What to do?
bigaudiofanatic
So my neighbor and I have been wathing start wars episode 1 and was going very smothly until we get to the pod racing scene. That scene basicly was making the LSi 25 subs POP and distort a bit. He has the lsi 25's a onkyo 3 room reciver 2 direct tv recivers a blu ray player and a sony lcd 47 inch tv all pluged in to the wall via power strip. Also has in the same room and on the same braker the celing fan and the lights as well. So what can we do to get them to stop POPING at that scene is it just to little power getting to them or is it the gains need to be set a little lower. Everything else including music movies and shows sounds great but it is that scene. So what to do?
On a side not the gains on them are set at there "normal setting"
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
I am guessing that you really need a subsonic filter.... It is just trying to reproduce bass that is to deep for the LSi25 to deal with. best suggestion would be to get a subwoofer and crossover the LSi25's at 60hz or so.....Mains.............Polk LSi15 (Cherry)
Well he rely dose not want to get another sub in the room there rely is not room for it. So he will probably will just have to set the cut off and not have that rely low bass.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
What frequency's are in that scene?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I found out the lowest is 14 hzHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
The speakers were even poping during the movie stealth today. The knobs on the rear of the speakers were set at 80hz what else should we try?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
The knobs on the speakers are where they cut over to the powered 10" speaker.
one thing you could try (just to see if this is the issue) is set your speaker to small with a 40hz crossover in your avr.Mains.............Polk LSi15 (Cherry)
It still is doing it on things like tokyo drift and even polar express the Frequency is set to factory and the volume is set for a little more than half. Also in setup the bass is at the lowest it is at -15 db and if you go to THX there is less bass than if it is dolby but dose not sound as good.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
His receiver probably cant handle the 4 ohm load."They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
But would that effect the powered bass portion of the speakers?
If they were unpowered I'd point to this but I believe the LSi25s are powered subwoofer sections, right?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Correct they are poweredHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Well in my experience once you "pop" a speaker a few times it becomes weak or damaged and it will "pop" more often and at lower levels. The damage may already be done.
P.s. what speakers are popping? Woofers or mids?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Push all of the mid range drivers and the bass drivers in a couple of times with the rig powered down [being careful not to touch the dust caps]. Do they all bounce back with smooth precision or can you feel some sort of an obstruction?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
See if any of the drivers (with cones) scratch. If you feel scratching while pushing it directly in, that can mean the voice coil is blown. The scratching is the coil scraping.Main Surround -
I have connect my system to my pc and whenever it start window before the "starting" music kicks in there a "Plug" sound happen to all my speakers. What is that? It happens every time when I start window.
Please educate me what is the "Poping" you guys talking about for the speakers which you all mention that will damage the speakers? What does that sound like is that what happening to me? -
The "Plug" sound is just your computer initializing the sound card more than likely. Usually this is the fault of a poorly designed sound card that does not have a soft-on to prevent sending noise through on power up and power down.
I would wait until the computer is on an fully operational prior to powering on the speakers/amp to prevent this.Main Surround -
Agreed - after the computer starts up, turn on your amp - mine does this as well......... -
thanks guys, So that "plug" sound is different than the pop sound you all mention in the previous reply? So then what is a speaker pop sound like? And what is clipping too? How does that sound like?
I still need to find out why it is doing this going to check the woofers now.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Just checked them they go in and out very smoothly no resistance at all.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
More likely a problem with the receiver than the speakers"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
bigaudiofanatic wrote: »So my neighbor and I have been wathing start wars episode 1 and was going very smothly until we get to the pod racing scene. That scene basicly was making the LSi 25 subs POP and distort a bit. He has the lsi 25's a onkyo 3 room reciver 2 direct tv recivers a blu ray player and a sony lcd 47 inch tv all pluged in to the wall via power strip. Also has in the same room and on the same braker the celing fan and the lights as well. So what can we do to get them to stop POPING at that scene is it just to little power getting to them or is it the gains need to be set a little lower. Everything else including music movies and shows sounds great but it is that scene. So what to do?
simple solution.. quit watching the pod racer scene.. problem solved.
thanks everyone, I'll be here all night.
PolkFest 2012, who's going>?
Well the pop and distortion is constant during the scene, and during operation.
The pop from your computer is only on startup and not during operation, right?Main Surround -
LSi25 aren't going to hit 14hz. The volume is too high, the woofers are bottoming out and simply being overdriven....back off the volume.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
But I mean it is even doing ti while watching the polar express and Tokyo Drift. So should I cut back the volume on the towers or cut the frequency on the towers.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
yes it just start up only.
But I am just wondering the pop you all mention about during the movie, is it the same pop that when I start the window? -
bigaudiofanatic wrote: »But I mean it is even doing ti while watching the polar express and Tokyo Drift. So should I cut back the volume on the towers or cut the frequency on the towers.
Can the Lsi be defective? -
Both. If it has happened too many times already, you may have compromised the drivers. Keep it up and you may compromise the amp as well.bigaudiofanatic wrote: »But I mean it is even doing ti while watching the polar express and Tokyo Drift. So should I cut back the volume on the towers or cut the frequency on the towers.
Your goal? Never to hear that sound again.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
You're only going to get so much out of a 10" side firing woofer in a small enclosure and a 150 watt plate amp."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
No.
One is distortion, one is just a startup signal coming from your pc. Totally different.Main Surround -
When your questions are answered, and you are listening to your system, you will be unhappy.
