What are your speaker cables?
marvda1
My cables are Straley Reality speaker cables www.realitycables.com
I started a thread asking "what did you replace your Straleys with?" and the answers came back JPS Labs and Harmonic Technology which were both in the $1000+ range. So now as I have the change bug, I am looking for some new speaker cables to try.
I have an internal bi-wire pair of PNF cables on the way, www.pnf audio.com and I will be reviewing a pair of Grover and Audio Art's new sc-5 se cables in the near future.
Marvin
Marvin
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
I have owned so many different kinds of speaker wire. I started out with Monstercable going up to the M1.4s bi wires, then Moved into Transparent Musicwaves , then Kimber 8tc 8tc bi wires , Audioquest CV8's just to name a few. Now I have a few I like to swap out from time to time with a pair of Kimber 4tc , Liberty 14-2 , Audioquest 14-2 , DH labs Silver Sonic's and a really nice pair of Analsys plus Theater 2's which is in my system currently. I use all Audioqest speaker wire for Center and rears but when I run my Kimber 4tc, I also have a center channel wire. Same goes for the Liberty 14-2 and Audioquest 14-2.
I admit I am a wire Idiot, you should see the miles of wire I own. I'm like a addict. I have a problem with it. I love to do speaker wire and IC shootouts.It's like a National past time for me. I have done more then any normal human should.
You can do a search on my wire shoot outs if you would like to read some
DanDan
I using JonBilt speaker cables, 1bi-wire pair and a stereo pair.
Im tri-wiring my Linn speakers. The JonBilt are very Musical with
good detail:D
http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1250394312
http://www.polkaudio.com/forums/showthread.php?t=84140Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I'm using MIT MH Music Hose Shotgun 750 biwires.
Marvin
I didn't look but did you get in on the Audioquest Type 4's that are out for evaluations? If not you'll see it in the 2 channel section on this forum. -
MIT AVt MA and many feet of Goertz Flatwire."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ok, I will be the south side of Club Polk - I use Bliue Jeans Cable - 10 white..... Belden cable - 10 guage.Mains.............Polk LSi15 (Cherry)
Fronts: AQ CV-6/48dbs....couldn't resist the deal on Audiogon.
Sub: AQ Sub-x for movies, AQ Black Thunder IIs for Pure Direct/music
I'm content....for now....:p
Marvin
Thats an Awesome system that you have.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
AQ CV-8's w/72v BP.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I've been using a pair of original Audioquest Midnights (4 conductor, non hyperlitz) for several years, but just replaced them with the Kimber 4TC. The AQ's were so hard to work with but I've never found anything I liked as well. I think the Kimber's will be staying, thank goodness.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I'm using two pairs of coat hangers.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Mapleshade, and I have 5 more in the garage waiting for next week’s HT upgrade.
I love the fact such good sound comes from these cables, and I hope they migrate to the HT.
http://www.mapleshaderecords.com/audioproducts/doublehelixspeakercable.phpLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
MIT Shotgun S2
****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
Projector Epson 8700 UB
BLU-RAY Sony BDP-S1000ES
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Bellari VP 130 Phono Pre
Grant Fidelity Tube DAC-09
Sirius Stiletto 2 -
thanks danz, a lot of research and hiding stuff from the wife:D
marvinAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
marvin
Hiding stuff from the wife-Smart move;)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
extension cords.
Toshiba 62HMX85
Panasonic DMP-BD60
Xbox 360 with HD-DVD
Pioneer VSX-9130-TXH-K
Polk Audio CSiA6
Polk Audio RTi10's
Polk Audio RTi4's
Polk Audio RTi6's
Polk Audio PSW505 -
WireWorld Eclipse 6.0.
I moved to them from the Mapleshade which is a terrific wire! I lost a bit of mid definition but received a needed boost in the bottom. Fair trade off to me.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
I get a headache just trying to keep track of my AVRs, speakers and Amps, sources, etc. Whenever I start thinking about 'cables' as well, I go into an economic/catatonic distress! Where does it end...? Nowhere except in one's wallet...so I try not to think about my cables for 'now'.
Blue Circle BC92 - very underrated wire
I'm currently using Kimber Kable 8TC. I upgraded from Signal Cable Classics. I'm thinking about trying some BiWire DH Labs Q-10's or some MAC cuQ.
Dh Labs T-14 in shotgum config.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
i just bought an internal 8 ft, pair of pnf smphony speaker cable and so far they are starting to sound prett good.
http://www.pnfaudio.com/osc/product_info.php?cPath=13&products_id=49&osCsid=56ihv09c91scnnl2p8pr0p0cg5
i also have in for review a pair of grover huffman speaker cables. so far like what i hear.
http://www.groverhuffman.com/speakercablesAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I am using a set of Tara Labs RSC Air 2 10ft. Best I ever had, crisp, transparent, very very transparent, it likely exposes every flaw there is within the sytem and recordings, honesty down to the last drop.
I also have an extra set for Tara Labs RSC Air 3 8ft for sale, like new condition from a local store liquidation. Please email jyli19@hotmail.com if you're interested. -
10 gauge AudioGenics multi-strand with perlon core
SignalCable Ultra's in both rigs.
My silvers on the highs, and AQ CV4's on lows.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
MIT Shotgun S1's.Michael
NORTH of 60° -
Also got Ben's Silver for my center channel.
i am using vtl white wire ...this wire was custom made for vtl,and almost marketed by vtl in the early 90's .. i got a hold of 30 feet of it in 91.. i made a few pair of interconnects , and a set of speaker cables with it.. it looks like rg11 , feels stiffer though ..inside there are individual wires ..indvidually insulated, two of which are silver .. im not sure but i think its made by cardas...B&K ST-140
VTL 225
VTL 100
Dynaco ST70
AVA preamp
MFA Magus
Audible illus Ls1
Aunt Coreys PB preamp
MG3a's
AR M1
Theta pro basic 2
CAL Tercet
Pioneer cd65
Pioneer 9500&9100 tuners
Nad 440 tuner
Linn Valhalla
