Dayton 500w and 1000w plate amps
ben62670
ben62670 Posts: 15,969
edited June 2009 in DIY, Mods & Tweaks
Are these any good? I am running my 15" Dayton Titanic MK III's of of a pair of Adcom GFA-565's, but I have the opportunity to get the 500w plate amps for $200. Anyone have any experience with them? Do they hit hard and tight?
Ben
Ben
Post edited by ben62670 on
  • Rocco1
    Rocco1 Posts: 190
    edited May 2009
    Ben i was asking the same question, and came across this thread.
    http://www.polkaudio.com/forums/showthread.php?t=83430
    This POLKIE is trusting them to run his custom made subs, and he says they are amazing.
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • ben62670
    edited May 2009
    I think I trust Sid:)
    Ben
    Ben
  • Rocco1
    Rocco1 Posts: 190
    edited May 2009
    by the way Ben, where can you fid the 1000w amp?
    Man Cave: 7.1
    >Sub = MK Audio 10'
    -PS3
    -Directv
  • ohskigod
    ohskigod Posts: 6,505
    edited May 2009
    200 bucks for the 500 watter? nice
    200 for the 1000 watter = run, dont walk.
    great amps. my 500 watter handles my diy sub with a SVS plus driver in it without trouble. power man, wads of bass power!
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ben62670
    edited May 2009
    I have slowly been weening myself for the need to have mega power. It was cool to have 7 foot tall speakers at one time and a 6 foot tall sonosub. I was able to say I maxed out a 126db meter, and had the largest SDA's, but I want to refine things. I want to clean things up a bit. That is one of the reasons I built the subs into my towers. If I can stick those plate amps in the cabs that is two less amps to look at, and they should run a little cooler than those mono blocks. It gets hot here in HotLanta!
    Ben
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited May 2009
    I've got a PE 500 watter I bought about 2 years ago. Still in the box. Thinking about a sealed 15 inch bottom fire with four 10 inch Polk PRs. I've got a double handful of PRs to play with.
    VR3 Posts: 29,444
    edited May 2009
    I am digging them. They are SOLID.
    Not to mention the crossover functions are solid.
    I say do it!
  • Matt34
    Matt34 Posts: 318
    edited May 2009
    They are decent but do not put out what they are rated at. I'd go with the Bash or the O-Audio 500w amp that you can find for around $200. The reason I say O-Audio is because of the sine-wave amplifier tests at AVS. The O-Audio put out around 450 continuous watts, comparing very favorably to the 1,000 watt Dayton which delivered only 560 watts.
    http://www.avsforum.com/avs-vb/showthread.php?p=11318774#post11318774
    Then again, for a DIY subwoofer there really is no equal to a pro-amp for price/performance. A Behringer EP2500 for around $275 will give you 450w X 2 at 8 Ohms and about 650w x2 at 4 Ohms.
    http://www.avsforum.com/avs-vb/showpost.php?p=10753603&postcount=56
    ...but for your situation I'd check out those O-Audio amps I posted about above.
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2009
    BASH is probably the best bang for the buck. I got Bash 300S in my new custom sub, and it pounds with a good 12" driver.
    But honestly, I really wanted to try that Dayton 500-Watt sub - just couldn't afford it. It probably won't push all 500 Watts like Matt said, but oh well, 400+ is still good enough most of the time. And if it's not enough, there is always a 1000-Watt beast.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • NotaSuv
    NotaSuv Posts: 3,871
    edited May 2009
    Currently using the Dayton 1000 with the VMPS larger...........happy as can be....hits hard and tight.....rocks our house and the neighbors ;)
  • Deadof_knight
    Deadof_knight Posts: 980
    edited May 2009
    I have one and its Enough! dayton 1000 watt plate plenty !!!!
    Im gonna have to screw the sheet rock to the wall !!!!!!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • ben62670
    edited May 2009
    They sent me a bad unit. Big friggen ding on the case, and it died in less than 10 minutes. I know PE will take care of it.
    Ben
  • zingo
    zingo Posts: 11,258
    edited May 2009
    Which one did you get?
  • Deadof_knight
    edited May 2009
    tell me you bought the hpsa-1000
  • bsoko2
    bsoko2 Posts: 1,449
    edited June 2009
    The Ed A7S-450 (sealed sub) which has the LT1300 am now has the ICE amp (class D type). Sold the HSU 3.3's and I have two of the A7S-450 subs coming this Friday so it should be interesting with my gear.
    Bill
  • ben62670
    edited June 2009
    500 watter.
    Ben
  • ben62670
    edited June 2009
    Well I spoke with PE about the amp. I explained what I am running for a system. Soon they are coming out with a new upgrade with protection. For now the amps are not designed to handle constant bass heavy music. They are great for HT, but for my purposes the 565's suit me better. The main problem I am having with the 565's is the lack of an EQ to boost lower frequencies due to my sealed sub. PE has been great. I do recommend this sub for normal people, but if you want more than explosions you may be disappointed.
    Ben
    Ben
  • Face
    Face Posts: 14,340
    edited June 2009
    They also appear to use cheap electrolytic coupling caps.
