LSI25 and Pioneer VSX-1019AH-K Help
dvisoky
dvisoky Posts: 16
Hi - I need all the help I could get
The Pioneer is a brand new AV receiver and I also have a dedicated subwoofer.
Can anyone let me know the best way to connect my new receiver to the subwoofer and LSI25?
Please speak to me like the uneducated wannabe that I am Thanks Dave
Post edited by dvisoky on
  • jimmydep
    jimmydep Posts: 1,305
    edited June 2009
    What kind of subwoofer are you using.......what speaker configuration do you have (2channel, 5.1, 7.1.....)
    That receiver has 120wpc at 1khz@8ohms, the LSI's are 4ohm speakers that demand high power to sound good.
    JD
  • Montoya
    Montoya Posts: 506
    edited June 2009
    Connect it directly to the receiver left and right speaker post and connect the sub to the lfe RCA jack. On a side note you should seriously look into getting a seperate amp for those speakers at a minimum 200 watts per channel.
  • dvisoky
    dvisoky Posts: 16
    edited June 2009
    Thank you guys. The subwoofer is a Klipch (the exact model, watts, size are at home for the moment) and the receiver is set up as a 7.1. They say it has 120 watts X 7 of power.
    Note that I am going to run the system using only the Polk lsi25 speakers with the subwoofer and a center speaker for now. The room is a odd and open space so I will not run a 7.1 setup for now.
    I know that 120 watts is not so much power but I will not be running the speakers at high levels for extended times.
    Any advice is always appreciated
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    What they are saying is that your receiver does not employ a high current amplifier. It may not be stable into 4 ohms and can overheat or damage the amplifier by using the LSi speakers you have as they are low impedance.
    It will probably work in the short term but you will not get the full performance out of your speakers and can risk damage. I would use the pre-out of your receiver if you still want to use it and add a dedicated high current amplifier to power your speakers.
    As far as physical hookup goes - right now you simply connect your speakers directly to the receiver Left and Right speaker outputs and the subwoofer hooks up to the subwoofer pre-out.
    Main Surround -
  • johnmail76
    johnmail76 Posts: 1
    edited June 2009
    Pioneer VSX-1019AH-K is easy to setup and it has a phenomenal ability to upscale and convert analog video signals to 1080p when transmitted through HDMI to your LCD HDTV. You also can plug in your iPhone and watch videos with the included cable without buying an expensive dock
  • mantis
    mantis Posts: 17,373
    edited June 2009
    This is not a proper setup. You should not use the Pioneer to power your speakers.
    For now I suggest the following setup until you buy a external multichannel amp.
    Ditch the Klipsch sub. sell it on ebay and use the money towards a amp. Wire the Lsi internal subs as your LFE with a Y adapter at the preout on the receiver. Set the speakers up manually and cross over them in small at 80hz. All speakers. This will take some of the load off the Pioneer which is not desinged to power 4 ohm load speakers. If you purchased a ICE receiver like the SC-05 or SC-07 then I would feel a little better and is a better match to your speakers. I would still suggest a amp if you plan on cranking it although I have had success running my 4 ohm load speakers with the Pioneer Elite Sc-07 with no problem or loss of dynamic range. On a side note I think Pioneer under rated the Sc-07. It does not get hot or strain when I drive it. You should seriously consider at least this move.
    Dan
    Dan
  • Rocco1
    Rocco1 Posts: 190
    edited June 2009
    +1 with Mantis.
    You will end up messing everything up (receiver and speakers) if you run a 4 ohm speaker, with a 8 ohm amp. If you just spent a pretty penny on some pretty speakers BUY A AMP!
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • Bernal
    Bernal Posts: 991
    edited June 2009
    dvisoky wrote: »
    Hello.
    LSI are major league ...
    Use an amplifier.
    Check if you have pre-out outputs to amplify
    Specifications
    Amplifier section
    Continuous average power output of 90
    watts* per channel, min., at 8 ohms
    , from
    20 Hz to 20 000 Hz with no more than
    0.2 %** total harmonic distortion.
    Front (stereo) . . . . . . . . . . . . . . . .90 W + 90 W
    Power output (1 kHz, 6 Ω, 0.05 %, 1 ch driven)
    . . . . . . . . . . . . . . . . . . . . . . . . .120 W per channel
    Guaranteed speaker impedance
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .16 Ω to 8 Ω,
    less than 8 Ω to 6 Ω (setting required)
    * Measured pursuant to the Federal Trade Commission’s
    Trade Regulation rule on Power Output Claims for
    Amplifiers
    ** Measured by Audio Spectrum Analyzer
    Audio Section
    Input (Sensitivity/Impedance)
    LINE . . . . . . . . . . . . . . . . . . . . . . 284 mV/47 kΩ
    Output (Level/Impedance)
    REC. . . . . . . . . . . . . . . . . . . . . . 284 mV/2.2 kΩ
    Signal-to-Noise Ratio
    (IHF, short circuited, A network)
    LINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 dB
    Signal-to-Noise Ratio [EIA, at 1 W (1 kHz)]
    LINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81 dB
    Tuner Section
    Frequency Range (FM) . . .87.5 MHz to 108 MHz
    Antenna Input (FM). . . . . . . . . 75 Ω unbalanced
    Frequency Range (AM). . . .530 kHz to 1700 kHz
    Antenna (AM). . . . . . . .Loop antenna (balanced)
    Video Section
    Signal level
    Composite . . . . . . . . . . . . . . . . . .1 Vp-p (75 Ω)
    Component Video . . . . . . . .Y: 1.0 Vp-p (75 Ω),
    PB, PR: 0.7 Vp-p (75 Ω)
    Corresponding maximum resolution
    Component Video . . . . . . . . . . . 1080p (1125p)
    (Video convert off)
    Your AVR has no pre-out outputs to amplify
    Digital In/Out Section
    HDMI terminal . . . . . . . . . . . . . .19-pin (Not DVI)
    HDMI output type. . . . . . . . . . . . . . . 5 V, 100 mA
    USB terminal . . . . . USB2.0 Full Speed (Type A)
    iPod terminal. . . . . USB, and Video (Composite)
    SIRIUS antenna cable . . . . 8-pin mini DIN cable
    Integrated control section
    Control (SR) terminal. . Ø 3.5 Mini-jack (MONO)
    Control (IR) terminal. . . Ø 3.5 Mini-jack (MONO)
    IR signal. . . . . . . .High Active (High Level: 2.0 V)
    Miscellaneous
    Power requirements. . . . . . . . . . AC 120 V, 60 Hz
    Power consumption. . . . . . . . . . . . . . . . . . 350 W
    In standby . . . . . . .0.5 W (KURO LINK OFF)
    0.8 W (KURO LINK ON)
    Dimensions
    . . . . . . 420 mm (W) x 158 mm (H) x 349 mm (D)
    (16 9/16 in. (W) x 6 1/4 in. (H) x 13 3/4 in. (D))
    Weight (without package) . . . .8.7 kg (19 lb 3 oz)
    Furnished Parts Number
    MCACC Setup microphone (APM7008). . . . . . 1
    Remote control unit (AXD7551(VSX-1019AH)/
    AXD7552 (VSX-919AH)). . . . . . . . . . . . . . . . . . . . 1
    AA/IEC R6 dry cell batteries. . . . . . . . . . . . . . . . 2
    iPod cable (ADE7129). . . . . . . . . . . . . . . . . . . . . 1
    AM loop antenna . . . . . . . . . . . . . . . . . . . . . . . . 1
    FM wire antenna. . . . . . . . . . . . . . . . . . . . . . . . . 1
    These operating instructions
    Note
    •Specifications and the design are subject
    to possible modifications without notice,
    due to improvements.
    HT: 5.1
    Pre:
    DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    Amp:
    SUNFIRE Grand Signature
    Speaker:
    LSiC (Center speaker)
    LSi15 LEFT (Front speaker)
    LSi15 RIGHT (Front speaker)
    LSif/x LEFT (Surround speaker)
    LSif/x RIGHT (Surround speaker)
    VELODYNE OPTIMUN SERIES (High Output Digital EQ SubWoofer 2400W/1200WRMS)
  • dvisoky
    dvisoky Posts: 16
    edited June 2009
    Hi Everyone - I swapped my Pioneer and used my Onkyo TX SR-705 to power my LSI25's. It worked and I just won a bid on Ebay and purchased an Adcom 555II amp. Does anyone have any advice on how to hook up my receiver to the Amp to the Speakers and subwoofer? Thank you Dave
  • superjunior
    superjunior Posts: 1,632
    edited June 2009
    dvisoky wrote: »
    get some quality ic's (inter connect cables) and run them from your receivers pre-outs to the amps inputs. you than run your speeker wires from the amp to your speekers. You can also add a trigger wire - which is a 3.5mm cord simmillar to a headphone jack - from the receiver to the amp to power the amp on when the avr is turned on. Run a standard sub cable from your receivers sub output to your sub. It's fun- enjoy
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • dvisoky
    dvisoky Posts: 16
    edited June 2009
    Thank you so much for your reply. I search Amazon for Trigger Wire. Could you let me know a brand, model etc on Amazon in which to search? Are they just called 3.5mm cord? Please let me know and thank you
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2009
    Welcome & congrats Dvisoky. What he means is to be able to turn on your amp when you turn on your receiver you need to connect the amp to the receiver using a trigger. They can be obtained at Radio Shack.
    Personally, I think you should just leave your amp on all the time & save yourself that step.
    There are lots of options for IC's. Blue Jeans Cable, Monoprice, Signal cable are some of the favorites around here.
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2009
    Actually depending the amp you buy, you may not need the trigger. Some amps, quite a few of them actually have a switch that allows it to "auto sense" an incoming signal and turn on. Buy the amp first then determine if you need the trigger or like Cfrizz says, just leave it on.
  • dvisoky
    dvisoky Posts: 16
    edited June 2009
    I bought a Adcom GFA 555II - I went to the PDF manual but didn't see a place for a trigger. Do all Amp's have a slot? I also didn't see an automatic sensor which would be even nicer. Maybe the Adcom is too old
  • nguyendot
    edited June 2009
    No, not all amps have one. You simply turn it on after the receiver (to avoid the turn on noise).
    Main Surround -
  • cfrizz
    edited June 2009
    Turn it on & leave it on.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2009
    I would dump it back on the bay, Adcom is junk unworthy to feed the LSi any signal.
    RT1
  • dvisoky
    dvisoky Posts: 16
    edited June 2009
    Why would you say its a piece of junk? Others have it and love it.
  • reeltrouble1
    edited June 2009
    well, sorry, just trying to agravate the Adcom fan-boys today, but I see they all ran for cover and left you alone.
    See this Adcom thing has gotten way out of hand to the point that some good person like yourself comes along and buys these things based on something somebody wrote. They are adequate for power but tend to be harsh sounding and overall just mundane totally average, this has been known at Club Polk since oh say, well forever, but there has been a fan-boy revival of the company at CP over the past few years and its time to put things in proper perspective......to boot I am just enough of an butt munching a-hole to do it and most importantly get away with it, since I do know about such things. Besides I am an ole ****, if you want a young whippersnapper opinion check with Sid the Kid he owned Adcoms as well when he was really young and pimply.
    Now the "junk" thing was a bit tongue in cheek to stir the pot, actually to dump the pot off the stove and have the contents run down the cracks of the floorboards so the liquid lands on an Adcom Fan boy head, you should actually enjoy your new to you amp, I suspect you chose it with cost consideration in mind as well as those recommendations you mention for power sound and so on. Just know there are many many better amplifiers available for you as you grow in the hobby. Your speakers can handle a lot more amplifier and as a matter of fact a lot more pre-amp.
    Since you obviously have a great sense of humor we are going to be great board friends. You have some great speakers there.
    RT1
  • reeltrouble1
    edited June 2009
    oh and since nobody actually told you how to get your amp to turn on/off if it does not have a trigger and you want to do this, you might get a power bar with a switched outlet that has a trigger function. You run the wire from your A/V to the power center then plug your amp into the power center, you can get the trigger wire at Radio Shack for under 5 bucks. You can do some research on the power center companies to pick the one that fits your needs.
    RT1
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    RT1
    Ole RT1 is correct.
    I am a previous Adcom 565 mono block owner. Notice the emphasis on previous. There is a lot better out there but in it's class it is good equipment.
  • dvisoky
    dvisoky Posts: 16
    edited June 2009
    We'll give the Adcom a try. I actually bought it used to meet a 2 channel price point. The room that its in is not conducive to more that 2 or 3 speakers up front and a sub. Actually the previous post about getting rid of my Klipsch (very low end) sub is probably a good idea.
    If price was no object then I wouldn't be scraping around at the $400 price point for a used amp. But with some good words out there, I'm really hoping to get much better sound that whats coming out of my AVR Onkyo 705 - although its not too bad. I can always upgrade down the road right?!!
    Regarding that Wire Trigger - I'm not sure I'm following you on this - for exactly what I need to buy. Let me think about it once I get the amp. Cheers
  • reeltrouble1
    edited June 2009
    dv,
    now dont get nervous its not that complicated, I will look on the Audiogon for an example of the power center thing. In the meantime I do suspect the rig will sound better than just with the reciever, as far as the sub, well, except for HT I am not a fan, your LSI's would have plenty of nice bass for me.
    RT1
  • nguyendot
    edited June 2009
    RT1
    Gahhh.. i forgot about this. All my power centers have the trigger, it looks like a headphone jack.
    Good catch!
    Main Surround -
  • superjunior
    edited June 2009
    dvisoky wrote: »
    sorry man, didn't mean to leave you hangiin, been working some long shifts lately. looks like the fine folks here clarified what I was trying to say. good luck
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • reeltrouble1
    edited June 2009
    http://www.audiogon.com/cgi-bin/cls.pl?powrcond&1249396040&/Panamax-M5100-PM-11-outlet-lin
    here you go dv, you want something like this, you can find them for less used on Audiogon or give this guy a call. no affilliation.
    RT1
  • johnda
    johnda Posts: 13
    edited July 2009
    I like the LSi-25's and 15's, but we need to understand their power requirements and impedance. They are very similar to the classic AR3a loudspeakers in efficiency and have 4 ohms impedance. The AR3a's were known as "Amp Busters" because so many amps blew while trying to drive them. From what I see of the new A/V receivers, many of them do not have the high current ability to handle loads at 4 Ohms especially speakers rated below 90 Db efficiency. Remember a speaker rated at 87 Db will sound half as loud as a speaker rated at 90 Db at the same power setting. With the Polk efficiency being at 88 Db , if you are going to drive them in a room 16x25 or larger you will need lots of true power. I would not be looking at a all-in-one receiver, but would be looking at an integrated amplifier or preamp-amp combo rated at least 60-100 RMS watts/channel rated for 4 Ohms impedance with the powerband covering 20-20k cycles with a very low distortion figure. This will mean the unit will not be a lightweight, but will have a substantial power supply and cooling. Having said all that, I really do like the Lsi 25's. Coupled up properly to a good amp, you will NOT need a separate subwoofer. They will give you all the punch you need.
    Polk Monitor 4
