sami
    Sami Posts: 4,634
    edited August 2008
    TVersity is the way to go. It will also decode FLAC on the fly to PCM for the PS3 if you want to go the lossless way.
  • PhantomOG
    edited August 2008
    so you run tversity on the PC and then connect to it on the PS3 through the web browser?
    ok, I read it connects to media server. Have to try this out when I get home tonight.
  • LessisNevermore
    edited August 2008
    PhantomOG wrote: »
    No web browser involved. It shows up in the XMB like a networked computer. (which is essentially how it's set up)
    You will have to manually set up which folders are shared by TVersity, and it takes some time for it to build the library, but after that, giddy-up.
    If you have more than one pc on your network, you can install and run TVersity on those as well. I have a small home recording studio set up in my basement, and pipe my test mixes upstairs to the main system for playback. (it sure beats burning a cd each time!) The drawback, is that a pc has to be running to run TVersity. I'd love it, if the PS3 had NAS support, it would eliminate the need for TVersity, except for transcoding video on the fly.
    It's a far more complete solution than WMP 11. There are several ways to convert video files, and it's not something I've played with a whole lot yet, so I'll let others steer you on that one.
    There is one program (also free) that I've used that avoids having TVersity transcode the videos to a format the PS3 understands. http://www.redkawa.com/videoconverters/ps3video9/
    Very straight forward and easy to use.
  • PhantomOG
    edited August 2008
    Hmm... I wonder if my PC is beefy enough to stream HD. Or my wireless network connection stable enough for that matter.
  • LessisNevermore
    edited August 2008
    From what I understand, it takes at least a duo-core, or quad, to stream HD. Not sure I'd attempt it wirelessly, either. I got tired of futzing with the wi-fi on ps3, and ran some cat-5. Much improved. As always, ymmv.
  • cheddar
    cheddar Posts: 2,390
    edited August 2008
    PhantomOG wrote: »
    I prefer to just use a big external usb drive. Seems old school 'cause you have to walk it from pc to the ps3. But nothing beats the stability and pure speed of a local connection.
  • Lowell_M
    edited August 2008
    I've been reading about TVersity and ,man, that sounds like the ticket. I may start building a flac library, but it also looks like people have been able to stream Apple Lossless as well, which is what a good portion of my library consists of.
    I thought about just adding a hard drive to the PS3 and moving files over, but I have two 250gb hard drives in my simple media PC and backup one to the other every 3 days, so no need to worry about losing data and its automated so I don't have to worry about being lazy.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • punny
    punny Posts: 1
    edited November 2008
    Hi.....
    This site is really informative.....
    Thanks man.....
  • EugeneDouglass
    EugeneDouglass Posts: 1
    edited December 2008
    hi...
    :o I've been reading about TVersity and ,man, that sounds like the ticket. I may start building a flac library, but it also looks like people have been able to stream Apple Lossless as well, which is what a good portion of my library consists of.:(
    I thought about just adding a hard drive to the PS3 and moving files over, but I have two 250gb hard drives in my simple media PC and backup one to the other every 3 days, so no need to worry about losing data and its automated so I don't have to worry about being lazy.:eek:
  • reignsantiago
    reignsantiago Posts: 1
    edited August 2009
    You can rip cd's but from my compassionate it is defaulted to rip them at 128 or 256 i dont anticipate you accept the option. If was you I would advance in an angel tv and use the congenital in one on there as that is what it was mead for. or do what me and the acquaintance did buy a big harder drive for the computer and put all the music on that than alow the angel tv to just use the music in itunes on that harder drive for its music "the acumen we did this ws because we did it in lossles and had over 7k songs"
    _________________
    Predictive dialer
  • concealer404
    concealer404 Posts: 7,440
    edited August 2009
    There are a lot of one post wonders in this thread.
  • FittyFieFo
    FittyFieFo Posts: 482
    edited August 2009
    I plan to use my computer to stream music to the PS3. I've also read about Tversity working with the Nintendo Wii as well. This has been a great help :)
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • concealer404
    edited August 2009
    FittyFieFo wrote: »
    Don't forget your predictive dialer!
  • Willow
    Willow Posts: 11,231
    edited August 2009
    I use the PS3 Google media server and have no issues
  • Conradicles
    Conradicles Posts: 6,343
    edited August 2009
    I use my PS3 to drop 70 yard TD bombs and thunderous hits on folks with Madden Online play. PS3 is a work of art!
  • SoundArtillery
    SoundArtillery Posts: 39
    edited August 2009
    Fongolio wrote: »
    I use 1TB external and a PS Audio DLIII with excellent results.
