Lord Vadar
rubin
rubin Posts: 565
edited June 2009 in 2 Channel Audio
I will destroy U with my mega-watt stereo!!!!!!!!!!!!!!!!!
Post edited by rubin on
  • Conradicles
    Conradicles Posts: 6,372
    edited June 2009
  • Lord Vader
    Lord Vader Posts: 167
    edited June 2009
    rubin wrote: »
    Am I to assume that you are foolish enough to call ME OUT? I do not need the power of STEREO to destroy you, for I have the power of the Dark Side as my ally.;) It will serve you well to learn to spell my name correctly, as I have a reputation for being intollerant of mistakes...:D
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    Lord Vader wrote: »
    But, you are slightly more tolerant than the Emperor...correct? I've heard that he's really a hardass when it comes to spelling mistakes.
    You'd do well to remember that Rubin. If the Emperor were to see that spelling error, it would be an instant force choke...no questions asked.:p
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Lord Vader
    edited June 2009
    Kex... You will find that it is wise not to get on my bad side. Do you think it easy to type with mechanical hands? And the damn eyepieces on my mask have yet to come back from the optometrist. Perhaps it is because I choked the $hit out of the **** for getting the wrong lenses last time....
    To your last point, yes I really am a nice guy, so long as you understand that I am the Master...
  • rubin
    rubin Posts: 565
    edited June 2009
    Let the error of the VOWEL!! stand.My 256,000 uf of energy storage will defeat you in" the battle of EVERMORE" !!!!!
  • Lord Vader
    edited June 2009
    Do you think it wise to challenge Me? Need I remind you that I have enough power to destroy a planet?
    The force is weak in you, and it is for that reason I tolerate your lack of respect... What is it that you posess that could defeat ME?
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2009
    Lord Vader, are those Sith smilies you are using?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Lord Vader
    edited June 2009
    The Sith don't smile without reason.
  • wingnut4772
    edited June 2009
    Lord Vader wrote: »
    They make you appear kinda warm and fuzzy. I find myself strangely drawn to you.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Lord Vader
    edited June 2009
    I find the thought of you being turned on by my heavy breathing disturbing...
    I should thank the OP of this thread as it is nice to have a thread named in My honor. I am curious as to why he called me out however...
    I sense something... a presence I have not felt since......
  • rubin
    rubin Posts: 565
    edited June 2009
    Lord Vader wrote: »
    I have the mighty L Z as an ally!!!!!!
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited June 2009
    Listen babies. This is an audio forum and a 2 channel audio section of that thread. So go your pacifiers and climb back into your cribs.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2009
    Some people need to review the proper dosage of medication with their physicians.
    DKG999
  • zingo
    zingo Posts: 11,258
    edited June 2009
    rubin wrote: »
    I would assume that you posted this here because your mega-watt stereo!!!!!!!!!!!!!!!!! is 2 channel. Let's see some pictures of this beast?!?
  • megasat16
    megasat16 Posts: 3,521
    edited June 2009
    rubin wrote: »
    256000uF is only a number without what's the Voltage it's stored in it. If it's 1V, it's hardly lethal but if it's 50V or more, it can weld mild steel together.
    Welcome to the Dark-side! Now, let's the fight begins. :D
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • devani
    devani Posts: 1,497
    edited June 2009
    in CP, no force is stronger than "EMOTIVA" :D:D
    ....now surrender
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • rubin
    rubin Posts: 565
    edited June 2009
    megasat16 wrote: »
    Hi megasat,you got me curious so I checked.I have 2 power amps each with 128,000uf 4 caps@22,000uf/80v....4 caps@10,000uf/50v This is what is written on them.I'm not that familiar with electronics, so is this a large amount?I've also noticed that the glass fuses on the circut board have thick wires in them but I cant see their amperage rating.They each(amp) have a toriod power supply that measures about 5 inches in dia. and 4 inches tall.
  • megasat16
    edited June 2009
    rubin wrote: »
    Well, without looking at the Schematic or knowing what amp it is, it's hard to tell that you can combine the 4 x 22000uF/80V with the other 4 x 10000uF/50V. Since there are different ratings, they appears to be for different part of the circuits and the filter capacitance might not be 128,000uF for each channel. Having said that 4 x 22000uF for each channel alone means a mighty reserve for a good tight bass in the amp. For e.g, I have an amp which uses 2 x 50000uF/100V for each channel but voltage is actually measured at more than 80V for each rails (positive and negative). And then, there are smaller value caps with 150V (which has 134V measured voltage) used for Voltage Gain Stages.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2009
    megasat16 wrote: »
    Mega,
    I have a device that can ouput 50,000 volts, I can put it around your waste and choke your chicken for 7 seconds after which you will get up, call me bad names, but you will walk away.
    RT1
  • rubin
    rubin Posts: 565
    edited June 2009
    megasat16 wrote: »
    these 8 caps are all on the same board,The output boards also have smaller caps. The power supply is 115/230v,don't know why.
  • rubin
    rubin Posts: 565
    edited June 2009
    Mega,
    RT1
    what kind of device is that?
  • megasat16
    edited June 2009
    Mega,
    RT1
    Hehehe...You tried it? I don't need my body-parts straightening yet but thanks! :D
  • megasat16
    edited June 2009
    rubin wrote: »
    I don't think the device RT1 mentioned is not related to Audio! It is known as Taser / Stun Guns used by police and law enforcement officers.
    You gonna pay for it Ted! With your Soundlabs, that is.....
  • rubin
    rubin Posts: 565
    edited June 2009
    zingo wrote: »
    Not really,just to bug LV,but I will post some pics.
  • Lord Vader
    edited June 2009
    rubin wrote: »
    I am curious as to why you sought me out... Prior to this thread, I have had no contact with you. Why do you wish to bother me? I have no time for games or trolling as it is called here. Better come up with something more than this because I fail to understand your purpose here.
  • rubin
    rubin Posts: 565
    edited June 2009
    Lord Vader wrote: »
    Your name LV,and your comments,on other threads were entertaining.Just my way of responding.
  • Lord Vader
    edited June 2009
    I am not here for your .... entertainment. As I surmised from your lack of any sort of equipment to back your claims, you are a waste of time as is this thread. I will post here no further.
    treitz3 Posts: 20,069
    edited June 2009
    rubin wrote: »
    Bofa-Deez **** in yo'mouf. 'Nuff said.
    What in the hell is it with you girls?
    Get with it, this is an audio forum. You girls are in the wrong sub-forum to begin with. Take your BS and move it elsewhere. Love ya'. Mean it. Bye. :rolleyes:
  • lightman1
    lightman1 Posts: 10,797
    edited June 2009
    Lord Vader wrote: »
    Suuuure you won't!:rolleyes:
    edited June 2009
    Lord Vader wrote: »
    Cool, as long as we agree? How about making just ONE post about audio and knocking off the clown act?
    .....And now a word from a worthless piece of schieeeeet......
