Shun Mook. Interesting topic. Truth or Lie
Bernal
Bernal Posts: 991
edited May 2009 in Speakers
Shun Mook Explained
The general reaction of Hi Fi users is to regard Shun Mook as a black magic or voodoo - or perhaps psychoacoustics and imagination. The belief of traditional science is what is known is known and must be proven by theory and formulae. Yet there are some many things that science still does not understand and cannot explain.
Shun Mook is not black magic but very simple physics. Sympathetic resonance is the main principal behind it. As in high school you have experimented with tuning forks. Strike one fork of the same frequency and bring it next to a same fork the stationary one will start to react without even touching it.
Sound as we know it is movement of air, but the quality of this movement is the result of resonance of the material providing this vibration. Different material gives out a difference resonance character. For example steel, glass, marble, wood all has their resonance signature.
A musical instrument produces resonance - vibration of air - to give us different pitches and frequencies of sound, the inherent cellular resonance produces the type of sound produced. Strings - from a box of wood of various sizes and shape. Woodwind - from sections of tubes with holes in varies positions. Brass - by forcing of air through this expanding metal tube. Percussion - the beating of skin on frames of wood etc etc.
All these are the result of resonance of the material at the cellular level producing music, as we know it.
Shun Mook is made from Mpingo ebony wood. Mpingo - in Africa means tree that sings. Ebony wood has the most musical properties in its resonance characteristics or else the string instruments will not be using them as fingerboards, the wood winds will not use it as it body.
Looking at a section of the wood it consists of thousands of tubes, or its cellular structure is like a micro-sized pipe organ. When energy makes contact with this material it creates multiple vibrations of the most complexity within its body. A string vibrating upon this wood thus give out a complex but musical resonance to the human ear. On the other hand a plastic fingerboard on a string instrument will create another pattern, but a pattern of a not so musical sound.
The Shun Mook disc is like a musical instrument, receiving sound energy from the speaker and then being excited, resonates and releases a sympathetic resonance of
a musical character to its surrounding. Our invention is making a disc that will resonate at an enhanced rate with the effect of masking the non-musical frequencies and harmonics while amplifying the purer musical spectrum. It is acting like a mirror in a sense that it will energise, absorb, resonate and radiate to its surroundings.
Earlier you mention most tuning devices aims to cancel or absorb resonance, these are actually resonance from non-musical materials, like steel, brass, lead, glass, marble, granite, plastic, rubber, MDF wood, etc. The resonance’s from these materials are damaging to sound produced by the loudspeaker and therefore have to be controlled.
Energy cannot be destroyed, that is a given in physics, so many attempts were to dampen, absorb and isolated the vibrations from these material cannot cure the fundamental problem. You think the rubber feet at the base of the amplifier dampens the vibration, yet it only stores the energy for the moment and delay a release back to the system as a negative feed back. That’s why air bags and pressurised air suspensions does not work well due to the time delay feed back of the negative energy (non-musical). Heavy composite of steel, lead and plastic also just delays the bad resonance and smear up the signal later on.
With Shun Mook we channel away the bad energy, as it cannot be destroyed. Just as you cannot stop a flood with a wall you have to dig a canal to divert it. In this case we use our diamond tipped resonators. The diamond can transfer away the vibration instantly while the ebony wood body acts like a reservoir for the musical energy to be amplified within its body.
Hence this musical energy is feed back into the system while the diamond acts like a mechanical diode - one way out.
Of course we hold some trade secrets as how to enhance this wood and determine the maximum direction of flow energy in a piece of ebony. Anyone can make an ebony disc with real ebony. In fact ten years ago when our disc first hit the market in Hong Kong, within a few hours it was dissected by some copy cat who did try and make some disc of their own but of course was never successful. All they have are some dud-discs - not alive.
A simple test by yourself or your clients is to hold the disc on ones palm and feel the weight. Flip the disc over and weigh it the other way, you will feel as though one way is heavier then the other way. Why? There is an energy flowing out from your palm and the disc is enhancing it. The energy from your palm is the aura of the human body; it differs from person to person. For a male it comes out of your left hand and flow towards your right hand, while for a female its the other way around. The disc is not as simple as it looks and there is a complex process involved in the making of it.
We also make a record clamp that if you have the opportunity to ask Martin to let you hold it, the energy enhancement level is extraordinary
I hope this explains a little bit about how and why Shun Mook works. Most humans have very acute senses and therefore can pickup the changes in a Hi Fi system. Those who cannot hear the difference need not go further with Shun Mook and save themselves a pocket full of money.
1) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
2) SUNFIRE Grand Signature - Bob Carver's
3) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
4) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport (change for a OPPO BDP-83 Blu-ray Disc Player will be available soon)
5) HITACHI P55T501. 55" HD1080 Plasma HDTV
6) POLKAUDIO LSiC (Center speaker)
7) POLKAUDIO LSi15 LEFT (Front speaker)
8) POLKAUDIO LSi15 RIGHT (Front speaker)
9) POLKAUDIO LSif/x LEFT (Surround speaker)
10) POLKAUDIO LSif/x RIGHT (Surround speaker)
11) SONY SA-WP16 ( Sub Woofer 2X200W)
Post edited by Bernal on
«134
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    I'm sorry but this reeks of expensive speaker wire. By far the biggest difference is the placebo effect. Make sure you do blind tests to try and differentiate the shun mook stuff. I'm still surprised that people will swear by expensive speaker wire when in double blind tests no one can tell the difference between generic and expensive wire as long as the copper is thick enough and you're not by a giant power plant.
    I'm not sure about what your examples are trying to prove.
    "With Shun Mook we channel away the bad energy, as it cannot be destroyed. Just as you cannot stop a flood with a wall you have to dig a canal to divert it."
    On the contrary a wall can definitely stop a flood.
    "There is an energy flowing out from your palm and the disc is enhancing it"
    I'm not sure about other polk owners but I'm not going to kid myself. I do not have the ability to direct energy like iron man. If this was true these things would sell like hotcakes! Imagine the weight loss! Sorry I couldn't resist.
    Delete this account
  • artinaz
    artinaz Posts: 185
    edited May 2009
    I was nodding along till I hit this part- "The energy from your palm is the aura of the human body; it differs from person to person. ..."
    If they had left that part out, it would be more believable.
    Question- if it really works, could'nt u just run a frequency sweep with and without it ?
    Azi
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    That's the issue though, it doesn't work. It's even less respectable than the 4,000 dollar amplifiers people delude themselves into hearing massive differences. Amplifiers at least theoretically do make a difference ( although I'd like to see someone in a double blind test differentiate between an 800 dollar amp and a 4000 dollar amp ). If anything shun mook has the potential to make things worse. Chances are cleaning your ears thoroughly makes more of a difference =).
    Delete this account
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2009
    Shun mook is only effective if the speaker feng shui is aligned with magnetic north. In other configurations it has a deleterious effect. :rolleyes:
  • lightman1
    lightman1 Posts: 10,797
    edited May 2009
    Can I order a purple one? Purple is pretty.
    nooshinjohn Posts: 25,955
    edited May 2009
    Shun mook... this sounds more like a line from a bad gangster film...."Shun da mook!" "Shun him!" as they all turn their backs on him as they push his concrete laden shoes into the east river.. and that is where this garbage needs to go as well.
    F1nut Posts: 51,886
    edited May 2009
    Bernal, if you are quoting from some source, please use the quote feature otherwise it appears that you are selling the products yourself. You aren't, are you?
    As for blind tests, they are completely worthless.
    Now back to the question of the blinded testing. Here is what the now publisher (Robert Harley) of one of the major magazines wrote a few years ago....
    Quote:
    Blind tests nearly universally appear to indicate that no differences exist between electronics, cables, capacitors, etc. In fact, one infamous test "revealed" that no sonic differences exist between power amplifiers. Mark Levinson, NYAL Futterman OTL tube monoblock, NAD, Hafler, and Counterpoint power amplifiers were all judged to be sonically identical to each other and to a $219 Japanese receiver (footnote 7). This very test, wielded by the objectivists as proof that all amplifiers sound alike, in fact calls into question the entire blind methodology because of the conclusion's absurdity. Who really believes that a pair of Futterman OTL tube amplifiers, a Mark Levinson, and a Japanese receiver are sonically identical? Rather than bolster the objectivist's case, the "all amplifiers sound the same" conclusion of this blind test in fact discredits the very methodology on which hangs the objectivist's entire belief structure.
    If differences do exist between components, why don't blind tests conclusively establish the audibility of these differences? I believe that blind listening tests, rather than moving us toward the truth, actually lead us away from reality.
    First, the preponderance of blind tests have been conducted by "objectivists" who arrange the tests in such a way that audible differences are more difficult to detect. Rapid switching between components, for example, will always make differences harder to hear. A component's subtleties are not revealed in a few seconds or minutes, but slowly over the course of days or weeks. When reviewing a product, I find that I don't really get to know it until after several weeks of daily listening. Toward the end of the review process, I am still learning aspects of the product's character. Furthermore, the stress of the situation—usually an unfamiliar environment (both music and playback system), adversarial relationship between tester and listener, and the prospect of being ridiculed—imposes an artificiality on the process that reduces one's sensitivity to musical nuances.
    Going beyond the nuts and bolts of blind listening tests, I believe they are fundamentally flawed in that they seek to turn an emotional experience—listening to music—into an intellectual exercise. It is well documented that musical perception takes place in the right half of the brain and analytical reasoning in the left half. This process can be observed through PET (Positron-Emission Tomography) scans in which subjects listening to music exhibit increased right-brain metabolism. Those with musical training show activity in both halves of the brain, fluctuating constantly as the music is simultaneously experienced and analyzed. Forcing the brain into an unnatural condition (one that doesn't occur during normal music listening) during blind testing violates a sacrosanct law of science: change only one variable at a time. By introducing another variable—the way the brain processes music—blind listening tests are rendered worthless.
    edited May 2009
    This is total garbage... I have never in my life experienced such a DRAMATIC difference in performance, clarity and presence as I did when I first plugged in my old Carver TFM-35 into my yamaha preouts. I was so taken aback by the sound that I quickly stepped up and got my Sunfire to run all channels and bypassed the amp section of my reciever completely.
  • Face
    Face Posts: 14,340
    edited May 2009
    Resiroth wrote: »
    You couldn't be more wrong.
  • lightman1
    edited May 2009
    I'll get the popcorn..anybody need anything while I'm in the kitchen?......
    edited May 2009
    lightman1 wrote: »
    how about a slice of that Apple pie ala-mode you have been promising me?:)
    F1nut Posts: 51,886
    edited May 2009
    Yummy....pie!
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited May 2009
    Mmmmm, I like pie. Hopefully this doesn't turn into another one of those threads, lol.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    You really think that 1000 dollar a foot wire makes a difference over 12 gauge speaker wire? For subwoofers it makes a bit more difference but on many hi end systems we've tried out different expensive speaker wires and not noticed a difference. Maybe we're just crazy. Then again these speakers were only 2-4,000 dollars.
    As for blind tests being worthless I'm not so sure. Keep in mind I have no weird agenda like the objectivists. All I care about is great sound without spending extra on things I would not notice. Then again, I don't drive my speakers at very high volumes so perhaps distortion is increased more noticeably at that point.
    Robert Harley states that for improvements to be noticeable it takes weeks and yet many people who announce they just spent 4,000 on an amplifier laud the immediate improvement that this new toy made. Certainly the more expensive amplifiers are of higher quality. Whether or not people can tell the difference is another story. Another issue is that I doubt many people ( although I am sure some do ) have a dedicated room solely for the purpose of pristine sound production. Room acoustics can easily lessen the impact of improved speakers.
    I googled Robert Harley and on the first page of google results, 4th from the top, was a monster article on him. That to say the least is not helpful for his image as an authority on sound. If you stand by monster's HDMI cables there is simply no hope.
    Let's assume that it does take weeks to truly appreciate the small differences. If it takes weeks to notice the difference why spend the extra 3 grand on it? Maybe I'm not as hardcore about audio as other people here but that just seems silly when I'm sure that money could be better put to use for another project.
    The placebo effect has reversed the growth of tumors, I'm sure it's not a stretch to say it could make someone hear a slight improvement if he thought he just spent 10k on cables.
    Maybe I'm weird but if I'm spending thousands of dollars on something I want the improvement to be easily noticed ( like the difference between 128kbps and flac ). For me at least, I doubt I would notice the improvement of thousand dollar cable or shun mook. If you guys feel like your purchases are worth it that is all that matters.
    Delete this account
    F1nut Posts: 51,886
    edited May 2009
    I know it does. YMMV. :)
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    What's your listening environment? I've heard several 2-4 thousand speakers in normal rooms and didn't notice a difference. I'm assuming you've got 20k+ speakers and a specially treated room? You should try to take the skeptics up on their many offers. there are multiple ones giving 15k+ to differentiate between generic ( low gauge ) and high end cables.
    I know for a fact that cables in retail stores have the highest markup often in the whole store. This is for monster etc. ( which I actually use since I got the wire free from some guy selling speakers ) and not for the even more expensive brands. I know people here think blind tests aren't worth crap but if the difference is significant shouldn't it be easy to differentiate? If it's not significant why should you spend 400 on a 4000 dollar set of speakers? wouldn't that money be better invested in room treatments ? This doesn't apply to people who like spending extra money to be sure everything is perfect but I doubt that describes a lot of polk fans.
    I'm interested in what stands out f1nut and primarily if the difference is substantial or if you have to look for it.
    Delete this account
    edited May 2009
    Welcome back Seafart:eek:
    Looks like your command of the english language has improved:)
    Only seven posts old and you decide to start off with this BS... all that is left to say is welcome to CP!
    F1nut Posts: 51,886
    edited May 2009
    The answers to all your questions lie within my 17,000+ posts. Enjoy!
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    Wow! I wasn't aware there were people around that actually thought post count mattered.
    "Well, I don't want to brag or anything but....I have posted nearly 1600 messages on the internet"
    Congratulations. Really, I'm in awe of your posting capabilities. :rolleyes:
    I still maintain that anyone without absurdly high end speakers and more importantly custom made rooms with acoustic treatment should not bother spending wads of cash on speaker wire. If you've spent 400k on your system then yeah, why not ( it will at least look cool ). But if you've got a 4k dollar system not one person I've met has been able to tell the difference ( and not one person in the world has been able to provide anywhere near 100% accuracy between generic and expensive speaker wire ).
    I'm really surprised there are so many high end audiophiles on polk's forum. Polk's highest end line is, what, under 2.5k for a stereo setup right? I didn't expect to find people spending 1k PER FOOT of cable. I never pegged polk's consumer base as elitist.
    Nooshinjohn, you're clearly a superhuman at hearing. Why don't you make an easy million dollars comparing monster cables to 7,500 dollar audio cables? Should be a piece of cake right? In spite of all of these self proclaimed golden ears out there no on has done it so far. It appears your understanding of basic human psychology has not improved. :rolleyes:
    Edit: this is directed at nooshinjohn, not f1nut of course.
    Delete this account
    F1nut Posts: 51,886
    edited May 2009
    About what I expected. How about you relax, lose the attitude and get your read on if you really want the answers to your questions. If not, move on.
    edited May 2009
    I won't be brought into your BS...
    Hearing has nothing to do with Psychology and everything to do with the ear's ability to interpret sound. I do not claim to be an expert on anything, nor do I claim to be superhuman. Rather I come here to learn from others, contribute where I can and associate with folks I have come to respect, some less than others, but that's family for you. Bottom line is were support each other through this crazy mess called audio appreciation. Some call it being an audiofile. To me that means we appreciate sound and the efforts some members go to to get the most out of their gear, whether we agree or not.
    You sir have made 8 posts here, EIGHT! I do not care if you have made one post per second for the past 15 years on the internet elsewhere. Here is what counts to Club Polk. I encourage you to take a step back and evaluate why you joined the forum and contribute a bit before you start trashing those that have earned their due by doing the same.
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    On the contrary High-end audio has a lot to do with psychology. If you hook up two identical wire sets and tell them that one is more expensive and features gas injected platinum plated liquid core technology they'll always choose that one as being superior. This of course is known as the placebo effect.
    I do not claim to be an expert of audio equipment but I do believe the laws of diminishing returns definitely applies here. You only have to read the specifications for these products; ultra-pure 99.9999% copper is listed as a component of monster cable's "Sigma Retro" speaker cable. Can humans differentiate between not just thousandths of a percent, but ten thousandths of a percent? My own speaker wires are listed as having a Magnetic Flux Tube. Really? A flux tube? I'm surprised people swear by flux tubes and 10thousandths of a percent pure copper but balk at the idea of special wood to enhance sound.
    I agree my attitude could have been better in my last post but bragging about post count is pretty silly under any circumstance.
    I do appreciate high-end audio but it's things like Shun Mook and 50 grand spent on speaker cables that I believe give high-end audio a bad name.
    I still have a question about why AB comparisons while blindfolded are not accepted. If it does indeed take weeks to tell the difference why spend so much on it? I would think the expensive speaker wire would be an instant improvement as speaker upgrades are ( going from 500/pair to 2k/pair, ) especially if you were coming from generic wire.
    I'll try to keep my posts more civil in the future.
    Delete this account
    F1nut Posts: 51,886
    edited May 2009
    Who's bragging? I simply suggested that you could find the answers to your questions in my posts. Perhaps now that we have that matter cleared up....
    Please re-read the following,
    He doesn't say it takes weeks to tell the difference, rather it takes weeks to learn the subtleties. I agree 100%
    I've recently been playing with a very expensive power cord on loan from the maker. Mind you, my current pc wasn't cheap either. So, after learning the subtleties of this "new" pc I could tell that my original pc sounded better to my ears. This, of course, makes the placebo effect theory or the just because it costs more theory invalid. When one learns how to listen and keeps an open mind, one will be blessed with audio nirvana.
    heiney9 Posts: 25,486
    edited May 2009
    Resiroth, You've already stated you tried higher end cables (in your words"just more expensive") and didn't notice a difference in your system in your environment, with your ears. Why can't you leave it at that? Others including myself have had the opposite results and we're fine to encourage others to try better cables and gear. Not to chastise those who can't hear a difference.
    I have heard differences in very modest systems with very modest cables. Many times it's about the synergy and like F1 stated he tried an uber expensive cable and it didn't sound better in his system.
    Why is it the cable crusaders like yourself can't just state your opinions/experiences and move on? Why do you feel you have to chastise those who do and can hear a difference. Personally I can respect anyone's opinion who has given a valid effort to try different things and in the end feels there's no benefit. Why do I have to participate in all these scientific tests to prove to you what I hear? Why does that matter to you? How does it benefit you? Is it so you think you can say "I told you so" or so you can continue to chastise and tell people they are crazy?
    All I care about is what my rig sounds like to my ears, in my environment, with my music, in my sweetspot.
    In my office rig I switched from 14g "zip" chord to Canare Star Quad and heard a very subtle but pleasing positive difference. The Canare, in the end, cost less than the "zip" chord. So these positive changes aren't just limited to "expensive" high end gear or speakers. Just using a pair of refreshed, lowly, 20 year old Polk Audio Monitor 5B's, an inexpensive dac streaming FLAC files from my computer, using a modest Toslink cable w/Signal Analog II's hooked to an inexpensive 13wpc hybrid tube buffered gainclone output amp.
    Guess what.................this is the best (and most inexpensive) sounding office rig I've assembled so far. The synergy is off the charts. It's the sum of all the parts working together that makes a stellar rig. I've tried expensive to modestly priced cables and finally settled on MIT's for the main rig. It would take a lot to convince me to use any other type of cable and I/C's.
    I alos tried some much more expensive MIT model and guess what.............I didn;t care for them as much as I did the current MIT's I'm using. S-Y-N-E-R-G-Y
  • messiah
    messiah Posts: 1,790
    edited May 2009
    Resiroth wrote: »
    9 posts and you're bashing the vets, huh? Just so you know it wont be "placebo effect" when everyone starts calling you a **** moron. Do yourself a favor and spend some time reading. Do some searches. LEARN SOME THINGS. Then come back and join our discussions. Once you lose the attitude that you know everything, it's amazing how much you can learn!!
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • Resiroth
    Resiroth Posts: 17
    edited May 2009
    I have always taken the stance that you should buy whatever you want. Different speakers are pretty easily identifiable so I believe most of the budget should be allocate to them. I said in one of my posts the equivalent of whatever makes you happy and I mean that.
    The reason why us cable crusaders want someone to prove the can hear any difference is that otherwise expensive cables are in the same range as shun mook. Expensive accessories which make a difference but can never be noticed in a double blind test. If someone can tell the difference in a test then it graduates to a legitimate component.
    As for me bashing the vets, I'm really not. All that is happening is vets are bashing someone with low posts and asserting their perceived superiority as master of the internets.
    Seriously google the placebo effect, this is basic psychology 101, not some theory. It's like when people claim to be able to see 100 fps on a 60 hz monitor. I never was talking about you f1nut, I was referring to people who just look at post count as the measurement of knowledge.
    Delete this account
  • Face
    Face Posts: 14,340
    edited May 2009
    Quit speaking in absolutes, not every blind test has disproved differences in cables, amps, etc... You sound like an internet expert on the subject, why don't you get out there and try some different gear and cables instead of going by what you've read on the internet and psychology books. Hit a few high end shops and ask to demo different cables.
  • kevhed72
    kevhed72 Posts: 5,152
    edited May 2009
    Bernal, put me down for 5 of those Shun Mook devices...one for each speaker. I may need 2 more when I upgrade to a 7.1 system. Thanks
  • kevhed72
    edited May 2009
    Rim / bass drum shot....But seriously folks, I'll be here all weekend.
    I think if you purchased one of these things, you would get shunned up the mook...
  • amulford
    amulford Posts: 5,020
    edited May 2009
    While that statement is funny as hell, I just realized you are really effed up...:D
