Universal remotes?
  • mantis
    mantis Posts: 17,388
    edited October 2008
    There are many remotes on the market. The harmony remotes are ok but I don't perfer them. I perfer the Universal remotes like the mx850 , mx900 , mx950 , mx880 , mx980 , I don't care for the mx300 as I have seen to many battery and screen problems.
    Right now I'm waiting on the mx6000. It has the ability to control over IP , RF and IR. Thats badass. Not many remotes can do all 3. It's base station in the MSC400 is killer combo. Not to mention IP control. I love it. I plan on getting on as soon as they come out.
    Also Lighting control they now have in RF which is way cool. I like the Radio Ra system from Lutron as it's really good but expenisve. Universal now has there own RF control lighting which I can see working very well. I also plan on trying out a few switches and swapping out a few on my current Lutron system for a try.
    Check them out. You may like what you find. If not the Harmony are a good do it yourself remote.
    Dan
  • Sansui
    Sansui Posts: 372
    edited November 2008
    If you want to find out about certain remote controls the link below I found to be not only unbiased but very in depth with it's reviews. That's how I ended up with the one I have.
    http://www.remotecentral.com/
    Hope this helps.
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • ViperZ
    ViperZ Posts: 2,046
    I have Harmony 520 and Harmony 720... Love them. Can't really afford 880, 890, 1000 or 1 :)
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • thsmith
    thsmith Posts: 6,082
    Really enjoying my H1. Works well with PS3 as long as you have a IR to BT adapter.
  • Rivrrat
    Rivrrat Posts: 2,101
    I'm afraid I might need to investigate that remote a bit further. I need to see that the buttons are actually going to be large enough to operate with and that the screen is legible.
    I've always found those remotes to be unreliable, and with a limited ability to learn new components. Those remotes are generally the reason one needs to upgrade to a universal remote in the first place.
    But it is a nice looking remote.
    My equipment sig felt inadequate and deleted itself.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Harmony remotes are great IMO
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • olilugo
    olilugo Posts: 405
    for those of you that own the 880 do you know if you can use regular bateries instead of the lithium batery included with the unit?
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • clubmeister
    clubmeister Posts: 1
    edited June 2009
    Olkie-polkie...
    Just joined. For you and others, the URCMX3000 is obviously a great remote. Very happy w/it. Though I did have to plunge for a new remote control battery a little sooner than expected (!).
    People, this is a good spot: www.batterytex.com
    I looked around -- they have good prices. Got it right away, &tc.
    -CM
  • Marty913
    Marty913 Posts: 760
    edited June 2009
    Well considering that he dug up a 9 month old thread to recommend a 4 year old remote that just may happen to need a battery from his recommended place, I'd say it's an obvious scam.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
