Center for RT2000i in HT
dkmuch
dkmuch Posts: 79
edited June 2009 in Speakers
I'm trying to piece together a system from used equipment to get the best bang for my buck.
I realize RT2000i is probably overkill, (I've never even heard a pair), but if I did go that route, would the CS400 or the CS400i be timbre matched?
I've been unable to locate a CS400i used, but I've found a CS400. Or there any others?
How far off timbre would the RTi series be from the RT2000i? It's so confusing, the placement of the 'i' determines a whole different line.
I haven't bought anything yet, I'm just trying to get the most for my money (and more than I really need!).
I'm trying to stick to around $1000K (not including sub), which I will get later. Because I haven't done enough sub research yet.
There are a couple of crazy complete Polk systems for sale for twice that. I almost think I should do it. One is a LSi, the other is RT2000p based.
Thanks!! I've been reading these forums for a long time, every time I consider buying Polk, but never pull the trigger. I finally registered as I am very close to be a Polk owner.
RT55i mains, CS400i center, FX300i surrounds, RTi15 rears, Energy S10.3 Sub, Onkyo 607 / PS3
Post edited by dkmuch on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    I think the 400 and 400i are pretty close. I'm pretty sure they used the same tweeter, but different driver/crossover. If you want to have matching driver color, wait for an i. They are fairly common and usually go for $175-$200. If you don't want to wait, the 400 will likely work very well.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Thanks. How easy would it be to sell the CS400 if I bought it now, and sold when I find a CS400i (although if it crops up a lot, I can just wait).
    Here's a thought I can't get out of my head. There's a complete LSi 5.1 (sans the .1) HT system for $2k, That's twice my budget, but about 70% off new. That just seems like a perfect, long term system I could keep and amortize over a decade. That's only $100 a year extra over my budget! I'll have to explain that part to the wife.
    But I know the RT2000i based-system would probably suit me just as well. And probably do me for a decade as well.
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2009
    Ron Temple wrote: »
    Just FYI, the tweeter is a different model in the 400i vs 400. It would still be a pretty decent match. The 400 is just known to be a little on the brighter side.
  • dane_peterson
    edited June 2009
    All my Polk product knowledge comes from this forum. I am basing it off this thread I had read several months ago:
    http://www.polkaudio.com/forums/showthread.php?t=4580
  • Ron Temple
    edited June 2009
    Nice dig Dane...even so, I doubt the sonic difference between the 400 and i is any bigger than the dingleberries hanging from a gnat's ****.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Argh!, I just found out my Onkyo 607 doesn't have pre-amps out. That means I can't use the RT2000i, right? Isn't the bass self-powered? I may have to get a smaller speaker set-up. I was thinking I could add amps if needed (in the future).
    I just assumed there would be pre-amps. I could take a hit on the restocking fee.
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Well, I guess according to page 19 of my Onkyo 607 manual, I can bi-amp the the FR/FL, If I'm happy with 5.1, which I am probably am (esp with RT2000i's in front). But I'd have to bypass the RT's amp. Perhaps I should look elsewhere. I guess I'm a lower-end polk guy after all. Serves me right for picking the 607.
  • dpowell
    dpowell Posts: 3,081
    edited June 2009
    You can still use the RT2000's without pre-outs on your amp since the 2000's can be configured both ways. The bass isn't quite as clean when using speaker-level inputs vs line level. They are nice sounding speakers. That's the set I started with.
    +1 on the CS400. Great center channel.
    For the LSi's, if you don't have pre-outs to add a separate 4Ohm amp, you'll not be able to take full advantage of them. They are power hungry.
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Kex wrote: »
    You won't have a problem. You can do more research with these links:
    Product page: http://www.polkaudio.com/homeaudio/products/recent/rt2000i/
    Manual: http://www.polkaudio.com/downloads/manuals/home/RT1000i_2000iManual.pdf
    If you have a subwoofer, you will be connecting the RT2000i with a standard speaker connection, and AC power. If you do not have a subwoofer, you will be connecting the RT2000i with the LFE pre-out, which the Onkyo will have (and of course, AC power).
    You will not, however, be able to add an external amplifier, if you wish to do so later, without pre-outs.
    That's what I thought at first, when i did a google search, it turned up quite a few post at other forums saying you couldn't w/o pre-amp outs.
    I guess that's why you should only ask polk questions in a polk forum.
    Thanks!
