What to do?
bigaudiofanatic
bigaudiofanatic Posts: 4,415
So my neighbor and I have been wathing start wars episode 1 and was going very smothly until we get to the pod racing scene. That scene basicly was making the LSi 25 subs POP and distort a bit. He has the lsi 25's a onkyo 3 room reciver 2 direct tv recivers a blu ray player and a sony lcd 47 inch tv all pluged in to the wall via power strip. Also has in the same room and on the same braker the celing fan and the lights as well. So what can we do to get them to stop POPING at that scene is it just to little power getting to them or is it the gains need to be set a little lower. Everything else including music movies and shows sounds great but it is that scene. So what to do?:confused: On a side not the gains on them are set at there "normal setting"
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • McLoki
    McLoki Posts: 5,231
    edited May 2009
    I am guessing that you really need a subsonic filter.... It is just trying to reproduce bass that is to deep for the LSi25 to deal with. best suggestion would be to get a subwoofer and crossover the LSi25's at 60hz or so.....
  • bigaudiofanatic
    edited May 2009
    Well he rely dose not want to get another sub in the room there rely is not room for it. So he will probably will just have to set the cut off and not have that rely low bass.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited May 2009
    What frequency's are in that scene?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited May 2009
    I found out the lowest is 14 hz
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited May 2009
    The speakers were even poping during the movie stealth today. The knobs on the rear of the speakers were set at 80hz what else should we try?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • McLoki
    McLoki Posts: 5,231
    edited May 2009
    The knobs on the speakers are where they cut over to the powered 10" speaker.
    one thing you could try (just to see if this is the issue) is set your speaker to small with a 40hz crossover in your avr.
  • bigaudiofanatic
    edited June 2009
    It still is doing it on things like tokyo drift and even polar express the Frequency is set to factory and the volume is set for a little more than half. Also in setup the bass is at the lowest it is at -15 db and if you go to THX there is less bass than if it is dolby but dose not sound as good.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • messiah
    messiah Posts: 1,790
    edited June 2009
    His receiver probably cant handle the 4 ohm load.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    messiah wrote: »
    But would that effect the powered bass portion of the speakers?
    If they were unpowered I'd point to this but I believe the LSi25s are powered subwoofer sections, right?
    Main Surround -
  • bigaudiofanatic
    edited June 2009
    Correct they are powered
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    heiney9 Posts: 25,432
    edited June 2009
    Well in my experience once you "pop" a speaker a few times it becomes weak or damaged and it will "pop" more often and at lower levels. The damage may already be done.
    P.s. what speakers are popping? Woofers or mids?
    treitz3 Posts: 19,986
    edited June 2009
    Push all of the mid range drivers and the bass drivers in a couple of times with the rig powered down [being careful not to touch the dust caps]. Do they all bounce back with smooth precision or can you feel some sort of an obstruction?
  • nguyendot
    edited June 2009
    treitz3 wrote: »
    See if any of the drivers (with cones) scratch. If you feel scratching while pushing it directly in, that can mean the voice coil is blown. The scratching is the coil scraping.
    Main Surround -
  • mr2sw21
    mr2sw21 Posts: 115
    edited June 2009
    I have connect my system to my pc and whenever it start window before the "starting" music kicks in there a "Plug" sound happen to all my speakers. What is that? It happens every time when I start window.
    Please educate me what is the "Poping" you guys talking about for the speakers which you all mention that will damage the speakers? What does that sound like is that what happening to me?
  • nguyendot
    edited June 2009
    The "Plug" sound is just your computer initializing the sound card more than likely. Usually this is the fault of a poorly designed sound card that does not have a soft-on to prevent sending noise through on power up and power down.
    I would wait until the computer is on an fully operational prior to powering on the speakers/amp to prevent this.
    Main Surround -
  • rayslifecycle
    rayslifecycle Posts: 511
    edited June 2009
    nguyendot wrote: »
    Agreed - after the computer starts up, turn on your amp - mine does this as well.........
  • mr2sw21
    mr2sw21 Posts: 115
    edited June 2009
    thanks guys, So that "plug" sound is different than the pop sound you all mention in the previous reply? So then what is a speaker pop sound like? And what is clipping too? How does that sound like?
  • bigaudiofanatic
    edited June 2009
    I still need to find out why it is doing this going to check the woofers now.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited June 2009
    Just checked them they go in and out very smoothly no resistance at all.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • messiah
    edited June 2009
    More likely a problem with the receiver than the speakers
  • danger boy
    danger boy Posts: 15,722
    edited June 2009
    simple solution.. quit watching the pod racer scene.. problem solved. :p
    thanks everyone, I'll be here all night. ;)
    PolkFest 2012, who's going>?
  • nguyendot
    edited June 2009
    Well the pop and distortion is constant during the scene, and during operation.
    The pop from your computer is only on startup and not during operation, right?
    Main Surround -
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2009
    LSi25 aren't going to hit 14hz. The volume is too high, the woofers are bottoming out and simply being overdriven....back off the volume.
  • bigaudiofanatic
    edited June 2009
    But I mean it is even doing ti while watching the polar express and Tokyo Drift. So should I cut back the volume on the towers or cut the frequency on the towers.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • mr2sw21
    mr2sw21 Posts: 115
    edited June 2009
    nguyendot wrote: »
    yes it just start up only.
    But I am just wondering the pop you all mention about during the movie, is it the same pop that when I start the window?
  • mr2sw21
    mr2sw21 Posts: 115
    edited June 2009
    Can the Lsi be defective?
    edited June 2009
    Both. If it has happened too many times already, you may have compromised the drivers. Keep it up and you may compromise the amp as well.
    Your goal? Never to hear that sound again.
  • Face
    Face Posts: 14,340
    edited June 2009
    You're only going to get so much out of a 10" side firing woofer in a small enclosure and a 150 watt plate amp.
  • nguyendot
    edited June 2009
    mr2sw21 wrote: »
    No.
    One is distortion, one is just a startup signal coming from your pc. Totally different.
    Main Surround -
  • rayslifecycle
    edited June 2009
    mr2sw21 wrote: »
    When your questions are answered, and you are listening to your system, you will be unhappy.
