Yet another Monitor 7 question
tx_polkhead
Hi, are the outside dimensions of all monitor 7 the same or was there some variation from model to model? My 7c's are 14" x 24" x 9 7/8" (WxHxD) where depth includes the grill. If you have a measuring tape handy please chime in with the dimensions of your speaker and specify which Monitor 7x. I am trying to justify an IKEA AV/TV stand and the Monitor 7c I was using as a CC is an inch too tall to squeeze in the spot I imagined it would live in. Do I rebuild my Monitor 7 to fit in the spot or keep an eye out for a different vintage Polk that will squeeze in to the 14 1/2" x 23" space?
Abel
Abel
Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
Same here – Monitor 7A (1979).
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
I think they were all basically the same dimensions. Those are the same dimensions as my (1978) 7A's.
I think the Monitor 7 Series II was a little bit deeper...due to the beveled baffle edge. Couldn't be much more than an extra quarter inch or so though.
To answer your other question, I'd just keep your eye out for a different speaker. What other speakers will you be running in your setup?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
My mains (right and left channels) are RTA 12c's my surrounds are Monitor 5JR+, with a single Monitor 7c as the center channel, and a Infinity Interlude 100 Sub. Right now I am leaning towards building an enclusure of equal volume that would fit in the space and just keep the empty shell of the Monitor 7 so the drivers can always go back.Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
