Tube amp suggestions for SDA-SRS...Anybody?
MB,SC Polkie
MB,SC Polkie Posts: 30
edited August 2009 in 2 Channel Audio
I am in the market for a new amp to drive my SDA-SRS speakers. I have never owned a tube amp, and am considering getting my feet wet. The SDA-SRS are rated at 1,000 watts as you know, so it will obviously need a larger tube amp maybe between 200, and 300 watts correct? I am also on a bit of a budget, so I am considering the Chinese tube amps.
I also should mention that I have no problem if need be rewiring it a bit. I understand that some of them can make darn good tube amps with a few parts changed out, and a few things bypassed etc. Let me know your opinions on this, even if you think I should stick with Solid State. Considering the Adcom 5802 as well for a SS. Thanks
BEING GOOD GETS YOU STUFF. BEING STUFF GETS YOU GOOD!....Mr. Bungle :D
Post edited by MB,SC Polkie on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    I personally run a Moscode 300 for my SDA 1C's and it plays with beautifully. Wanted to add though that I've also heard it running 1.2tl's, and a Moscode 600 ran the 1.2's even better. Very natural, clear and LOUD...although it was also connected to a tube pre. If you can find one, I'd say you're in for a treat without breaking the bank!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    heiney9 Posts: 25,491
    edited July 2009
    BAT, Manley, Cary come to mind. Those aren't cheap for higher power units. Really be careful with some of the Chinese stuff as much of that stuff uses very odd tube circuits and tube designations which limits your future ability to roll tubes or find suitable replacement tubes.
    Another option is to go with a SS power amp and get a really nice tube pre that responds to tube rolling, as that's where the fun is.
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    +1 on H9's suggestion. Tubes and Hendrix,,, wow
  • MB,SC Polkie
    edited July 2009
    heiney9 wrote: »
    Thanks Heiney9. I have heard this same suggestion from another serious tube guy, but never had the chance to hear exactly why....time thing. Anyway, this sounds great to me. Not too sure what rolling tubes means, but I have heard that comment a few times. Sorry, still reading and asking questions. Any tube preamps that you feel are worthy under a grand?
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited July 2009
    This is a ridiculous price for these amps. If you like el34's these will suit you very nice....Marvda1 has a pair as well so you could get his thoughts as well.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstube&1252894874&/Consonance-Cyber-800-Tube-Mono
    Good luck,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • george daniel
    edited July 2009
    Unless they are commom ground,he is gonna' have to use the AI-1 non common ground interface.
  • ND13
    ND13 Posts: 7,601
    edited July 2009
    The Anthem One @ 40wpc was more than enough to drive my SRS2s to very loud, clean levels in a $500 sq. ft. room. It sounded better than the 75wpc McAlister horizontal tube amp I had for a while. The SDAa are much more efficient than people realize. Now if going solid state, the more watts and current you can get, the better.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
    F1nut Posts: 51,924
    edited July 2009
    I'll add a few more in no particular order. VTL, Wolcott, Audio Research, McIntosh, Conrad-Johnson, Jolida and Sonic Frontiers.
    You don't need 200-300wpc tube amps, 100wpc will be plenty.
    edited July 2009
    To answer the OP's question about "tube rolling" simply means buying all the different brands (GE, RCA, Mullard, Siemens, etc) and variants (ie; 12AT7 = 6210, 6211, ECC81, E180CC, etc) and swapping them in and out to find a tube(s) that you like. They all sound slightly to largely different and the fun is the hunt for a great bargain and experimenting.
    Here's a great site with lots and lots of info and here's an example of the info on the tubes my pre uses (12AT7).
    http://www.audiotubes.com/12at7.htm
    You need to get your lean on because IF you are looking to get a tube power amp there are different kind of output (power) tubes and they all sound/react slightly different. Other things to look for in a power amp is auto biasing of the tubes; if no auto biasing then you would need to bias the tubes occasionally yourself, check to see how easy the procedure is.
    Also research the terms, Ultralinear, push/pull and class A as they relate to tube amps those are the 3 basic output configs.
    I'm still just a toob noob myself so if anything above is incorrect someone will correct me.
    GL
  • MB,SC Polkie
    edited July 2009
    Thanks everyone for all the good advice. This will give me some direction in which to read. Tube stuff is just a whole new world to me. I am going to read more about a tube pre, and a ss amp config. as this really has my interest. I still have a long way to go before I settle on anything. I probably should start a new thread on good tube pre amps under $500.:rolleyes:
  • george daniel
    edited July 2009
    If you are serious and ready to buy,,I know where a vintage VTL 50(stereo) watt tube amp can be had for your budget,,LMK.
  • marvda1
    marvda1 Posts: 4,958
    edited July 2009
    for $1300 i would be all over the consonance cyber 800. i paid double that for mine and that's still a steal for the level of performance that they bring. just make sure there is someone close that can work on them in case a power tube goes as it tends to take out resistors also, but this is a simple fix. if you have to take out a 401k loan do it ( done a couple of those myself).
    Puritan PSM156
  • Systems
    Systems Posts: 14,872
    edited July 2009
    I'm partial to Conrad Johnson.
    Testing
    Testing
    Testing
  • madmax
    madmax Posts: 12,434
    edited August 2009
    I ran mine with some Manley 200W monoblocks for awhile. That was the best they ever sounded. A pair like I had just ended on audiogon which were going for $1400. That is insanely low (5K new) but they didn't sell. I looked but they are no longer listed. I bet they show up again.
    madmax
    Vinyl, the final frontier...
  • MB,SC Polkie
    edited August 2009
    Thanks everyone for taking the time to shead some light on this. After reading a bit more, I think I may go with a tube preamp first to see how I like it.
  • madmax
    edited August 2009
    The amp is where the rubber really hits the road. :)
    madmax
