8 volt 300 mA lamp replacements
rmaiers
rmaiers Posts: 145
edited July 2009 in DIY, Mods & Tweaks
Does anyone know where 8 volt 300 mA replacement lamps can be found. I have an Nikko NR-1019 receiver that has 3 burnt out bulbs I would like to replace. These lamps were used in a lot of 1970s and 1980s Japanese made stereo gear. Not fuse type, two wire connections.
  • embo
    embo Posts: 10
    edited July 2009
    Try www.vintage-electronics.net. Bob has 8V 300mA bayonet and wedge base lamps. The latter were used in Pioneer receivers of the 1970's. Good luck, I hope you can find what you need
    Dennis
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2009
    embo,
    I quoted your post in another thread thanks for the info.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    would you have a closeup picture ?
  • rmaiers
    rmaiers Posts: 145
    edited July 2009
    Thanks Dennis. I sent them an email to see if they have replacement lamps I can use.
    Bob
