Center for RT2000i in HT
dkmuch
dkmuch Posts: 79
edited June 2009 in Speakers
I'm trying to piece together a system from used equipment to get the best bang for my buck.
I realize RT2000i is probably overkill, (I've never even heard a pair), but if I did go that route, would the CS400 or the CS400i be timbre matched?
I've been unable to locate a CS400i used, but I've found a CS400. Or there any others?
How far off timbre would the RTi series be from the RT2000i? It's so confusing, the placement of the 'i' determines a whole different line.
I haven't bought anything yet, I'm just trying to get the most for my money (and more than I really need!).
I'm trying to stick to around $1000K (not including sub), which I will get later. Because I haven't done enough sub research yet.
There are a couple of crazy complete Polk systems for sale for twice that. I almost think I should do it. One is a LSi, the other is RT2000p based.
Thanks!! I've been reading these forums for a long time, every time I consider buying Polk, but never pull the trigger. I finally registered as I am very close to be a Polk owner.
RT55i mains, CS400i center, FX300i surrounds, RTi15 rears, Energy S10.3 Sub, Onkyo 607 / PS3
Post edited by dkmuch on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    I think the 400 and 400i are pretty close. I'm pretty sure they used the same tweeter, but different driver/crossover. If you want to have matching driver color, wait for an i. They are fairly common and usually go for $175-$200. If you don't want to wait, the 400 will likely work very well.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Unknown
    edited June 2009
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Thanks. How easy would it be to sell the CS400 if I bought it now, and sold when I find a CS400i (although if it crops up a lot, I can just wait).
    Here's a thought I can't get out of my head. There's a complete LSi 5.1 (sans the .1) HT system for $2k, That's twice my budget, but about 70% off new. That just seems like a perfect, long term system I could keep and amortize over a decade. That's only $100 a year extra over my budget! I'll have to explain that part to the wife.
    But I know the RT2000i based-system would probably suit me just as well. And probably do me for a decade as well.
  • Unknown
    edited June 2009
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2009
    Ron Temple wrote: »
    Just FYI, the tweeter is a different model in the 400i vs 400. It would still be a pretty decent match. The 400 is just known to be a little on the brighter side.
  • Unknown
    edited June 2009
  • dane_peterson
    edited June 2009
    All my Polk product knowledge comes from this forum. I am basing it off this thread I had read several months ago:
    http://www.polkaudio.com/forums/showthread.php?t=4580
  • Ron Temple
    edited June 2009
    Nice dig Dane...even so, I doubt the sonic difference between the 400 and i is any bigger than the dingleberries hanging from a gnat's ****.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Argh!, I just found out my Onkyo 607 doesn't have pre-amps out. That means I can't use the RT2000i, right? Isn't the bass self-powered? I may have to get a smaller speaker set-up. I was thinking I could add amps if needed (in the future).
    I just assumed there would be pre-amps. I could take a hit on the restocking fee.
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Well, I guess according to page 19 of my Onkyo 607 manual, I can bi-amp the the FR/FL, If I'm happy with 5.1, which I am probably am (esp with RT2000i's in front). But I'd have to bypass the RT's amp. Perhaps I should look elsewhere. I guess I'm a lower-end polk guy after all. Serves me right for picking the 607.
  • Unknown
    edited June 2009
  • Unknown
    edited June 2009
  • dpowell
    dpowell Posts: 3,068
    edited June 2009
    You can still use the RT2000's without pre-outs on your amp since the 2000's can be configured both ways. The bass isn't quite as clean when using speaker-level inputs vs line level. They are nice sounding speakers. That's the set I started with.
    +1 on the CS400. Great center channel.
    For the LSi's, if you don't have pre-outs to add a separate 4Ohm amp, you'll not be able to take full advantage of them. They are power hungry.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • dkmuch
    dkmuch Posts: 79
    edited June 2009
    Kex wrote: »
    You won't have a problem. You can do more research with these links:
    Product page: http://www.polkaudio.com/homeaudio/products/recent/rt2000i/
    Manual: http://www.polkaudio.com/downloads/manuals/home/RT1000i_2000iManual.pdf
    If you have a subwoofer, you will be connecting the RT2000i with a standard speaker connection, and AC power. If you do not have a subwoofer, you will be connecting the RT2000i with the LFE pre-out, which the Onkyo will have (and of course, AC power).
    You will not, however, be able to add an external amplifier, if you wish to do so later, without pre-outs.
    That's what I thought at first, when i did a google search, it turned up quite a few post at other forums saying you couldn't w/o pre-amp outs.
    I guess that's why you should only ask polk questions in a polk forum.
    Thanks!
