LSi Serie: Why does set my speakers to Large (or Small) when I know they are not?
Bernal
Bernal Posts: 991
edited February 2012 in Speakers
This is a decision: should be made using 40 Hz as the roll- off frequency. That is to say, if a speaker is found to roll-off below 40 Hz it should be called Large and all other speakers should be called Small.
My Question:
1) LSi Serie PolkAudio on this budget is large or small.
2) LSi Serie PolkAudio: is a speaker is found to roll-off below 40
Hz
Br
Post edited by Bernal on
  • Bernal
    Bernal Posts: 991
    edited June 2009
    Kex wrote: »
    LSi7, LSi9, LSi15 or LSi25? What receiver or pre are you using for the calibration?
    HT: 5.1
    Pre:
    DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    Amp:
    SUNFIRE Grand Signature
    Speaker:
    LSiC (Center speaker)
    LSi15 LEFT (Front speaker)
    LSi15 RIGHT (Front speaker)
    LSif/x LEFT (Surround speaker)
    LSif/x RIGHT (Surround speaker)
    VELODYNE OPTIMUN SERIES (High Output Digital EQ SubWoofer 2400W/1200WRMS)
  • PSOVLSK
    PSOVLSK Posts: 5,372
    edited June 2009
    I'd set all speakers to small and crossover at 60 or 80, whichever you prefer.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2009
    Play with it, see what you like. I wouldn't waste the low end response on the 15's with anything set higher than 40Hz.....
    Cheers,
    Russ
  • Bernal
    Bernal Posts: 991
    edited June 2009
    RuSsMaN wrote: »
    Cheers,
    Russ
    Kex wrote: »
    I agree with RuSsMaN. 40Hz is likely to be the right setting. Try also 60Hz and you should know which of the two you prefer almost instantly, especially if the Denon allows you to change the setting "on the fly" without stopping the music (put a decent CD that you know well and like in the player). You should notice much more musical and controlled bass IMO at 40Hz, and the subwoofer can dedicate itself to doing what it does best.
    It's not surprising that Audyssey calibrated these as large, given their lower 3dB limit. You might even want to try leaving them that way for music listening IMO, if the Denon allows you to memorize different settings that can be easily accessed from the remote (use the small setting for movies, and the large setting for certain types of music). If you do decide you prefer the large setting for music, then you'll have to determine if you think the subwoofer is helping or not for music listening (some people just prefer certain types of music without a subwoofer, as long as the speakers can get close enough to 30Hz ... or lower).
    Hello.
    To better understand:
    1 .- The recommendation for all speakers is small.
    2 .- Set all speakers at 40Hz for music.
    3 .- Set all speakers for movies at 60HZ.
    4 .- 60 or 80Hz Subwoofer?
    5 .- Why choose Denon Audyssey MultEQ XT speaker: small 60/100HZ?
    This graph can also:
    Music:
    Large Setting:
    LSiC (Center speaker) = 40HZ
    LSi15 LEFT (Front speaker) = 40 HZ
    LSi15 RIGHT (Front speaker) = 40 Hz
    LSif/x LEFT (Surround speaker) = 40 HZ
    LSif/x RIGHT (Surround speaker) = 40 Hz
    VELODYNE OPTIMUN SERIES = 60HZ
    Movie:
    Small Setting:
    LSiC (Center speaker) = 60HZ
    LSi15 LEFT (Front speaker) = 60 HZ
    LSi15 RIGHT (Front speaker) = 60 Hz
    LSif/x LEFT (Surround speaker) = 60 HZ
    LSif/x RIGHT (Surround speaker) = 60 Hz
    VELODYNE OPTIMUN SERIES = 80HZ
    Denon Audyssey MultEQ XT Auto-Setup/Room EQ: speaker configuration set as:
    Small Setting:
    LSiC (Center speaker) = 100HZ
    LSif/x LEFT (Surround speaker) = 100 HZ
    LSif/x RIGHT (Surround speaker) = 100 Hz
  • Bernal
    Bernal Posts: 991
    edited June 2009
    Hi,
    If I miss something please tell me.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2009
    Set all your speakers to large, sub = no, and run the sub off the front pre-amp output. Works fine for me with 4 LSi15s, 1 LSiC, and a PSW1000 sub. If you do not like it then put them back the way they were.
    tonyb Posts: 33,068
    edited June 2009
    Ok,here's a question I can never get answered.........
    Why spend the money on floorstanders and then set them to small ?
    Anyone care to take a shot at this ?
  • pearsall001
    pearsall001 Posts: 5,248
    edited June 2009
    tonyb wrote: »
    Generally speaking just because it's a FS doesn't mean it can produce full range. Odds are it's not even close. A FS is designed as a jack of all trades, master of none. Pretty much like a receiver...everything crammed into one box. Something has to give.
    By setting them to small you relieve them of struggling to produce what they can't. Now the mids will open up & sound as sweet as honey & let the sub handle what it's designed for...the low end.
    Also I'll bet that where the FS are placed in the room is the absolute worst location for bass performance. Now you have a speaker trying to do it all in a bad location. Now this doesn't mean that the mighty FS can't sound good, because they sure can. They'll just sound a lot better having to do less.
    I was always a FS guy until I discovered what a pair of great monitors paired with dual subs can sound like. Dynamite!!! No more FS here.
  • Bernal
    Bernal Posts: 991
    edited June 2009
    tonyb wrote: »
    "...Receivers and preamp/processors typically have two settings for your speakers: "small" and "large." You need to get past what these words actually mean in English, as they are a very poor choice for this feature of a processor. This setting actually has nothing to do with the size of the speakers, and everything to do with the range of the speakers. This setting determines when low frequencies are diverted from your front speakers and into your subwoofer (the crossover frequency). In other words, it has a tremendous effect on the bass you'll hear in movie soundtracks...." (published by O'Reilly Media, Inc)
  • Bernal
    Bernal Posts: 991
    edited June 2009
    BlueFox wrote: »
    Hi,
    Set speakers; large at 60Hz. OK.
    Connected to the subwoofer pre-out of the main speakers. Ok.
    The pre-out of the main speakers connected to the amplifier.
    As I do?:confused: Explain in a graph.
    Thank you
    tonyb Posts: 33,068
    edited June 2009
    I imagine more than a few can subscibe to this,but then the question remains,why spend the coin on floorstanders when you don't utilize the whole speaker? As you say,why not go the monitor/sub route?To me,if your going the floorstander way,then buy a full range FS and not a full range wannabe.I guess I don't see the logic in it is all,kinda like buying SACD player and only playing redbook on it.To each his own I guess,just my .02.
  • Bernal
    Bernal Posts: 991
    edited June 2009
    tonyb wrote: »
    Interesting, but if it exists?
    Why? For example LSi 9 versus LSi15. Personally, I think the LSi15 as an "extension" of the magnificent LSi 9 to which was added a third way to lower frecuencias.Con want it to say that the LSi 15 in its upper part is almost identical to his sister lower LSI 9 but for the home sections LSi 15 for middle and high frequencies, while low is dedicated to the rest of the cabinet. This can not do the LSi 9. The record is seriously powerful, forceful and often descends into more than you would expect from an eight-inch woofer
  • pearsall001
    edited June 2009
    Here's a great article on the subject. Nothing etched in concrete, but I found the principles to be sound. I think the problem most have is the mind set that their FS speakers are really full range, truth is that unless you've spent mega $$$$ & the speakers themselves are huge, they're not close to being full range. Marketing hype & phony specs reares it's ugly head on this one. That word "Fullrange" is tossed around as loosely as "Reference" in the audio world.
    http://forum.ecoustics.com/bbs/messages/34579/128214.html
  • Bernal
    Bernal Posts: 991
    edited June 2009
    Kex wrote: »
    ...Concering Bernal and the LSi15 he is using, with a lower -3dB limit of 30Hz, and an overall response down to 22Hz, it certainly would seem like a waste to me to set the crossover as high as 60Hz or 80Hz, but I suppose that does depend on his subwoofer and his own personal tastes ... and most of us would agree that specifications printed on paper can never tell the whole story. As I suggested earlier: making the switch "on the fly", with music playing, I would know almost instantly which I preferred.
    Based on my Denon 4308Ci system means that you can configure the LSI 15 to 40Hz? Ok. And the subwoofer configure ... HZ? You can target a little more.
  • Bernal
    Bernal Posts: 991
    edited June 2009
    Good article.
    Thank you.
  • Bernal
    Bernal Posts: 991
    edited June 2009
    Good article.
    Thank you.:rolleyes:
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2009
    Hi Tony. Phil really is right on the money with this. Whether BS or FS the drivers can only go so low. and when they are struggling to play the really low stuff, the mid range which the drivers handle really well suffers in the process. Becoming strained & muddy sounding.
    Once you put a sub into the works & let it do its job the mid range from the speakers becomes much more crisp, clear & clean.
    So for the most part the recommendation to set all speakers to small & crossover @ 80hz works really well.
    tonyb wrote: »
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    If your main speakers have the same or more volume and impact at the deepest bass frequencies your subwoofer can hit - you should set them to large while you save for a better subwoofer.
  • Bernal
    Bernal Posts: 991
    edited June 2009
    McLoki wrote: »
    Hello.
    His advice applies to this setting?
  • Bernal
    Bernal Posts: 991
    edited June 2009
    My Question: :confused:
    Hz
    Br
    Bernal wrote: »
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    Bernal wrote: »
    Hello.
    Yes - in my opinon - if you have a decent subwoofer, you should set all speakers to small. The crossover depends on the capability of the speaker, subwoofer and room you are in.
    I have two good subwoofers, and a bad room for bass. Based on that I have all speakers set to small with an 80hz crossover. (should probably be 100 in my room, but oh well....)
    If I had a better room (and a pre/pro that does not truncate the LFE channel to the same crossover setting as the mains) I would cross over the fronts and center at 60hz and my LSi7's at 80hz. (if I had LSiFX - they would cross over at 60hz as well)
    The thing to remember is a crossover is not a brick wall. The speaker will still be asked to play below the crossover level. If you set the crossover frequency at the lower limits of your speakers, it will not be able to play hardly at all below the crossover level and blending the sound to the subwoofer will become very hard.
    With your speakers, you can set them to anything you would like, but that is how I set mine and why I do it.
    Michael
  • McLoki
    McLoki Posts: 5,231
    edited June 2009
    Bernal wrote: »
    Hz
    Br
    1) yes
    2) yes, but not really the most important for this discussion. A better question would be - Above what level is the bass from the LSi series better than the bass you get from your subwoofer?
    That will give you the answer for large or small and what the crossover frequency should be.
  • Bernal
    Bernal Posts: 991
    edited June 2009
    McLoki wrote: »
    1) yes
    Thanks for the info.
  • Conradicles
    Conradicles Posts: 6,335
