Anyone modified the wiring of SDA-1C
restanim
restanim Posts: 227
edited July 2009 in DIY, Mods & Tweaks
I am concidering ditching (NOT throwing away) the SDA cable and wire the SDA drivers in parallel with the stereo drivers. I did identify the fact that each SDA driver is wired in series as well as the stereo drivers.
This will be just a trial run and may not be permanent.
Comments?
Mike
polkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015
Post edited by restanim on
  • Face
    Face Posts: 14,340
    edited July 2009
    Why?
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2009
    Wouldn't this negate the SDA effect?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • restanim
    restanim Posts: 227
    edited July 2009
    Why? Well, I prefer standard stereo sound and I would expect more output from all four drivers as opposed to just the two stereo drivers.
    Remember, this is just a trial and I may not like the result.
    polkaudio
    Currently Own:
    Previously Owned:
  • Systems
    Systems Posts: 14,872
    edited July 2009
    For one I'm thinking you will end up with a frequency balance problem with all 4 drivers operating as the stereo array because the midrange and bass levels will be increased but the tweeters level will not have changed.
    Testing
    Testing
    Testing
  • restanim
    restanim Posts: 227
    edited July 2009
    Yeah, I did concider the output of the mid/mid bass would be higher. I would use my equalizer to smooth this out.
    Thanks!
    polkaudio
    Currently Own:
    Previously Owned:
    heiney9 Posts: 25,630
    edited July 2009
    Sell them and get conventional speakers. The x-overs are designed to run the dimensional drivers over a very specific freq range. Simply disconnecting them will not get you what you desire.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2009
    Sell me your 1C's and get some different speakers...lol
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Systems
    edited July 2009
    Just to add,while the schematic shows the midbass's for both the DA and SA sections operate over the exact same range ,(the difference in crossover values is due to a parallel connection for one array and series for the other) paralleling the two sections will likely result in a very low impedance.
    Testing
    Testing
    Testing
  • restanim
    restanim Posts: 227
    edited July 2009
    I see the SDA drivers are in parallel, I would definitely wire them in series.
    polkaudio
    Currently Own:
    Previously Owned:
  • Systems
    edited July 2009
    restanim wrote: »
    But then the crossover frequency will change due to it seeing a different load.
    Testing
    Testing
    Testing
  • restanim
    restanim Posts: 227
    edited July 2009
    This is what I intend to do:
    The Stereo drivers wired in series.
    The SDA drivers wired in series.
    Then wire the SDA drivers in parallel with the Stereo drivers.
    The SDA drivers will be dis-connected from the SDA part of the crossover.
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
  • Systems
    edited July 2009
    restanim wrote: »
    What you are proposing would only work (without shifting the crossover frequency) if the impedance of the four drivers combined had the same impedance as that of the two series connected SA drivers.Otherwise you would have to duplicate the crossover of the SA section for use with the DA pair and connect them in series,then connect both the SA and DA sections in parallel.In other words not a simple fix.
    I see that the midbass drivers in each section are different models (6510's 6511's,)Anyone know the what differences are between them? impedance? sensitivity? or both?
    Testing
    Testing
    Testing
    edited July 2009
    GV#27 wrote: »
    The exact information is proprietary, but that's a very good guess. The voice coils on some of the MW drivers are wound differently as well.
  • restanim
    restanim Posts: 227
    edited July 2009
    Ha Ha!
    Bose junk? NO THANKS!
    I don't need anymore speakers.
    I'll just hook up my Legacy Audio FOCUS.
    polkaudio
    Currently Own:
    Previously Owned:
  • comfortablycurt
    edited July 2009
    That sounds like a lot more work than it's worth...
    I'd just sell the 1C's and get some different speakers.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited July 2009
    You have to understand... what you're proposing to this forum is, for the lack of a better word, blasphemy. SDAs were specially designed to be run the way they are wired.
    There is a reason there are not many speakers out there made with 4 like drivers side by side. If you prefer standard stereo, there is absolutely no purpose in going through this work. Your Legacy Audios are on a vertical axis FOR A REASON... does this make sense?
    If you're dying to tear open the SDAs... do so to upgrade the crossovers or something. What you're suggesting is like converting a sports car to diesel, just because you prefer diesel.
  • restanim
    restanim Posts: 227
    edited July 2009
    Well fellas, I am convinced NOT to do this mod.
    Thanks for all your input,
    Mike
    polkaudio
    Currently Own:
    Previously Owned:
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    restanim wrote: »
    Mike
    No,, Thank You :)
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited July 2009
    Whew, that was close one. Almost lost a perfectly good pair of 1C's to "curiosity" lol.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • comfortablycurt
    edited July 2009
    restanim wrote: »
    Mike
    Thank you!
    So do I need to take a road trip to New York and buy your 1C's?:cool:
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    Just run them without the innerconnect cable and you'll be good to go.
  • restanim
    restanim Posts: 227
    edited July 2009
    Thank you!
    No need to, they are staying here as Polk designed them. BTW they are in immaculent shape with the RD tweeters.
    polkaudio
    Currently Own:
    Previously Owned:
  • restanim
    restanim Posts: 227
    edited July 2009
    leroyjr1 wrote: »
    Yeah, that seems to be an easier solution as to what I was trying to achieve. But, the interconnect cable stays.
    polkaudio
    Currently Own:
    Previously Owned:
  • lightman1
    lightman1 Posts: 10,800
    edited July 2009
    Was getting ready to road trip for an intervention.....and pick up Curt along the way.....
    Dodged that bullet.
  • wutadumsn23
    edited July 2009
    lightman1 wrote: »
    Dodged that bullet.
    I was willing to be the "muscle" for the trip if needed, lol. Then ditch you two on the way home and enjoy my new 1C's, lol.
    HT Rig
    Blu-Ray- 80 GB PS3
  • lightman1
    edited July 2009
    About 7000 miles to save a set of 1C's..worth it.. say the word.
  • Systems
    edited July 2009
    lightman1 wrote: »
    LOL :D seems like a few of you had one foot out the door ready to spring into action.
    Testing
    Testing
    Testing
  • restanim
    restanim Posts: 227
    edited July 2009
    We should call you guys the "Polk Police" ;)
    polkaudio
    Currently Own:
    Previously Owned:
  • lightman1
    edited July 2009
    GV#27 wrote: »
    Hell...I had the car started by the last keystroke!
    Glad you came to your senses, ritalin.
    Curt has a bad disposition...worse than mine.
  • restanim
    restanim Posts: 227
    edited July 2009
    I probably should have asked what a non SDA speaker with similar sound to the 1C I could aquire. Looking at Polks line-up, The Monitobr 12 seems to be a good choice.
    Suggestions?
    polkaudio
    Currently Own:
    Previously Owned:
