dsw pro 600 vs new svs pc12 nsd
superjunior
superjunior Posts: 1,632
I'm just about ready to upgrade to a decent sub. I was set on the dsw 600, but I've been looking at the new svs. Does anyone have any experiance with the new svs pc12 nsd ? It cost a bit more, I'm wondering if the extra change is worth it. My room is roughly 14 x 26 and it would be used mostly for movies, I usually listen to music in pure direct mode. Any comments are much appreciated.
Jr
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    Haven't heard the dsw's but the SVS' model before the one youre looking at is sick. Its also more of an HT sub as opposed to a musical sub, but who says you cant play music with it? I was hearing alot of good things about the dsw that you really get alot of value for the money, especially if you went with a refurb on polk ebay. As for that, I also had epic sentinels on my list along with a sunfire hrs8/10, if you dont mind spending just a little more go give them an audition too.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • apphd
    apphd Posts: 1,514
    edited July 2009
    A couple things jump out at me. "14x26 and mostly movies." I didn't check the $ difference but it doesn't sound like it scares you off so I have to say SVS all the way. With you location shipping should be minimal.
  • superjunior
    edited July 2009
    I think the price difference is a couple hundred. I really like the features of the 600, but the svs is ..well.. an svs. It is noticably smaller than its predecesors,though. I don't know of anywhere around here to demo either one, in fact my system was built from info I've read here(can't thank you guys enough :)) decisions,decisions.. hmmm...
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • kawizx9r
    edited July 2009
    Well, SVS is located in Ohio, I'd call them and find where the nearest authorized retailer is, or go to the company itself, see if they've got anything out you can listen to. Although if you did that, you might just leave with a much thinner waller than you would have hoped to. Svs subs are beasts imo
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    I've never heard the SVS sub but I own the DSW-PRO 600 and it does a very good job equally on HT and music.
    From what you said you'll be using it mostly in HT,so I'll limit my comments to that, you will get that ground thumping in the chest feeling even at half volume, and it really does a great job of filling in the low end of a movie soundtrack, but don't expect to rattle the pictures off the wall.
    My set-up is in a 20 x35' room and it does an excellent job with plenty of good vibrations....if you're the type that wants that 7.5 earthquake effect then look at something else....if you like "normal" HT then the PRO 600 will meet all your expectations.
    Pro's: very musical, nice tight bass with a hard thump when necessary, definitely not BOOMY, good sustained low end vibrations, nice remote control.
    Con's: Larger than I thought, volume control needs a little getting used too (you have to count the blinking lights), remote doesn't work when placed in front firing position.
    For the price a GREAT DEAL!!!!
    Hope this helps
    Jimmy
  • superjunior
    edited July 2009
    thanks for input fellas. It's raining here, I'm stuck in the house, wife's at work, I'm bored and my wallet is taunting me. Gonna pull the trigger here if I can just make up my mind...:confused:
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • bevo
    bevo Posts: 306
    edited July 2009
    I'd call SVS since your in NE ohio and see if they would let you hear one. Their customer support is right up there with polk, both companies easily have the best support I have ever dealt with. Also SVS has a 30 day trial period, so you could get one, and since you probably don't live that from from them, you could just take it back, if it's not what you thought it would be.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • superjunior
    edited July 2009
    anyone know where in ohio svs is? I don't see an address on their site unless I'm overlooking it
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2009
    Girard, OH, it's a suburb of Youngstown. I don't think you can go wrong with that sub, though if you go listen you might end up with something more expensive ;).
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • superjunior
    edited July 2009
    Ron Temple wrote: »
    thank you, sir. That's less than an hour drive from here, but your probably right. I'll walk in to listen to the 12 and walk out with the 13 ultra :eek:
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited July 2009
    Let me know what you end up doing super because you've started a thread that I'm very interested in as well as you already know. Good luck shopping and have fun!
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • superjunior
    edited July 2009
    Rodeo0530 wrote: »
    I was waiting for you to chime in Rodney, how ya been? Not sure what to do yet. I really wanted to keep the sub budget under 5 bills, I was set on the pro600, got the funds, ready to buy, but this little voice in my head keeps saying svs...damn I wish my golf outing wasn't rained out this morning :)
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Rodeo0530
    edited July 2009
    You going to take a little drive over to Youngstown? If I still lived where I grew up it would only be about an hour drive for me to check them out as well. Sorry to hear about the golf outing, but we desperately needed the rain.
    Nintendo Wii
    Not in use-
    Polk Audio PSW10
    Parasound p/sp-1000
  • Ron Temple
    edited July 2009
    If you go, give them a call first. They will open their doors for customers, but it's a small operation and they need some warning.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • danz1906
    danz1906 Posts: 5,144
    edited July 2009
    The Ultra 13 is AWESOME!!!!!!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • superjunior
    edited July 2009
    Rodeo0530 wrote: »
    thinkin about it, but I hate to just rule out the pro 600. I have no intentions on buying the 13 ultra- damn you guys:p - yes we needed the rain, and I shot pretty darn good this morning :)
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited July 2009
    danz1906 wrote: »
    That's why I'm afraid to go there :o
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited July 2009
    Ron Temple wrote: »
    Thanks for the heads up , will do ;)
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • bluextatic
    bluextatic Posts: 5
    edited July 2009
    I love Polk Audio stuff and in fact own an awsome pair of RTi 10' that I've had since new in 05. I desperately needed a sub upgrade in the worst way, since my old and tired Infinity just wasn't cutting the mustard anymore. I researched for months, and decided on a brand new HSU VTF3-MK3. It is a few hundred more than your current budget, but in my opinion, well worth every penny. This monster is a beast, that sounds wonderful on both movies and music.I have never heard of anyone being disappointed with a HSU sub. The model that I have will either hold it's own or blow away any 12 inch sub on the market and will out perform many 15 inch subs costing much more.
    It WILL Rattle your foundation and it is capable of around 18hz.
    You should check out their website at hsuresearch.com and check out Craigs list on subwoofers where he has a terrific reputation and has tested many subwoofers.
    Steve
    harman/kardon AVR 645
    Emotiva X-3
    harman/kardon DVD 31
    harman/kardon DVD 48
    harman/kardon FL8380
    Teac X3 vintage reel to reel
    APC H-15
    Monster HTS 1000 mk II
    Polk Audio RTi 10's Front
    Infinity BETA360 center
    JBL Studio 810's Surround
    Canton Ergo 602's surround
    HSU Research VTF3-MK3 Subwoofer
    Steve
  • mdk5068
    mdk5068 Posts: 204
    edited July 2009
    I own a dswpro 400 which is up for sale now as well as an svs pb12 ultra. I was thinking about the nsd and talked to the svs guy on the phone and he said it would be more than appropriate for my needs. the dsw400 rocked, but I knew it was an 8 inch sub and I wanted a 12 as I upgraded. I only ended up not getting the nsd because this guy offered me the ultra for 700. In my opinion, there is no question in quality between the polk and the svs, svs will dominate every time.
    -Mark
    Bulls make money.
    Bears make money.
    Pigs get slaughtered.
    You, my friend, are the bacon.
  • superjunior
    edited July 2009
    Thanks for everyones comments and suggestions. I think I'm leaning towards the Polk 600 at this point for a few reasons. Cash flow being first concern. The dsw is over 200.00 less and I still need a decent set of ic's and at some point 2 sets of quality surrounds. The a9's put out some good base on their own, but with movies I'm missing out without a good sub. I can always upgrade to a second pro 600 if needed, but I think that might be overkill in my room.
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • jimmydep
    edited July 2009
    Good choice on the Pro 600 I know you'll like it.
    BTW, I got mine on e-bay for less than $350 shipped (with Bing cashback).
    JImmy
  • superjunior
    edited July 2009
    same place I'm getting it- thanks to your previous post jimmy. I'll post results when it arrives :)
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • dekuda
    dekuda Posts: 756
    edited July 2009
    I believe if you decide on a second DSW600 in the future it will not be overkill in a 14x26 room. That is a rather long room. I am a big fan of having 2 good subs instead of one great sub.:D
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • jimmydep
    edited July 2009
    My Pleasure Jr.
    I'm looking forward to hearing what you think of it....
    Jimmy
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2009
    Let us know what you think.
    Thanks!
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • kevhed72
    kevhed72 Posts: 5,142
    edited July 2009
    jimmydep wrote: »
    JImmy
    So you did pull the trigger on the purchase...which seller did you do through?
    If you don't want to post, please PM me with your thoughts on the seller, etc.
    thx
  • jimmydep
    edited July 2009
    kevhed72 wrote: »
    thx
    I bought the DSW PRO-600 on e-bay from: the_e_warehouse for a grand total of $312.00 shipped I had an 8% off coupon from e-bay and 8% Bing Cashback, this was a deal I just couldn't pass up...
    I did check "the_e_warehouse" today and they had none for sale.
    I was very pleased with them, the only gripe is they didn't e-mail me with a tracking number so 3 days after I bought it, I was surprised to see the sub at my door.
    I like the sub and think it was a stellar deal!!!
    Jimmy
  • superjunior
    edited July 2009
    E-WARE HOUSE. didn't have the coupons jimmy had, but got it for 370.00 shipped. Pretty good deal IMO and I'll definatly post results on the transaction and the sub itself. Had to shave a little sub cost to save room for ic's in my audio budget- which is $$$$$$$$$ over what I planned, but I'm lovin it :D
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited July 2009
    thanks for comments and advice to all that chimed in
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
