new circuits
ben62670
ben62670 Posts: 15,969
edited June 2009 in DIY, Mods & Tweaks
Well I went to Lowe's today. The wire cost more than the circuit panel with 5 20a breakers. I just ripped my stove out, and yes it is set up for gas, or electric. I stole the power to feed my audio. It is a 3 wire setup which means 2 hots, and a neutral. I will cold water pipe the ground (cleanest, but...). The breaker was bad, but it is a square D so no big deal. I am glad to finally have clean AC for my puter, and audio. I will use it for my air compressor here and there, but not while listening.
Ben
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2009
    If you are going to do it, I say do it right, and run it back to the box. What do you need 4/12 or is it cheaper to do 2 2/12's?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
