Sda srs 1.2
szhleppy
szhleppy Posts: 325
edited February 2010 in For Sale (FS) Classifieds
$1000 for the pair. Local pickup (located in Chandler) preferred. I'll consider delivery/meeting on an individual situation basis if necessary. Any shipment would be on you...the most I would do is deliver them "as is" to a local facility that would sign to verify they are in the described condition at that point.
I'm definitely not the 1st/only owner of these...but they're in great shape. These are not the TL version.
  • Cabinet 8/10
  • Fabric 7/10
  • Face 8/10
  • Speakers 8/10
These speakers have not had any upgrades/modifications. The SDA interconnect is included. The individual speakers each look excellent...none are "pushed in" and each works, the crossovers don't have any scratches, the fabric doesn't appear to have any snags...just a few marks that could probably be removed with a little extra TLC. The only flaw worth mentioning is the back panel of each speaker has scratches consistent with being moved without a blanket put down first.
I purchased these via drunken text about 2 years ago with Wes's help, then proceeded to forgot about them. They ended up in Bill's hands who graciously delivered them about 9 months ago. Since then I've had them hooked up and thoroughly enjoyed them, but not enough to consider moving with them. I'm not going anywhere in the next couple of weeks, but will probably be moving in the next few months and would like to get these into someone else's hands now before it becomes a last minute thought. Although I don't frequent this forum any longer, I've had great transactions, conversations, and meetings with many of the members here...therefore, I'd rather see these stay "in the family."
Let me know what you think and if you have any questions. Thanks!
Post edited by szhleppy on
    nooshinjohn Posts: 25,890
    edited June 2009
    how does one tell the difference between the original SRS, the 1.2's and the TL's?
    If they are 1.2's how difficult would it be to bring them to TL spec?
    If they can be brought up to TL spec, please place me on the interested list.
  • szhleppy
    szhleppy Posts: 325
    edited June 2009
    Toolfan66 Posts: 17,995
    edited June 2009
    About $300 to $500 for crossover upgrade, and $400 for the RDO198's
    Yes they can be brought up to TL upgrade, This is what i am doing with mine now.
  • zarrdoss
    zarrdoss Posts: 2,562
    edited June 2009
    the tl's have sl 3000 tweeters not sure on the original srs and 1.2
    ask TOOLFORLIFEFAN bout the tl upgrade as he is doing that very thing with his I believe
  • zarrdoss
    edited June 2009
    damn your fast Larry!
    edited June 2009
    After looking at the pics, are you sure they are the 1.2's? The crossover cover plate looks like the original SRS's, but i do know Polk is good at using the parts that are there to get the job done.
    edited June 2009
    I have pm'd him looking for a closeup of the serial number tags. if they are 1.2s I will take them if I can work out how to get them to Indiana
    edited June 2009
    the tag on one of them reads sda srs 2518, so they must be SRS and not 1.2's
  • szhleppy
    szhleppy Posts: 325
    edited June 2009
    Must be SRS, not 1.2's if you say so. I'm not an SDA expert and thought the 1.2 designated this size...
    edited June 2009
    is the cost to upgrade srs the same as 1.2's? can it even be done?
    edited June 2009
    With that serial # My money says they are the 1.2's
    edited June 2009
    how else would you know or go about finding out?
    edited June 2009
    Can you pull a driver and tweeter and look on the back of them? also Sal asked if they are PIN/BLADE or BLADE/BLADE can you let us know?
    This will give you your answer's
    edited June 2009
    From my understanding it cannot be done.
  • szhleppy
    szhleppy Posts: 325
    edited June 2009
    Blade/Blade
    edited June 2009
    so to check understanding... srs to TL, not possible...1.2 to 1.2tl, possible?
    edited June 2009
    Correct!!! These are the SDA SRS originals
    edited June 2009
    I am out on these. If they were 1.2's and I could upgrade to TL's, I would be all over them
    edited June 2009
    Sal was right on the money checking the P/B B/B .
  • szhleppy
    szhleppy Posts: 325
    edited June 2009
    F1nut Posts: 51,699
    edited June 2009
    Those are definitely SDA SRS's and priced accordingly. No, they can not be upgraded to 1.2 or 1.2TL statis.
  • xj4094dg
    xj4094dg Posts: 1,158
    edited June 2009
    In the interest of learning more about SDA's (for us newbies out there), why can't they be upgraded. Sorry in advance for the stupid question.
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
    edited June 2009
    because F1 and ToolForLife say so... geez:D
    F1nut Posts: 51,699
    edited June 2009
    I don't want to muck up the OP's thread, PM sent.
  • snow
    snow Posts: 4,358
    edited June 2009
    xj4094dg wrote: »
    The internal cabinent structure is different along with the crossovers, mid drivers and tweeters.
    $1000.00 is a very good price for these though and some members actually prefer the sound of the original SDA SRS and I believe if my memory serves me correctly that these actually play a little bit lower in the Bass department then the 1.2TL's.
    REGARDS SNOW
  • bluecomet
    bluecomet Posts: 1,118
    edited June 2009
    Basically the only upgrade you can do is change out the tweeters to RDO 194's on a SDA SRS. Is that correct?
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    eh,, you might want to upgrade the caps and resistors in the crossover,, pop in some RDO,, then pay attention to your source and downstream components--good luck,,and enjoy. :)
  • Deadof_knight
    Deadof_knight Posts: 980
    srs and tls there's a slight cabinet structure difference internally correct?
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • bluecomet
    I have two sets of 1.2tl's. One I plan on modding the crossovers and going the RDO 198 route. I have a set of 1.2's and they are very similar sounding to the original SRS speakers I used to own. The thing about the 1.2's is that they are easier to drive being 6 ohm speakers. If I had to pick between the original SRS and 1.2's, I would take the 1.2's and yes they do seem to have a deeper bass sound to them than the 1.2tl's. They cannot beat the 1.2tl's in the mid's or highs in my opinion. All of the SRS big boys are great in there own right.
  • Cramer1
    Cramer1 Posts: 72
    Hello,
    I was wondering if you still have this pair of speakers for sale, if you do please contact me @ cjglke@bis.midco.net.
    Thanks in advance!!
