Yet another Monitor 7 question
tx_polkhead
tx_polkhead Posts: 248
edited July 2009 in Vintage Speakers
Hi, are the outside dimensions of all monitor 7 the same or was there some variation from model to model? My 7c's are 14" x 24" x 9 7/8" (WxHxD) where depth includes the grill. If you have a measuring tape handy please chime in with the dimensions of your speaker and specify which Monitor 7x. I am trying to justify an IKEA AV/TV stand and the Monitor 7c I was using as a CC is an inch too tall to squeeze in the spot I imagined it would live in. Do I rebuild my Monitor 7 to fit in the spot or keep an eye out for a different vintage Polk that will squeeze in to the 14 1/2" x 23" space?
Abel
Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • jimbo1421
    jimbo1421 Posts: 772
    edited July 2009
    Same here – Monitor 7A (1979).
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2009
    I think they were all basically the same dimensions. Those are the same dimensions as my (1978) 7A's.
    I think the Monitor 7 Series II was a little bit deeper...due to the beveled baffle edge. Couldn't be much more than an extra quarter inch or so though.
    To answer your other question, I'd just keep your eye out for a different speaker. What other speakers will you be running in your setup?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • tx_polkhead
    edited July 2009
    My mains (right and left channels) are RTA 12c's my surrounds are Monitor 5JR+, with a single Monitor 7c as the center channel, and a Infinity Interlude 100 Sub. Right now I am leaning towards building an enclusure of equal volume that would fit in the space and just keep the empty shell of the Monitor 7 so the drivers can always go back.
