Adcom gfa 555 vs.Rotel 990BX
zarrdoss
zarrdoss Posts: 2,562
edited June 2009 in 2 Channel Audio
I am looking at getting one of these maybe in the next few days and was wondering if anyone has had any exp with the Rotel, both about the same power, but the Rotel is still new never been used in the box for 450. and the adcom is 375 but about 9 years of use on it.
Thank you!
Post edited by zarrdoss on
    Toolfan66 Posts: 18,140
    edited May 2009
    One for upstairs One for downstairs. :)
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    $375 is a little too high for the 555.
    Ben
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    ben62670 wrote: »
    Agreed,Go for the new Rotel:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Ender
    Ender Posts: 603
    edited May 2009
    The Rotel seems to average for about $400 give or take $50. The Adcom averages for $325 give or take $25.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • zarrdoss
    edited May 2009
    Thanks guys, going to talk to the guy tonight with the Rotel and see what I come up with. does anyone know if it is a common ground amp?
  • zarrdoss
    edited May 2009
    I should have the Carver back sometime for upstairs or down whatever works better.:)
    edited May 2009
    zarrdoss wrote: »
    It's common ground, I have done all the leg work on the Rotel amps that i have looked at and that is one of them. I actually called Rotel and talked to them about a few amps. I really want to hear the RB-1090 :cool: $$$$$ it sounds bad **** but i have read up and down reviews.
    380 x 2 8ohms
    760 x 2 4ohms
    1520 x 2 2ohms
  • zarrdoss
    edited May 2009
    380 x 2 8ohms
    760 x 2 4ohms
    1520 x 2 2ohms
    If I decide to pass on this would you want it?
    edited May 2009
    zarrdoss wrote: »
    No my angel has bigger plans for me, or so he say's :p
    I will think about it, i will get back to you on it.
  • zarrdoss
    edited May 2009
    geez Larry, 760x2 @ 4 ohms
    I just talked to him and will go look at the Rotel sometime soon.
  • lakesailor
    lakesailor Posts: 319
    edited May 2009
    I haven’t had a 990BX but if it sounds anything like the Rotel RB1080 that I did have; I can say it will sound a fair bit different from a GFA 555. If you can, try to listen to both and see what you prefer. I would go with the Adcom, however that is a case of personal preference. Good luck.
  • zarrdoss
    edited May 2009
    I got the Rotel and another smaller Rotel (for surrounds) from him and am going to go get one more for the center So I will have all Rotel pre and power.
  • danz1906
    edited May 2009
    Congrats on the Rotel amps.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • zarrdoss
    edited May 2009
    danz1906 wrote: »
    Thanks I am hooking them up now but running to a bit of a problem with the rack, nothing the rotozip will not fix.
  • zarrdoss
    edited May 2009
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2009
    Nice setup.... How does it sound ?
  • zarrdoss
    edited May 2009
    Thank you! It sounds fantastic, best of both worlds, excellent 2 channel and HT to boot.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2009
    Great choice on the Rotel....no slight on the Adcom, but it fits the bill better.
  • xsmi
    xsmi Posts: 1,804
    edited June 2009
    380 x 2 8ohms
    760 x 2 4ohms
    1520 x 2 2ohms
    Tool,
    Is the 1090 common ground? I want to make sure because I may have a line on one.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    edited June 2009
    xsmi wrote: »
    Tool,
    Yes it is.. I want one bad.:cool:
  • leroyjr1
    edited June 2009
    xsmi wrote: »
    Tool,
    Yes the Rotel
    1050
    1070
    1080
    1090
    1095
    1075
    are all common ground. There new class d amps are not.
    edited June 2009
    zarrdoss wrote: »
    Kevin how did i go past this post? is that the one that was in the springs?
    Awesome:cool::cool:
    Congrats..
  • Flash21
    Flash21 Posts: 316
    edited June 2009
    I had a Rotel 990 in my system for a number of years, I feel it was an outstanding value new and even better value at today's prices. To my knowledge the 1090 is actually little different internally from the 990, most of the difference is the cosmetic fins and such externally.
    I compared the 990 to the 980 (again, similar to the 1080). The sound was quite similar (not surprisingly), but the 990 just had a little more "there" to the sound, slightly fuller and more dynamic, which I attributed to the greater headroom of the 990.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • zarrdoss
    edited June 2009
    Awesome:cool::cool:
    Congrats..
    Thank you! the 990 was in Aurora and the other two came from ft Collins and here in Loveland, I really like the way it sounds, nice full bass and clear highs.:D
