2.3 TL's instead of 1.2 TL's
michaeljhsda2
michaeljhsda2 Posts: 2,207
edited June 2009 in The Clubhouse
I'm going to sell my 1.2TL's if I ever find a pair of 2.3TL's...is this a crazy/dumb/smart/stupid,etc....idea? Thoughts please.
_________________________________________________________
Mike
SDA SRS 2.3TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    I would think that it would depend on room size,components and what you are trying to accomplish,me,, I have a smaller room,,tubed amplification,50 watts+/-,,so my 1C's are perfect for my application. Good luck.
  • michaeljhsda2
    edited June 2009
    George, my room size is good for the 1.2's, however, I like the idea of the tweeters being more at ear level on the 2.3's..or maybe I should just raise the couch :)
    SDA SRS 2.3TL's
    SDA 2B TL's
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    I sit on a phone book when listening to my 1.2TLs.
  • michaeljhsda2
    edited June 2009
    I'll try that but doesn't your arse get sore?
    SDA SRS 2.3TL's
    SDA 2B TL's
    edited June 2009
    Must be the phone book with all pizza joints in it.:):p
  • hearingimpared
    edited June 2009
    No it actually sinks into the couch but raises my ear level to the second from the bottom tweeter.
  • hearingimpared
    edited June 2009
    tonyb wrote: »
    . . . and Italian resturants.
  • engtaz
    engtaz Posts: 7,674
    edited June 2009
    I don't think it a good idea. You have the cream of SDA crop and you want to go down??????
    engtaz
  • Face
    Face Posts: 14,340
    edited June 2009
    engtaz wrote: »
    Cream of the crop is a matter of opinion. Some do prefer the smaller SDA's.
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited June 2009
    Face wrote: »
    That's right. I've never had the pleasure of hearing a pair of 2.3's, but there seems to be a good many of those who prefer them to the biggest ones.
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
  • ben62670
    ben62670 Posts: 15,969
    edited June 2009
    I like the fact that most of the music come from one of the tweeters. Just as an experiment play a test tone around 3.5k and move around the room. It will very a lot. All speakers will do this a bit, but the 2.3TL's have one of the better tweeter setups.
    Ben
    Ben
  • madmax
    madmax Posts: 12,434
    edited June 2009
    I had both models in the same room for awhile and different music sounded best on different models. I tended to like the 1.2's better overall for covering a larger group of genres. The 2.3's were heavier on bass and better in attack on some recordings.
    madmax
    Vinyl, the final frontier...
  • ben62670
    edited June 2009
    MM TL's on both models? Which did you feel had a better sound stage, and why. Ame location and gear ny any chance?
    Thanks much.
    Ben
    Ben
  • madmax
    edited June 2009
    Non TL's, both models had tweeter upgrade. At that time I had just got my 200w manley monoblocks and preamp which sounded suprisingly like the soundcraftsmen 380wpc amp I had lived with for quite some time. It took a while to really appreciate the new sounds from the manleys, pretty much when I later switched back to the SC for comparison. Source was a theta cd transport and audio note dac.
    They both had a great soundstage and live sound on great recordings. The 1.2's allowed a lot more enjoyment of poorer recordings while retaining the glory when playing great recordings. The 2.3's allowed a slightly more powerful performance of modern rock, mostly because of more perceived bass. The SDA sound was a little more pronounced on the 1.2's but this is very room dependent. Either speaker is awesome.
    madmax
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited June 2009
    I sold my 1.2TL's and kept my 2.3TL's. Never looked back.
  • ChrisD
    ChrisD Posts: 101
    edited June 2009
    2.3TL and SDA 1Cs seem like better speakers than the 1.2TLs because of the lower tweeters.
  • hearingimpared
    edited June 2009
    ChrisD wrote: »
    The only difference that I notice between the 2.3TL and 1.2TL tweeter placement is that the stage on which the performers are standing/sitting is higher up with the 1.2TLs. It is as if you are at a concert and are looking up at the stage. I wouldn't say it is better or worse than than the 2.3TLs or 1Cs.
  • Emlyn
    Emlyn Posts: 4,888
    edited June 2009
    For what it's worth, you could sell the 1.2TL's and buy a pair of 2.3TL's and have several hundred dollars to put towards something else. All while not losing much if anything in sound quality. Like Max says above, different music sounds better on different SDA's. They are also very room dependent. I think the 2.3TL's are the best all around of the SDA's for where I have mine set up. I would suggest buying the 2.3TL's before you sell your 1.2TL's though, that way you can decide which work best for you.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited June 2009
    I have 2.3TL and SRS 2. The imaging is very room dependent. In a smaller room, the SRS 2 sounds better than the 2.3TL. I think you will have similar differences in the 1.2 and 2.3. The 2.3TL is as big as I will ever need. I can throw two TFM-55s at them and they laugh at me. They are not leaving.
  • BrettT1
    BrettT1 Posts: 560
    edited June 2009
    I've never heard the 2.3tls. With that said, I'll Never sell my 1.2tls.;)
  • warlocks1
    warlocks1 Posts: 1,284
    edited June 2009
    I owned the non TL 2.3's before the 1.2TL's. The 1.2 seem to better fill up the room and have a stronger SDA effect in my basement. The 1.2's also have better base in my room. My basement is 30X24. I woudn't trade my 1.2's for 2.3's.
    Has anyone tried tilting SDA's slightly forward? I haven't tried on my 1.2's, but works wonders on my Martin Logans.
  • michaeljhsda2
    edited June 2009
    "Has anyone tried tilting SDA's slightly forward?"
    I'm going to do that later on today.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    edited June 2009
    Success! :D I increased the height of the rear spikes so that now the soundstage is where I feel it should be. The speakers are not in danger of falling over as they are not pitched that far forward. I used the bass braces to anchor them to the rear wall.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • nikolas812
    nikolas812 Posts: 2,915
    edited June 2009
    I tilted mine forward today also...
    I like what I am hearing but they look like there going to fall over.:eek: There not. But they sure like it..
    Nick
