Want to switch out the capacitors on my Monitor 40s
I've never actually tinkered around inside speakers before, so this will be a first for me. At the suggestions of some posts and reviews, I would like to get some Jantzen Z-Standards and swap them with the stock capacitors. First of all, which specific Z-Standard should I get for these speakers? Also, would anyone have any pointers in how to go about doing this?
Post edited by Sedako on
Many here use Dayton caps from parts express for inexpensive cap upgrades. (although I have not heard anything bad about Jantzen either)
Yes - just get the same values as what you have now and go for it.
(do a quick search for crossover upgrade and you will get some ideas of what you are getting yourself in for. it may not be for your exact speaker, but there are good tips in many of the upgrade threads) (there are even a few in my sig...
Michael
BTW - Welcome to Club Polk.
Amplifier.........Cinepro 3k6 (6-channel, [email protected])
Thanks! Would it benefit me at all to go for some higher spec'd caps, or is it best to match specs to the old ones?
BTW - the schematic for your monitor 40's is located here....
lots of options are available to choose from.
Is that the Jantzen Standard Z-Cap or Crosscap?
Anything from a speaker crossover won't hold a charge large enough to do any damage, or possibly even enough for you to feel anything.
As for the Dayton caps, did you purchase the 1% caps instead? The only difference is the tollerance.
Yes. It was the 1% caps.
