Power amps and conditioners
VR3
VR3 Posts: 29,434
edited May 2009 in Electronics
NO THANKS! I'll pass!
Talk about soundstage and dynamics robbing!!?!?!?!?!?
Huge difference between in the conditioner and out of the conditioner.
Post edited by VR3 on
  • pearsall001
    pearsall001 Posts: 5,294
    edited May 2009
    I take it you never used an Equitech Balanced Power unit. I guarantee your opinion will change.
    VR3 Posts: 29,434
    edited May 2009
    Hmmm...
    The MIT does good on the sources, but the Monos consume quite a bit of power...
  • ward91
    ward91 Posts: 338
    edited May 2009
    Talking about mains ac?
    I have never used a power conditioner (apart from my belkin “pure av” filter cheap plug thingy)
    But i fail to understand how they make a huge difference when the power amp has a conditioned power supply. Often with capacitors holding enough charge to run the unit for seconds after it has been unplugged from the wall.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    heiney9 Posts: 25,437
    edited May 2009
    ward91 wrote: »
    But power amps don't have a conditioned power supply, some have regulated power supply's. Big difference between conditioning and regulating. Perhaps you got the two terms mixed up.
    I don't know of any (amp) power supply's that also condition the AC.
  • jm1
    jm1 Posts: 618
    edited May 2009
    And you tried which one(s)?
    I also have a 2.4 kVA balanced power unit on a 20A circuit powering my entire system. Better than all the others I tried and much better than directly from the wall outlet.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • pearsall001
    edited May 2009
    jm1 wrote: »
    I've had the Equitech Son of Q running in my system since '05. I wouldn't think of running my gear without it.
  • Systems
    Systems Posts: 14,873
    edited May 2009
    jm1 wrote: »
    I think balanced AC has a lot of merit.I have 500VA Plitron xformer I will be using for my source components.
    Testing
    Testing
    Testing
  • Systems
    edited May 2009
    ward91 wrote: »
    What your thinking of is the filter/storage capacitance used to filter out the 120hz ripple,it is completely different than AC power conditioning.Some amplifers will have a small capacitor placed across it's AC input's neutral and hot.It's purpose is to provide some filtering of RF but it can't be considered elaborate line conditioning.
    Testing
    Testing
    Testing
  • Early B.
    Early B. Posts: 7,900
    edited May 2009
    Yeah, and there are a few others out there that actually improve the sound, as well. I use the low end BPT. Highly recommended.
    "God grooves with tubes."
  • pearsall001
    edited May 2009
    Early B. wrote: »
    Yep, these balanced power units are the real deal!!! You can't go wrong, the improvements in audio & video are not subtle to say the least. Highly recommended also!
  • vmaxer
    vmaxer Posts: 5,120
    edited May 2009
    Early B. wrote: »
    What model do you use??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ward91
    ward91 Posts: 338
    edited May 2009
    Fair enough guys, looks like ill have to do some reading on this one :D
    So what do they do ?? make the mains ac sine a pure wave ?? rather than one with noise in it ??
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • pearsall001
    edited May 2009
    ward91 wrote: »
    Here's so reading for you...they pionered the whole concept & obtained the patents for it.
    http://www.equitech.com/
  • ward91
    ward91 Posts: 338
    edited May 2009
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
