Best amp for LSI 25
Jude59
Jude59 Posts: 5
Just got a pair of LSI 25s and am impressed enough to consider getting a dedicated amp. Considering a used amp of high quality. A friend mentioned a Plinius 8200. However, I read some reviews that said it doesn't handle rock music very well. I could definitely use some suggestions. Seems like there are lots of higher-end used amps to choose from in the $1,000-1,500 range. Any help would be appreciated. Thanks
Post edited by Jude59 on
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2009
    Jude,
    There are many threads on this. Most say anything over 200 wpc is a good choice. Though you must make sure that the amp you choose will work with a 4 ohm speaker.
    I don't know much about Plinius so I cannot say without looking it up. I would suggest a Sunfire 300x2. You should be able to get one of those in the range you are looking at.
    If you don't have that much $$$ I would suggest a Carver TFM 35 or better. A Carver TFM 55 would deliver 500 wpc into 4 ohms and you can get one for about $500.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • curved
    curved Posts: 664
    edited July 2009
    Agree with Thuffman03.
    You picked a good speaker for you music taste IMO.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • polkatese
    polkatese Posts: 6,767
    edited July 2009
    check out Krell 400xi. Matched pretty well with LSis.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
