Adcom gfa 555 vs.Rotel 990BX
zarrdoss
I am looking at getting one of these maybe in the next few days and was wondering if anyone has had any exp with the Rotel, both about the same power, but the Rotel is still new never been used in the box for 450. and the adcom is 375 but about 9 years of use on it.
Thank you!
Thank you!
Post edited by zarrdoss on
One for upstairs One for downstairs.
$375 is a little too high for the 555.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
The Rotel seems to average for about $400 give or take $50. The Adcom averages for $325 give or take $25.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
Thanks guys, going to talk to the guy tonight with the Rotel and see what I come up with. does anyone know if it is a common ground amp?
TOOLFORLIFEFAN wrote: »One for upstairs One for downstairs.
I should have the Carver back sometime for upstairs or down whatever works better.:) -
It's common ground, I have done all the leg work on the Rotel amps that i have looked at and that is one of them. I actually called Rotel and talked to them about a few amps. I really want to hear the RB-1090 :cool: $$$$$ it sounds bad **** but i have read up and down reviews.
380 x 2 8ohms
760 x 2 4ohms
1520 x 2 2ohms -
TOOLFORLIFEFAN wrote: »It's common ground, I have done all the leg work on the Rotel amps that i have looked at and that is one of them. I actually called Rotel and talked to them about a few amps. I really want to hear the RB-1090 :cool: $$$$$ it sounds bad **** but i have read up and down reviews.
380 x 2 8ohms
760 x 2 4ohms
1520 x 2 2ohms
If I decide to pass on this would you want it? -
No my angel has bigger plans for me, or so he say's
I will think about it, i will get back to you on it. -
geez Larry, 760x2 @ 4 ohms
I just talked to him and will go look at the Rotel sometime soon. -
I haven’t had a 990BX but if it sounds anything like the Rotel RB1080 that I did have; I can say it will sound a fair bit different from a GFA 555. If you can, try to listen to both and see what you prefer. I would go with the Adcom, however that is a case of personal preference. Good luck.
I got the Rotel and another smaller Rotel (for surrounds) from him and am going to go get one more for the center So I will have all Rotel pre and power.
Congrats on the Rotel amps.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Thanks I am hooking them up now but running to a bit of a problem with the rack, nothing the rotozip will not fix. -
Nice setup.... How does it sound ?
Thank you! It sounds fantastic, best of both worlds, excellent 2 channel and HT to boot.
Great choice on the Rotel....no slight on the Adcom, but it fits the bill better.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Tool,TOOLFORLIFEFAN wrote: »It's common ground, I have done all the leg work on the Rotel amps that i have looked at and that is one of them. I actually called Rotel and talked to them about a few amps. I really want to hear the RB-1090 :cool: $$$$$ it sounds bad **** but i have read up and down reviews.
380 x 2 8ohms
760 x 2 4ohms
1520 x 2 2ohms
Is the 1090 common ground? I want to make sure because I may have a line on one.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Tool,
Yes it is.. I want one bad.:cool: -
Tool,
Yes the Rotel
1050
1070
1080
1090
1095
1075
are all common ground. There new class d amps are not. -
Kevin how did i go past this post? is that the one that was in the springs?
Awesome:cool::cool:
Congrats.. -
I had a Rotel 990 in my system for a number of years, I feel it was an outstanding value new and even better value at today's prices. To my knowledge the 1090 is actually little different internally from the 990, most of the difference is the cosmetic fins and such externally.
I compared the 990 to the 980 (again, similar to the 1080). The sound was quite similar (not surprisingly), but the 990 just had a little more "there" to the sound, slightly fuller and more dynamic, which I attributed to the greater headroom of the 990.Steve Carlson
Von Schweikert VR-33 speakers
Bel Canto eVo2i integrated amp
Bel Canto PL-2 universal disc player
Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
VH Audio Flavor 4 power cables
Polk Monitor 10B speakers, retired but not forgotten -
TOOLFORLIFEFAN wrote: »Kevin how did i go past this post? is that the one that was in the springs?
Awesome:cool::cool:
Congrats..
Thank you! the 990 was in Aurora and the other two came from ft Collins and here in Loveland, I really like the way it sounds, nice full bass and clear highs.:D
