Marantz SR-82
chef-nick
chef-nick Posts: 40
edited May 2009 in DIY, Mods & Tweaks
this receiver makes a popping or snapping sound only on the right channel. not affected by the volume knob or balance. I cleaned all appropriate connections with deoxit to no avail. any suggestions? I am an a noob to this stuff, so is it worth me messing around with? or should I just sell it off as a preamp?
thanks
Post edited by chef-nick on
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2009
    Do you get any signal out of that channel? It might be as easy as some capacitor going bad on the signal path. Or you might have to pull the oscilloscope out and find, which part is failing.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • jrgoswick
    jrgoswick Posts: 159
    edited May 2009
    This will be a little easier than an O-scope. Does it do it on one source or all sources? Interchange left and right channels. Does the problem follow with the change? If so, it's the amp, otherwise you need to check your speaker.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • chef-nick
    chef-nick Posts: 40
    edited May 2009
    it's not the speaker. I have only tried it with fm and am radio. always out of the right channel. I will try some other sources, but I'm confident that it will make no difference. I do get signal out of the channel and it sounds really really good until the popping noise. thanks for the help I will check some other stuff as well
  • chef-nick
    chef-nick Posts: 40
    edited May 2009
    definitely the amp. should I bother or just dump it? I have no experience troubleshooting which component in the amp is the problem.
  • jrgoswick
    edited May 2009
    If you've no experience in troubleshooting, I'd just dump it.
    Onkyo TX-SR705 AVR
    Polk CS300 Center
