8 volt 300 mA lamp replacements
rmaiers
Does anyone know where 8 volt 300 mA replacement lamps can be found. I have an Nikko NR-1019 receiver that has 3 burnt out bulbs I would like to replace. These lamps were used in a lot of 1970s and 1980s Japanese made stereo gear. Not fuse type, two wire connections.
Try www.vintage-electronics.net. Bob has 8V 300mA bayonet and wedge base lamps. The latter were used in Pioneer receivers of the 1970's. Good luck, I hope you can find what you need
Dennis -
embo,
I quoted your post in another thread thanks for the info.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
would you have a closeup picture ?
Thanks Dennis. I sent them an email to see if they have replacement lamps I can use.
Bob
