Dayton 500w and 1000w plate amps
ben62670
Are these any good? I am running my 15" Dayton Titanic MK III's of of a pair of Adcom GFA-565's, but I have the opportunity to get the 500w plate amps for $200. Anyone have any experience with them? Do they hit hard and tight?
Ben
Ben
Ben
Ben
Post edited by ben62670 on
Ben i was asking the same question, and came across this thread.
http://www.polkaudio.com/forums/showthread.php?t=83430
This POLKIE is trusting them to run his custom made subs, and he says they are amazing.Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
I think I trust Sid:)
Ben -
by the way Ben, where can you fid the 1000w amp?Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
200 bucks for the 500 watter? nice
200 for the 1000 watter = run, dont walk.
great amps. my 500 watter handles my diy sub with a SVS plus driver in it without trouble. power man, wads of bass power!Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
I have slowly been weening myself for the need to have mega power. It was cool to have 7 foot tall speakers at one time and a 6 foot tall sonosub. I was able to say I maxed out a 126db meter, and had the largest SDA's, but I want to refine things. I want to clean things up a bit. That is one of the reasons I built the subs into my towers. If I can stick those plate amps in the cabs that is two less amps to look at, and they should run a little cooler than those mono blocks. It gets hot here in HotLanta!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I've got a PE 500 watter I bought about 2 years ago. Still in the box. Thinking about a sealed 15 inch bottom fire with four 10 inch Polk PRs. I've got a double handful of PRs to play with.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I am digging them. They are SOLID.
Not to mention the crossover functions are solid.
I say do it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
They are decent but do not put out what they are rated at. I'd go with the Bash or the O-Audio 500w amp that you can find for around $200. The reason I say O-Audio is because of the sine-wave amplifier tests at AVS. The O-Audio put out around 450 continuous watts, comparing very favorably to the 1,000 watt Dayton which delivered only 560 watts.
http://www.avsforum.com/avs-vb/showthread.php?p=11318774#post11318774
Then again, for a DIY subwoofer there really is no equal to a pro-amp for price/performance. A Behringer EP2500 for around $275 will give you 450w X 2 at 8 Ohms and about 650w x2 at 4 Ohms.
http://www.avsforum.com/avs-vb/showpost.php?p=10753603&postcount=56
...but for your situation I'd check out those O-Audio amps I posted about above. -
BASH is probably the best bang for the buck. I got Bash 300S in my new custom sub, and it pounds with a good 12" driver.
But honestly, I really wanted to try that Dayton 500-Watt sub - just couldn't afford it. It probably won't push all 500 Watts like Matt said, but oh well, 400+ is still good enough most of the time. And if it's not enough, there is always a 1000-Watt beast.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Currently using the Dayton 1000 with the VMPS larger...........happy as can be....hits hard and tight.....rocks our house and the neighbors
I have one and its Enough! dayton 1000 watt plate plenty !!!!
Im gonna have to screw the sheet rock to the wall !!!!!!:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
They sent me a bad unit. Big friggen ding on the case, and it died in less than 10 minutes. I know PE will take care of it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
tell me you bought the hpsa-1000:cool: " He who dies with the most equipment wins Right ? "
The Ed A7S-450 (sealed sub) which has the LT1300 am now has the ICE amp (class D type). Sold the HSU 3.3's and I have two of the A7S-450 subs coming this Friday so it should be interesting with my gear.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Deadof_knight wrote: »tell me you bought the hpsa-1000
500 watter.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Well I spoke with PE about the amp. I explained what I am running for a system. Soon they are coming out with a new upgrade with protection. For now the amps are not designed to handle constant bass heavy music. They are great for HT, but for my purposes the 565's suit me better. The main problem I am having with the 565's is the lack of an EQ to boost lower frequencies due to my sealed sub. PE has been great. I do recommend this sub for normal people, but if you want more than explosions you may be disappointed.
Ben -
They also appear to use cheap electrolytic coupling caps."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
