Life span of power amp?
kjaym71
kjaym71 Posts: 10
edited July 2009 in Electronics
Hi guys,
I am looking at 5-year-old used multi channel amplifier(Rotel).
Because this is my first power amp, I am not sure how it will last(life span).
Can I use power amp for for a long time(like more than 20 years)?
Thanks,
Post edited by kjaym71 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    5 Years? That has a lot of life left, just take good care of it and it'll be good to you. Is it a RMB-1075?
  • lightman1
    lightman1 Posts: 10,796
    edited July 2009
    Some the amps I own are 20+ years old and still going strong. Some even sound better that some of my newer ones.
    Don't sweat the age, just the condition of the unit.
    Russ
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    There might be a way to assess the probability of a failure.
    using a Measurement such as "Mean time between failure"
    a multichannel amplifier has numerous components
    and just a single component failure would have an adverse effect on performance
    dirt, dust, temperature variations, humidity, power spikes etc...
    enjoy and when it breaks consider your options to repair or replace.
    edited July 2009
    At the moment I'm running a 20 year old Kenwood integrated amp (original owner--yours truly) on some SDAs and it sounds better than it ever has on other speakers...it is rated to 4 ohms.
    cnh
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2009
    I had a Rotel that lasted about 18 years. It probably would have lasted longer but it got daily use!
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited July 2009
    Yes, they can last quite a while. Although receivers, my Marantz (33 years old) and my Kenwood (31 years old) are still going strong.
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
  • Hilbert
    Hilbert Posts: 316
    edited July 2009
    My XPA-5 is coming up on its first anniversary.:D
  • pearsall001
    pearsall001 Posts: 5,280
    edited July 2009
    My Nikko Alpha VI is going on 30yrs old & performs like it's right out of the box. At 300w (dual mono design) this puppy puts out some serious power!!!
  • cfrizz
    edited July 2009
    Scuse me while I wipe up the drool!
    edited July 2009
    That Nikko looks 'mint'! What do you do to the outside?--it looks like my car after a good wax! Very NICE Pearsall.
    (cfrizz) is right! I'm second in that line.
    cnh
  • DeadFeat1
    DeadFeat1 Posts: 51
    edited July 2009
    I have a thirty-two year old Tandberg receiver that is hooked up to a new pair of RTiA1 speakers and doing well!
    Don't forget to enjoy the music...
  • pearsall001
    edited July 2009
    cnh wrote: »
    cnh
    Truth be told...I haven't done anything to the amp. I think it's the lighting from the camera that picked up it's original shine. And yes this puppy is absolutely "Mint", everything is still original & working as if I just bought it. I'd better knock on wood as I say that. So it looks like the life line of electronics can be a very, long time.
  • janmike
    janmike Posts: 6,146
    edited July 2009
    Very nice looking gear Phil.
    Michael ;)
    NORTH of 60°
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2009
    They key component that you can usually match a time frame up to is the power caps tend to go around the 20-25 year point...although that's not an absolute. There are many factors.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • pearsall001
    edited July 2009
    TNRabbit wrote: »
    That's one of my concerns...going on 30yrs now & if they go I wonder if I can even replace them & at what cost? Other than that...this puppy is playing like it's a newborn pup. I'm keeping my fingers crossed.
  • XJRGUY
    XJRGUY Posts: 258
    edited July 2009
    That is a really nice piece of gear. :eek:
  • greymatter
    greymatter Posts: 35
    edited July 2009
    My clear.gifNikko Alpha VI is going on 30yrs old & performs like it's right out of the box. clear.gifAt 300w (dual mono design) clear.gifthis puppy puts out some serious power!!!
    Thats a nice lookin classic.
