I feel like a new subwoofer...what do u think?>
Right now I have a velodyne CT100 powered sub....i like it but its older....I came across this one on amazon and seems like a great deal.....would it be worth the upgrade or should i just stick with what I got?
http://www.amazon.com/BIC-America-F12-450-Watt-Subwoofer/dp/B0015A8Y5M/
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
Post edited by Polkie918 on
You know, I'm starting to see more and more of these "BIC's" lately. I would also like to hear opinions on this thing from owners of a Velodyne CHT-12 or Velodyne DLS-4000 so I know what it's being compared to.
Btw nice sub you posted Polkie918, just wondering what youre aiming for really. I'm kind of looking for something to hit true 20hz or exceptionally close to without breaking the bank hard (for HT use). Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
just want a really good sub...got a large room to fill and the ct100 does a good job but im sure there is better cleaner bass.Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV -
Look into a SVS subwoofer.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
+1
Definitely an SVS, but it all depends how much you want to spend. Really though the best thing to do is just hold off on that "new sub" a little longer and save up some cash.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
whats an svs??
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
With that setup, SVS or Epik. www.svsound.com or www.epiksubwoofers.comShoot the jumper.....................BALLIN.............!!!!!
I recently switched from a Velodyne DLS 3750 to a Elemental Designs A2-300 for a huge improvement. My Velo is similar to yours in performance, it pretty much just rattles and has no output below 30 hertz. The A2-300 is truely in a different class and compares to the SVS PB 10. The bass is so much deeper and cleaner making the Velo that I thought was pretty decent seem like a toy.
There are a lot of good manufacturers of subs so shop around, anything you get that can do 20 Hz will be a huge gain. IMO the A2-300 at $350 shipped is as good a price/performance deal as you will find anywhere.HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2 -
i can see that -
Internet Direct subs are the best way to go....the downside is that it isn't easy (or cheap) to audition them all. Don't necessarily base your decision on spec sheets. Sound quality is more important.
Here's a good ranking list to reference when shopping for a sub:
http://www.avsforum.com/avs-vb/showthread.php?t=768150My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
It's unclear from the literature if that 450 watts isn't dynamic peak wattage..in which case this sub would compare, at least in specs, with Polks PSW505 (300 watts continuous) and my Boston A. 12" (300 watt digital/450 peak). Both weigh in at about the same. Mine is almost 46lbs.
What's impressive is that PRICE!
Never listened to a BIC....I've heard the Polk and obviously my own B.A. and they're about as good as anything in the 4-500 dollar range. They're no SVS or higher end sub. But for the money--hard to beat! Velo 4000 is a good sub too.
Now, mind you, I'm not saying GREAT!!
Holy CRAP that price is ridiculous.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Sunfire True sub. One going on ebay right now for $500 bin shipped.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320409560863Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Ok,
That is a great price for the Sunfire....'used' that is? But probably OK used.
However, Sunfires are in the 1000+ dollar MSRP category new. And that's the next tier up.
Here is some info on the BIC F2:
http://www.avsforum.com/avs-vb/showthread.php?t=1116093
Some highlights from the comments...
Looks like 150W RMS. It's equivalent to the BIC-100. Someone says that the BIC-100 was discontinued because Kplisch sued about the copper colored driver. The F2 sounds similar to the BIC-100. There are some nice pics comparing the two. -
Ok,
cnh
If you are looking for new the Sunfire is out of your price range. Heck it is out of mine new. Ever other month or so I see one of these deals on eBay or craigs listings. I would have snatched it up but I had to buy a chain saw this month and used my extra $$$.
Two sunfires would be nice. I might have to think long and hard about snatching it up.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
thuffman03 wrote: »If you are looking for new the Sunfire is out of your price range. Heck it is out of mine new. Ever other month or so I see one of these deals on eBay or craigs listings. I would have snatched it up but I had to buy a chain saw this month and used my extra $$$.
thuffman03,Don't think to hard about it my friend.......You can rent the chainsaw for a day or two, but not that Sunfire.
PULL THE TRIGGER AND BUY IT. I know that's what will make you happy. hehehe.
B.B.3Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's
