new circuits
ben62670
Well I went to Lowe's today. The wire cost more than the circuit panel with 5 20a breakers. I just ripped my stove out, and yes it is set up for gas, or electric. I stole the power to feed my audio. It is a 3 wire setup which means 2 hots, and a neutral. I will cold water pipe the ground (cleanest, but...). The breaker was bad, but it is a square D so no big deal. I am glad to finally have clean AC for my puter, and audio. I will use it for my air compressor here and there, but not while listening.
Ben
Ben
If you are going to do it, I say do it right, and run it back to the box. What do you need 4/12 or is it cheaper to do 2 2/12's?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
