Wtb Cs1000p
putski
putski Posts: 4
edited August 2003 in Flea Market
Gents,
I am in search of a CS1000P to replace my existing center. Anybody willing to part with one or know of anyone who might be?
-Putski
Denon 1082
(4) RT55s
CS245 (being replaced)
Post edited by putski on
  • warlocks1
    warlocks1 Posts: 1,284
    edited August 2003
    IMO, you would be better off with the CS400. I have the 1000 and used to have the 400. I like the 1000 a lot, but it really isn't much better than the 400. With your 55's and proper bass management, the 400 will sound perfect with your system. I think there are a couple of 400's on ebay now. Good Luck! Jeff
  • putski
    putski Posts: 4
    edited August 2003
    Warlocks1,
    After buying the CS245 instead of the CS400 a few years ago and regreting it ever since, I wanted to go all out this time. In addition to the CS1000p and CS400, I have also considered the CS350. Opinions?
    -Putski
    VR3 Posts: 29,696
    edited August 2003
    CSi40 with a split output to a pair of RTi38 wired through a SVS PCi 25-w/e. ;)
  • faster100
    faster100 Posts: 6,124
    edited August 2003
    I think having subwoofers in a center is overkill, "UNLESS" you have a very large room and need the extra impact and power.. even then that is why you have a sub and mains.. the cs400 is a HUGE center and i only like 1 speaker as much and that's my csi40 i have owned both, like both..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    VR3 Posts: 29,696
    edited August 2003
    Faster were about to have Identical(sp) systems. Except for the rear center. I might need that...:confused: Will have to see when it is all setup.
  • faster100
    edited August 2003
    Cool, your gonna love it!! I am thinking about the rear center as we speak.. should i get it or not?? that is the question.. as i ponder
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
    VR3 Posts: 29,696
    edited August 2003
    Well, I am going to have weird surround placement. So I might have a gap in the rear soundstage so I may need one. I will have to see also. Can't wait for the RTi70.
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2003
    I have the 400i and the 350. While the 350 looks better, the 400 sounds better.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited August 2003
    Ditto for the 400 (no "i") vs. the 350...
    More later,
    Tour...
    Vox Copuli
  • tortfsr24
    tortfsr24 Posts: 79
    edited August 2003
    I replaced my 350 with the 1000p. It made a HUGE (positive) impact on my system. Movie dialogue was noticibly clearer. I have never spent much time audibly comparing the 400 with the 1000p, so I really can't comment there. However, it seems to come down to a money issue. I got mine for less than $500 from this forum and have been extremely happy with my purchase.
  • Tour2ma
    edited August 2003
    I've little doubt the 1000p can outperform the 400. The issue with the 1000p though is the "p".
    If one sets up his HT with the speakers set to small, the 1000p is a waste.
    On the other hand, at $200 each a pair of 400's would be fairly competitive with the 1000p, at a lower cost.
    More later,
    Tour...
    Vox Copuli
  • brentski
    brentski Posts: 96
    edited August 2003
    I have 55's for my mains as well and used a CS-300 for 2 years until I heard a friends '400'.
    What a difference. Big Time
    The 400 or 400i (same spkrs., different colored drivers) makes all the difference in the world and matches perfectly with the 55's.
    The CS-400, at 32lbs. is a big speaker. (3lbs. shy of the 55)
    As mentioned, the speakers are perfectly matched.
    Both the 55's and the 400 have the same 6 1/2" drivers and 1" Tri-laminate tweeters.
    There's a few on Ebay right now; (no relation)
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3039903080&category=14992-ends at 6:30 P.M.,PST
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3040485510&category=14992
    Count yourself lucky if you can find someone here with one for sale as they're few and far between.
    Center; CS-400i
    Main's; RT-55's
    Side Surround's-RT-35's
    Rear center;CS-300
    Sub; SVS PB12-NSD
  • putski
    putski Posts: 4
    edited August 2003
    Thanks Gents. Currently bidding on CS400. Intrigued by the pair of 400's option. Can anyone teach the electronics illiterate guy how to do such a thing? Appreciate it!
    Putski
  • Tour2ma
    edited August 2003
    brett, I'm think ing that the tweeters are different models as well... yes?
    putski,
    It's be best to have another channel of amplification available to run two 400's, but being as they are 8 ohm two in wired parallel may present a manageable load to your Denon. Consult your manual.
    More later,
    Tour...
    Vox Copuli
  • wallstreet
    edited August 2003
    My old Denon had two outputs for the center channel.
  • brentski
    brentski Posts: 96
    edited August 2003
    a 400i on the board now;
    http://clubpolk.polkaudio.com/forum/showthread.php?threadid=11472
    (no relation) but a real good price, $200 shipped
    Center; CS-400i
    Main's; RT-55's
    Rear center;CS-300
    Sub; SVS PB12-NSD
