Marantz SR-82
chef-nick
this receiver makes a popping or snapping sound only on the right channel. not affected by the volume knob or balance. I cleaned all appropriate connections with deoxit to no avail. any suggestions? I am an a noob to this stuff, so is it worth me messing around with? or should I just sell it off as a preamp?
thanks
thanks
Post edited by chef-nick on
Do you get any signal out of that channel? It might be as easy as some capacitor going bad on the signal path. Or you might have to pull the oscilloscope out and find, which part is failing.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
This will be a little easier than an O-scope. Does it do it on one source or all sources? Interchange left and right channels. Does the problem follow with the change? If so, it's the amp, otherwise you need to check your speaker.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
it's not the speaker. I have only tried it with fm and am radio. always out of the right channel. I will try some other sources, but I'm confident that it will make no difference. I do get signal out of the channel and it sounds really really good until the popping noise. thanks for the help I will check some other stuff as well
definitely the amp. should I bother or just dump it? I have no experience troubleshooting which component in the amp is the problem.
If you've no experience in troubleshooting, I'd just dump it.Onkyo TX-SR705 AVR
Polk CS300 Center
