Fix my DVD driver please.
zingo
I have a Pioneer DVD-RW DVR-112D drive and I'm having problems with it. It will read and play CDs no problems, and it reads blank discs but can't burn to them, and it won't even read program discs. The computer says the drive is working correctly, but obviously that isn't true. I have updated to the latest firmware from the manufacture and reinstalled the drive, both to no avail. Please help.
Post edited by zingo on
I do not think it is a driver problem
You really think I might need a new one?
Yes
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175Testing
Testing
Testing -
I would take it apart, lube any transport pieces and clean the lens, if that works, great; if not, drives are cheap enough.
Yes you need a new one they go fairly regularly I replace a lot of them.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I would also say you need a new one I go through 2 to 3 a year but I burn at least 50 DVD's a month.Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Monster PowerCenter HTS 3600 MKII
Harmony One -
That was my next question. Lately I've been using a CD-RW and burning a podcast to it every day for my commute. Would that shorten its life or make it act weird like it is?
Thanks for the link. -
Ultimately, yes. The lasers are variable intensity (writing takes a more focused & stronger beam than reading) so the more burning the shorter the life. I doubt a short burn a day would wear it out but you didn't say how old it is. Anyway, it could be a weak laser. Cleaning it may buy you a little more time but for $25 for a new one, it probably isn't worth it to bother.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I've had the drive for about 2 years, so I may just buck up and get another one.
