7600 replacement Center suggestions
I have a RM7600. Looking to replace/upgrade my center. ANy suggestions? I would like the LSiC if it will timber match my 7600 sat's.
Also, will there be a big difference between LSiC and CSi40?
Post edited by pcgorilla on
LsiC wouldn't be a match because of the complete design differences. The CSi40 would be closest of the two, but are you intending on upgrading all of your system at some point and looking for the center to be the start or what?comment comment comment comment. bitchy.
Just looking for a better Center. I have a budget of about $300-$400.
I will be getting the new Yamaha's due out in Sept as a receiver. -
The problem that you're going to have with your center being as big as the 40 is that it's going to completely overpower the rest of your system. I'd consider something like the csi30 or 20 to match what you have.comment comment comment comment. bitchy.
That's what I am afraid of. So will there be a big difference between the csi30 and the center for the 7600?
Originally posted by pcgorilla
That's what I am afraid of. So will there be a big difference between the csi30 and the center for the 7600?comment comment comment comment. bitchy. -
I think you would be fine with the CSi40. Just because it is bigger doesn't mean it will overpower, it will just sound better. I don't feel upgrading to a CSi30 would be worth doing in the long run.
The LSiC was an incredible upgrade over the 7600 center.
Perhaps you could try it in your system and see how you like the sound of it with your other speakers. If you like, you've got a great center, otherwise you could take it back. Then maybe in the future you could go to the LCi in-walls which would be timbre-matched to the center. -
If he's talkin about getting a Yamaha receiver later, I wonder what he's driving it with right now. What receiver are you running with right now Gorilla?
Wouldn't the worst thing that he could do be to put a 4ohm speaker into the mix with all his others? Then he'd DEFINITELY have an overpowering center......right?comment comment comment comment. bitchy. -
Oh, and PC, don't forget to pick up an SPL meter, if you don't have one! -
I have a Denon 2803.
