Life span of power amp?
kjaym71
Hi guys,
I am looking at 5-year-old used multi channel amplifier(Rotel).
Because this is my first power amp, I am not sure how it will last(life span).
Can I use power amp for for a long time(like more than 20 years)?
Thanks,
Thanks,
Post edited by kjaym71 on
5 Years? That has a lot of life left, just take good care of it and it'll be good to you. Is it a RMB-1075?
Some the amps I own are 20+ years old and still going strong. Some even sound better that some of my newer ones.
Don't sweat the age, just the condition of the unit.
Russ -
There might be a way to assess the probability of a failure.
using a Measurement such as "Mean time between failure"
a multichannel amplifier has numerous components
and just a single component failure would have an adverse effect on performance
dirt, dust, temperature variations, humidity, power spikes etc...
enjoy and when it breaks consider your options to repair or replace. -
At the moment I'm running a 20 year old Kenwood integrated amp (original owner--yours truly) on some SDAs and it sounds better than it ever has on other speakers...it is rated to 4 ohms.
I had a Rotel that lasted about 18 years. It probably would have lasted longer but it got daily use!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Yes, they can last quite a while. Although receivers, my Marantz (33 years old) and my Kenwood (31 years old) are still going strong.Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
My XPA-5 is coming up on its first anniversary.:D
My Nikko Alpha VI is going on 30yrs old & performs like it's right out of the box. At 300w (dual mono design) this puppy puts out some serious power!!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
Scuse me while I wipe up the drool!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
That Nikko looks 'mint'! What do you do to the outside?--it looks like my car after a good wax! Very NICE Pearsall.
(cfrizz) is right! I'm second in that line.
I have a thirty-two year old Tandberg receiver that is hooked up to a new pair of RTiA1 speakers and doing well!Don't forget to enjoy the music...
cnh
Truth be told...I haven't done anything to the amp. I think it's the lighting from the camera that picked up it's original shine. And yes this puppy is absolutely "Mint", everything is still original & working as if I just bought it. I'd better knock on wood as I say that. So it looks like the life line of electronics can be a very, long time."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Very nice looking gear Phil.Michael
NORTH of 60° -
They key component that you can usually match a time frame up to is the power caps tend to go around the 20-25 year point...although that's not an absolute. There are many factors.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
That's one of my concerns...going on 30yrs now & if they go I wonder if I can even replace them & at what cost? Other than that...this puppy is playing like it's a newborn pup. I'm keeping my fingers crossed."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
pearsall001 wrote: »My Nikko Alpha VI is going on 30yrs old & performs like it's right out of the box. At 300w (dual mono design) this puppy puts out some serious power!!!
That is a really nice piece of gear. :eek: -
Thats a nice lookin classic.
