Cleaning dirty/dusty drivers
dipiazza
dipiazza Posts: 363
edited June 2009 in Vintage Speakers
hey all. I usually keep the grills off my speakers and recently noticed that dust has accumulated on the drivers, what do you all use to clean off dusty drivers? Its not too bad, but would you all just use a clean cloth? or is there something else good? Thanks!
-Jake
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
Post edited by dipiazza on
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2006
    Put on some Zepplin at 3/4 volume....LOL
    Seriously though, I use a well rung damp rag to wipe my drivers down when needed, very carefully.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Ditto the damp rag, usually a wash cloth or old soft t-shirt.
    Be very gentle.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • dipiazza
    dipiazza Posts: 363
    edited June 2006
    So its ok to get a little bit of moisture on the drivers. obviously i wont get them "wet" but damp is ok?
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2006
    I either use a 1500psi pressure washer or a DRY, THX certified paintbrush.
  • dipiazza
    dipiazza Posts: 363
    edited June 2006
    Clearly either of these would work fine... why didnt i think of them!?!?
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • shack
    shack Posts: 11,154
    edited June 2006
    Overkill....A common garden hose works fine. Leave it to audiophiles to come up with an expensive solution when something much less costly will do the job. I seriously doubt if anyone could tell the difference.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2006
    I have a French maid come over and dust all my drivers once a week. Twice a week if I do a lot of critical listening.
  • dorokusai
    edited June 2006
    Leave it to DK to offer the best solution yet.
  • DarqueKnight
    edited June 2006
    Yeah, and the cost is really reasonable if you get one who is working her way through school rather than one who is a full time professional.
  • ND13
    ND13 Posts: 7,601
    edited June 2006
    How skimpy is her uniform??
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • DarqueKnight
    edited June 2006
    The young lady who dusts my drivers prefers to take off her uniform shortly after arrival. She says its too contricting. She does keep on her hat and heels. The heels help her to reach the top of my SRS's (no extra charge). She keeps the hat on at my request because I think it is cute.
  • dipiazza
    dipiazza Posts: 363
    edited June 2006
    Glad to see everyone has such "unique" methods to keeping drivers clean!
    I approve whole heartedly!
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • steveinaz
    edited June 2006
    Dammit, come to think of it my rag IS NOT THX certified...son of a ****. Thanks for the heads up Mark!
  • shack
    shack Posts: 11,154
    edited June 2006
    Are the hat and heels THX certified?
  • DarqueKnight
    edited June 2006
    Yes, the heels are THX certified. No luck with the hat.
    SCompRacer Posts: 9,112
    edited June 2006
    Regardless of the THX certification, the wife says I absolutely cannot have one of them driver dusters.
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    Off the hook.
    All of you are off the hook.
    I am going to ask my wife for a duster chick, maybe for my birthday.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • ND13
    ND13 Posts: 7,601
    edited June 2006
    Skynut wrote:
    Off the hook.
    Or better yet, Father's Day!!
  • ward91
    ward91 Posts: 338
    edited June 2006
    proberly dusted them already but why not blow air onto them using yourself a compressor a bycycle pump ect.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • read-alot
    read-alot Posts: 812
    edited June 2006
    This sounds much better than the Armour All option. I will just have to wait till my wife and daughter decide to travel again. My son is cool with his fathers decisions on keeping the audio in pristine condition.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited May 2009
    Well Sal,
    What are you waiting for? I think you should film it with your wife cleaning them like a "good" wife should. You've been married for a few months now so now is about time for some training.
  • gdb
    gdb Posts: 6,012
    edited May 2009
    read-alot wrote: »
    I've heard that ArmorAll is not an option, and very bad for use on drivers.
    Toolfan66 Posts: 18,077
    edited May 2009
    gdb wrote: »
    I think ArmorAll is bad on everything.. I do not use it.
  • Bigbang
    Bigbang Posts: 233
    edited June 2009
    I use baby wipes to get most of the dust from the rubber butyl surrounds. It won't dry them out and it will clean them very well. I try and stay away from the sticky cones. Someone suggested silicon oil three times a year but I'm not sure where you would find that and not sure what corrosive actions it would have...
    you might check this thread out...
    http://www.polkaudio.com/forums/showthread.php?t=74044&highlight=cleaning
    I thought about this product for the paper cones but I've never heard anyone use it and I don't want to be the first... anybody?
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=340-513
    D
    I like to listen, tinker, listen and repeat.
    F1nut Posts: 51,799
    edited June 2009
    Windex is all that is needed to clean the cones and surrounds. Works perfectly and causes no damage. Do not use silicone oil or any silicone based product on the drivers or the cabinets.
  • CowboyRJB2
    CowboyRJB2 Posts: 58
    edited June 2009
    Windex... chamois (shammy) cloth.... Then ARMORAL
    ELITE VSX-99 REFERENCE
    ELITE PD-65
    SDA-1C's with new RDO194-1 tweeters as MAINS
    MAGNEPAN TYMPANI 1D's for alternate fronts for classical music
    PARADIGM REFERENCE CC-450 Center
    MONITOR SERIES II... M10 REARS
    2 POLK DSW-600PRO SUBS
    "ROCKIN THE HOUSE"
  • NJPOLKER
    edited June 2009
    CowboyRJB2 wrote: »
    Hopefully you mean for your automobile.
    edited June 2009
    I used a silicone based product one time, but at that time i had no idea that was a no no.
  • CowboyRJB2
    edited June 2009
    NOPE, not my car... For my SDA 1-C's and my M10's
    ELITE PD-65
    "ROCKIN THE HOUSE"
  • CowboyRJB2
    edited June 2009
    NO, not for my auto... For my SDA 1C's and M10's... I dont drench them. I spray the cloth lightly and give the drivers a wipe
    ELITE PD-65
    "ROCKIN THE HOUSE"
