ICs: AQ vs Kimber vs MIT
Erik Tracy
Erik Tracy Posts: 4,673
edited July 2009 in 2 Channel Audio
Any opinions on how the following ICs would compare up:
* Audioquest Diamondbacks
* Kimber Kable Heros
* MIT AVT-1s
Thanks!
Post edited by Erik Tracy on
    heiney9 Posts: 25,487
    edited July 2009
    MIT all the way.
    I used to hear minor differences in cables until I tried MIT. The AVT1 is a very nice cable.
    You will get answers all over the board because sometimes its simply a "synergy" issue. If you can try all 3 and sell the 2 you prefer less, that's the best way to do it.
  • mantis
    mantis Posts: 17,554
    edited July 2009
    heiney9 wrote: »
    MIT all the way.
    I really like the Kimber Hero's out of the 3 you chosen but the above advise is the way to go. Synergy is where it's at.
    Dan
    Dan
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    I recently converted all my IC's and speaker cables to MIT and I am very happy with the sound. Plus with the sale MIT is having you can find some nice deals for cheap.
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2009
    I am using the Kimber Kable Heros XLR in .5 and 1 meter length. I have no complaints at all with the sound. On the other hand I have no experience with the other models, so they very well might be better, worse, or the same.
  • danz1906
    danz1906 Posts: 5,144
    edited July 2009
    Its between the Kimber Heros and the MIT Avt-1.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Erik Tracy
    edited July 2009
    Thanks for the opinions, guys.
    I've seen some MIT AVT-1s show up on audiogon that are juuusttt inside my budget - I may give those a shot.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited July 2009
    The Heros sound nuetral and open to my ears. Previous to these I used Signal Cable classics. Just for fun, I'm purchasing some DH Labs Air Matrix IC's to do a shoot out.
  • Erik Tracy
    edited July 2009
    Ern Dog wrote: »
    I'd like to read that....pics too or it didn't happen ;)
  • Ern Dog
    edited July 2009
    Erik Tracy wrote: »
    It might be awhile, but I'm half way there. I've got one Matrix between my pre and amp, I just need one more for my cdp to pre. I don't buy anything new anymore, so I'm patiently waiting for one to pop up on the 'Gon.
