Power amps and conditioners
VR3
NO THANKS! I'll pass!
Talk about soundstage and dynamics robbing!!?!?!?!?!?
Huge difference between in the conditioner and out of the conditioner.
Post edited by VR3 on
I take it you never used an Equitech Balanced Power unit. I guarantee your opinion will change.
Hmmm...
The MIT does good on the sources, but the Monos consume quite a bit of power...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Talking about mains ac?
I have never used a power conditioner (apart from my belkin “pure av” filter cheap plug thingy)
But i fail to understand how they make a huge difference when the power amp has a conditioned power supply. Often with capacitors holding enough charge to run the unit for seconds after it has been unplugged from the wall.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
I have never used a power conditioner (apart from my belkin pure av filter cheap plug thingy)
But power amps don't have a conditioned power supply, some have regulated power supply's. Big difference between conditioning and regulating. Perhaps you got the two terms mixed up.
I don't know of any (amp) power supply's that also condition the AC.
And you tried which one(s)?pearsall001 wrote: »I take it you never used an Equitech Balanced Power unit. I guarantee your opinion will change.
I also have a 2.4 kVA balanced power unit on a 20A circuit powering my entire system. Better than all the others I tried and much better than directly from the wall outlet.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
I've had the Equitech Son of Q running in my system since '05. I wouldn't think of running my gear without it. -
I think balanced AC has a lot of merit.I have 500VA Plitron xformer I will be using for my source components.
I also have a 2.4 kVA balanced power unit on a 20A circuit powering my entire system. Better than all the others I tried and much better than directly from the wall outlet.Testing
Testing
Testing -
What your thinking of is the filter/storage capacitance used to filter out the 120hz ripple,it is completely different than AC power conditioning.Some amplifers will have a small capacitor placed across it's AC input's neutral and hot.It's purpose is to provide some filtering of RF but it can't be considered elaborate line conditioning.But i fail to understand how they make a huge difference when the power amp has a conditioned power supply. Often with capacitors holding enough charge to run the unit for seconds after it has been unplugged from the wall.Testing
Testing
Testing -
Yeah, and there are a few others out there that actually improve the sound, as well. I use the low end BPT. Highly recommended.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Yep, these balanced power units are the real deal!!! You can't go wrong, the improvements in audio & video are not subtle to say the least. Highly recommended also! -
What model do you use??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Fair enough guys, looks like ill have to do some reading on this one
So what do they do ?? make the mains ac sine a pure wave ?? rather than one with noise in it ??ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
Here's so reading for you...they pionered the whole concept & obtained the patents for it.
http://www.equitech.com/ -
Interesting. Done a little bit of reading, ill have to do some more, but Ive come across some bt mains conditioners on eBay might have to get one and see what i think ;
http://cgi.ebay.co.uk/BT-MCU5A-125-Mains-Conditioning-Unit-Cleans-Mains_W0QQitemZ260419290248QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca2330488&_trksid=p3286.c0.m14&_trkparms=72%3A2108%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
