Pre-amp -- Marsh p200t or Audible Illusions Modulus IIc
usp1
usp1 Posts: 207
edited July 2009 in 2 Channel Audio
I am looking at these two pre-amps to pair with a solid state amp (emotiva xpa-2). Anyone have any experience with either of these? The marsh is 4 yrs old while the AI is about 8 yrs old.
Thanks in advance for any advice.
Post edited by usp1 on
  • Face
    Face Posts: 14,340
    edited June 2009
    I'd lean towards the Marsh and away from the Audible Delusions.
    heiney9 Posts: 25,492
    edited June 2009
    Why waste the Marsh on an Emo amp? I'm just saying, the pre will far out class the amp.
  • Systems
    Systems Posts: 14,872
    edited June 2009
    Both are quality pre amps but with one being SS the other tube I would expect them to sound quite different from each other.It's hard to say which will be the best match for your system and taste.
    Edit.Ah I see it's Marsh's Hybrid tube/Fet pre not the pure SS model.
    heiney9 wrote: »
    He need not own a Pass Aleph to reap the benifits of adding a good pre to his system.
    Testing
    Testing
    Testing
    edited June 2009
    GV#27 wrote: »
    Yeah, I know (my lame attempt at late night sarcasm). I'd opt for the Marsh just because I'm more "familiar" with their products. I haven't heard either personally.
  • usp1
    usp1 Posts: 207
    edited June 2009
    I realize that there might be better amps than the emo. My plan is to get the pre and then follow up with a tube power amp. That way I can switch back and forth between the two amps depending on what I am listening to.
    The marsh uses a dual triode tube and the seller indicated that it does chew up tubes. So I am a bit concerned about recurring expense as well.
    (I also saw a Krell HTS 5.1 pre/pro. Would that be a worthwhile choice? I know it is apples and oranges with the Krell being solid-state. There are a host of complaints about how user unfriendly it is for HT but apparently no one faults the sound quality. The DAC in it is also exceptional, even though it is a bit dated.)
    edited June 2009
    usp1 wrote: »
    That doesn't make sense to me. I have a hybrid integrated amp that uses dual triodes for the input and I have no issues.
    I would do some research on the Marsh and see if other people mention that. Perhaps since it's a "single" tube maybe that puts more stress on it. But typically pre-amp tubes should last a very, very long time.
    I'm to lazy to look it up, what tube does the Marsh use?
    There are a lot of very good tube pre-amps to choose from.
  • venomclan
    venomclan Posts: 2,467
    edited June 2009
    usp1 wrote: »
    Make sure that you are familiar with Krell house sound before you pull the trigger. I would say that Krell can be sterile at times. Perhaps mated with a warm sounding tube amp it may work well.
    Venom
  • usp1
    usp1 Posts: 207
    edited June 2009
    For the marsh, I found this from one of the reviewers on audioreviews:
    "Preamp uses an out of production, hot-running tube called 5867, which is only available NOS, with a tube life of very low 1000 hours. "
    That does seem low, does it not?
    edited June 2009
    usp1 wrote: »
    Yep, but there are variations and substituites for the 5867. A typical tube is usually rated at 5000 hrs and 10,000 hours for a military tube of the same type, and should last even longer in a pre-amp (in general)
    Get your search on and find out what else can be used in place of the 5867 tube. I have some websites bookmarked (at home) which have some info when hunting for a sub or equivalent tube. Even shoot Marsh an email or phone call............they should be able to tell you what else you can use or at the very least what to stay away from.
    Edit: Also get a few more opinions before jumping to any conclusions make sure it's not just a couple instances and do you know for a fact the Marsh uses the 5867 or just relying on that persons post?
  • marvda1
    marvda1 Posts: 4,959
    edited June 2009
    i finally found info on what tube the p2000t uses. it uses the 5687 tube not 5867.
    i use this tube in my consonance cyber 800 mono block amps and have had no problems.
    a lot of people consider the tung-sol 5687 to sound the best.
    Puritan PSM156
  • usp1
    usp1 Posts: 207
    edited June 2009
    Thanks marvda1. There seems to be very little online information about what tube is used in this pre. There also seem to be a bunch of rather negative reviews on a'gon about build quality.
    Any other suggestions? (BTW...I did have a Dodd ELP for a while but that there was a slight hiss when I combined with my amp...hence the new search) Looking to spend between 400-600.
  • marvda1
    edited June 2009
    Puritan PSM156
    edited June 2009
    This is a Chinese piece, but I've been so impressed with my Dared MP-5 that this looks to be a really well built design. If I had a need for a tube pre-amp, I would have bought one already. This isn't cheap Chinese built crap.
    http://www.pacificvalve.us/MingDAMC6R.html
    FWIW
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    heiney9 wrote: »
    FWIW
    Seems to be worth the price and more
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Ricardo
    Ricardo Posts: 10,634
    edited June 2009
    I've not heard the Marsh tubed pre, but I owned the P2000B balanced SS and it's a very good sounding and well built preamp. I would think the tubed pre performs well above its price point, and from what I've seen these units are a modder's delight.
    My current pre uses 2 5687 tubes. They are supposed to last a lot more than that. There is not a lot of selection on this tube, but I've found the Philips 5687 WB to be very nice. These are NOS tubes and you can get a pair for around $40 or less.
    SOPA
    SCompRacer Posts: 9,121
    edited June 2009
    The 5687 is a wonderful tube. I prefer the ‘50’s Raytheon in my ModWright pre, and MU6900’s in my digital source. Sylvania GB-5687 Gold’s are another fav of mine.
    Some info about the 5687 (half way down page) and Brendan’s top ten list.
    http://www.tempoelectric.com/tubes.htm
    https://www.tubeworld.com/5687.htm
  • Ricardo
    edited June 2009
    SCompRacer wrote: »
    ....and MU6900’s in my digital source.....
    Bendix MU6900's? I'd love to try a pair of those, but they are reaaaaally hard to find, plus I've seen them go for over $300 :eek:
    SOPA
    edited June 2009
    edited June 2009
    Ricardo wrote: »
    True, but much cheaper than Bendix branded 6900’s.:eek:
    Some folks say you absolutely have to get the Bendix. MU Engineering bought Bendix Redbank Division, rebranded the old stock and continued to manufacture tubes with Bendix tooling. I can’t speak for the entire production run, but the MU6900’s I have and Norm(RIP) had looked and sounded identical to the Bendix. I sold my Bendix and kept the MU’s.
    You could try the 7119’s.
  • usp1
    usp1 Posts: 207
    edited June 2009
    Wow...thats a lot information. Thanks guys. The main user reviews on the marsh 2000t that I saw were at audioreview and a'gon and there were several people with complaints about the build quality (some who replace with the 200b and were surprised by the difference in build quality).
    The sonic frontiers sounds interesting. I will check up on it. I have toyed with the idea of getting some gear from pacific valve but I figure that used is probably a better value.
    edited June 2009
    usp1 wrote: »
    I agree somewhat. PV has some really great prices whne new and the 30day trial and warranty. The problem with most of the Chinese gear is it rarely comes up FS compared to other more popular brands.
    The only other choice is to buy the gear directly from Hong Kong or China w/big shipping fees and a long journey. Since the Chinese gear overall is less costly buying new from PV is nice option.
    I just missed a Ming Da MC-6R pre on Audiogon shipped for $244......killer deal for a very soild tube pre-amp. PV selles them new for $355 plus shipping
  • Systems
    edited June 2009
    That Marsh is about 50/50 good /bad. I checked with several owners and found 50% said it was ok with a few minor issues that could be resolved. And 50% that said they got nowhere in having the pre fixed or replaced. The thing is about 75% said they had issues in the early use of the pre. Go figure.
    Testing
    Testing
    Testing
  • usp1
    usp1 Posts: 207
    edited June 2009
    So it is very likely that the ones that are on the market are very likely to have issues. Its the old lemons rule.
  • Ricardo
    edited July 2009
